10-15-2023, 10:37 PM | #1 |
Rep 135
Drives: 23 M240I RWD
switching headlights
Recently bought a used 23 M240I with 3K miles has everything i need besides premium package so the headlights aren’t adaptive , can i switch them and code them it would be as easy as said ?
10-16-2023, 04:34 AM | #2 |
Rep 2,070
See this thread https://g87.bimmerpost.com/forums/sh....php?t=2054199
10-16-2023, 03:01 PM | #3 |
Rep 747
You in theory should be able to swap out the hardware (whole headlight assemblies) and code them however BimmerCode will not help. You will need to modify the Vehicle Order (VO) using either E-Sys, BimmerUtility or ProTool by BimmerGeek. This will allow you to tell the car (ECUs) that you have adaptive headlights installed.
That being said, I am not 100% sure if you will have the hardware to recognize when to turn on/off the brights. You might, do you see a camera in the windshield behind the rear view mirror? |
SNOW_G4273.50 |
10-16-2023, 03:09 PM | #4 | |
Rep 135
10-16-2023, 03:24 PM | #5 | |
Rep 747
If not, try asking on the G20 forums as there is usually more traffic over there. It looks like they also have similar headlight options (adaptive headlights are an option on their Shadowline package, does not mention it in Premium package) but beware that laser lights are something completely different that are no longer optioned on the 3 series and were never available on the 2 series |
SNOW_G4273.50 |
10-16-2023, 03:28 PM | #6 | |
Rep 135
10-16-2023, 03:32 PM | #8 |
Rep 135
10-29-2023, 10:03 AM | #9 |
578
Rep 2,047
01-29-2024, 03:36 AM | #10 |
Rep 47
01-29-2024, 03:44 AM | #11 |
Rep 47
found link with some pics: https://g87.bimmerpost.com/forums/sh....php?t=1940670
01-29-2024, 03:46 AM | #12 | |
Rep 135
01-30-2024, 01:27 AM | #14 |
Rep 135
Haha yea i have that btw 😜😜 on my M240I Id8
01-30-2024, 01:31 AM | #15 |
Rep 47
01-30-2024, 01:40 AM | #16 |
Rep 47
I'm considering DIY, is it possible with BimmerCode? or Do I need esys?
I found this on bummercode web, not sure if it works Layout Change of layout in the instrument cluster. Values: ALPINA M M Performance up to 160 mph M Performance up to 200 mph M Sport Standard Requirements: “Instrument Cluster” DKOMBI4 control unit |
01-30-2024, 01:48 AM | #17 | |
Rep 135
And a dongle thing to emulate, go to 3 series forum / DIY CODING / M CLUSTER all the info is there so far me and this guy have done it it looks really good |
capturedbysebastian16.50 |
01-30-2024, 01:54 AM | #18 |
Rep 47
thanks for the tip, maybe I'd better ask pro to do that.
01-30-2024, 12:52 PM | #19 |
Rep 1,954
Before spending $50-$80 on a Bluetooth or WiFi adapter, look into the OBD2 plugs with an Ethernet port, then get an Ethernet to usb-c or lightning cable adapter to connect it to your phone. I wish I had done this, as it’s cheaper and faster. Can anyone weigh in who’s done it this way?
SNOW_G4273.50 |
01-31-2024, 02:57 PM | #20 | |
Rep 1
https://www.amazon.com/dp/B07Y5FJ695 and this ethernet to Lightning dongle: https://www.amazon.com/Lighting-Ethe.../dp/B07VK8Q36S Seems quick enough!!! |
01-31-2024, 03:05 PM | #21 | |
Rep 1,954
02-01-2024, 04:31 PM | #22 |
Rep 9
Can you send the shop where you are going to send your headlights because I have the 2023 M2 and since it was in the show room I bought it and came with the Standard headlights and I also want to get the adaptive headlights 😮‍💨
SNOW_G4273.50 |
