bimmerpost/
BMW M2 and 2-Series Coupe
      10-05-2023, 05:31 PM   #1
wj100
Drives: 2022 Supra 3.0
Will I Feel Lighter Wheels?
Much has been said about the 930M wheels being cast and not forged. I've had my G87 a few weeks now and can't shake the notion that it feels a bit numb and heavy. I'm thinking lack of steering feel and overall weight are the two biggest culprits.
My question is this: if I go to wheels that are roughly 20 pounds a piece, am I really going to feel a significant difference in performance? Will it feel lighter on its feet? Or is it unrealistic to think the difference would be noticeable?
Thanks in advance...
PS, side benefit of new wheels...these bad boys are a chore to clean.
      10-05-2023, 05:49 PM   #2
RandomBro
Drives: BMW M2 (G87)
Yes, you will feel the difference. Add in some stickier tires and u will get 2x the feel.
I went to forged 19x10.5 square on 285 AR-1s MASSIVE improvement over stock.
Also, make sure your tire pressure is set properly I had over inflated tires from the dealership, killed all feel.
KevM2723.50
      10-05-2023, 06:32 PM   #3
Tag
this is the way
Tag's Avatar
18160
Drives: N-1 starfighter
Yes
Yes
No
      10-05-2023, 07:27 PM   #4
Ravenseal
Ravenseal's Avatar
Drives: 2023 M2 6MT
You absolutely will, specially if you go down to 19-21lb/wheel.
2023 G87 M2 - Toronto Red | 6MT | M HAS | CF Roof | BMW 826M Forged Wheels | Mishimoto Skid Plate | Active Autowerks Single Midpipe
Retired: 2022 M240i xDrive | 2021 Audi RS5 | 2019 Camaro 2SS 1LE 6MT | 2016 428i GC | 2011 BMW 335is
      10-05-2023, 07:45 PM   #5
apez
Drives: BMW G87 M2, F25 X3
2024 BMW M2  [7.62]
2015 BMW X3  [7.25]
Even on my G42 the difference between cast and forged wheels was like night and day.
      10-05-2023, 07:50 PM   #6
billspreston
billspreston's Avatar
336
Drives: G87
The change from 930M to 827M was definitely noticeable.
rons e921397.00
      10-05-2023, 07:52 PM   #7
FryCookOnVenus
Drives: G87 (Preorder), Toyota 4Runner
I'm also considering moving to 19in square set up when it's time. Are there any other modifications required with that (brakes, tire pressure sensors, etc.), or is it as simple as just mounting the wheels and driving away?
What tires do you run now? Any recalibration required to get accurate readings on the speedo and odometer?
Thanks and enjoy!
      10-05-2023, 07:57 PM   #8
RandomBro
19x10.5 square 285/35/19 all 4 corners perfect fit no modifications at all. Speedo will register exactly the same.
Essentially, put wheels and tire onto car and drive off. No issues.
      10-05-2023, 08:05 PM   #9
M_Power Rob
Drives: '23 M240 and '23 M2
Keep this in mind...when its time for your first brake job, go with a quality aftermarket rotor that is lighter than the OEM rotors (think Girodisc), saving even one pound per rotor will make a noticeable difference.
      10-05-2023, 08:09 PM   #10
baron95
baron95's Avatar
1704
Drives: BMW G87 M2
The first purchase for my G87 were a set of takeoff G80 826M wheels - saves 18 lbs total. (Just a great deal with nearly new tires)
And my car is still in Mexico being built.
Second purchase will be the Antigravity battery in the spring to save 38lbs.
I hope I feel both. But betting I will feel the wheels more.
G87 M2 BSM On Order
      10-05-2023, 08:18 PM   #11
ZPD
Drives: 2022 M850i GC, 2023 G87
Thanks and enjoy!
no speedo recall but everytime I switch between my street combo and track combo my car will flash a message that I have changed tires and I have to reset the TPS. It isn't hard but it is really annoying.
      10-05-2023, 08:22 PM   #12
M_Power Rob
The battery will make the car lighter but not the same effect as shedding weight on wheels/brakes...reducing unsprung and rotating mass is the key.
baron951703.50
VegasG42373.50
      10-06-2023, 07:50 AM   #13
M_Power Rob
https://girodisc.com/finder/?pfresul...All&f_axle=All
      10-06-2023, 10:21 AM   #14
M_Power Rob
What the heck is with the mods here...this went from the G87 general topic section and they moved it to the G42 forum.
      10-06-2023, 12:30 PM   #15
wj100
You are right, this question will never be answered again...Moderator, please at least put this in the G87/Wheels and Tires forum. Thanks.
      10-06-2023, 01:49 PM   #16
KevM2
KevM2's Avatar
Drives: 2019 F87 M2C, 2023 G87 M2
BMW M2 Competition  [0.00]
  [0.00]
Exactly! Inalso noticed a massive improvement in steering feel when I dropped the pressure to 32… dealer had them at 36 but it could’ve easily been temperature change
      10-06-2023, 01:54 PM   #17
RandomBro
I had mine set at 38 PSI COLD by the dealership upon pickup, its supposed to be 32 COLD. If you want EVEN MORE feel 30-31 COLD is even better.
on 38 Cold I was like aww man this thing really does feel like doo doo, numb, no feedback blah blah.
As soon as I dropped it to 32, car came alive in terms of driving feel and feedback.
      03-18-2024, 11:50 AM   #18
21M235IXGC
21M235IXGC's Avatar
Drives: m
Yes you will , I changed my wheels this weekend and they are 10lns lighter in the front and 8lbs lighter in the back and the steering is so much better and light and it’s not as stiff as it was before with the ringlets . And the take of definitely quicker off the line than before
..2021 M235ix
g87
