08-29-2023, 09:41 AM | #1 |
Rep 10,891
IND | Studie BMW Display Multifunction Screen Protector - iDrive 7
The BMW iDrive display has been enlarged with each new model, and operations such as swipe gestures similar to smartphones have been adopted, making it a more hands-on interactive style. However, this large screen and direct operation have some drawbacks, such as difficulty seeing the display due to glare from direct sunlight or street lights, and the display surface becoming dirty as a result of use... To make the display easier to see and use under these conditions, a film has been developed specifically for BMW, with added functionality! The film surface has a special coating that makes it easy to perform operations like swiping, and dirt such as sebum and oil from food can be easily wiped off! Furthermore, the coating protects the display surface from scratches caused by fingernails and other objects! The base layer has a double-layered AR (anti-reflection) and AG (anti-glare) treatment, so even when exposed to direct sunlight or street lights, the display content can be seen clearly without any washed-out appearance! The AG treatment enhances both usability and stain resistance, and greatly affects the visibility of the display screen, so only a minimal treatment is applied, considering its use in a vehicle. As a result, the transparency is extremely high, at over 95%, allowing for clear and vivid displays without inhibiting high-definition imaging! This product uses a special protective sheet called "Kiresepa" that makes it easy to position and apply! Even those who are not used to applying film can easily position it, making it a less error-prone film! In addition, the special adhesive allows for multiple reapplications, so you can adjust the position until you are satisfied! The "MULTIFUNCTION SCREEN PROTECTOR" is a purely Japanese-domestic product, from planning, material development, design, manufacturing, and packaging, all under high-quality domestic control! Product Details:
The Studie BMW Display Multifunction Screen Protector - iDrive 7 may be viewed at the following links to our online store: https://ind-distribution.com/product...ector-idrive-7
