08-27-2023, 08:17 PM | #1 |
Ballin’ on a Budget
Rep 15
Catless DP Check Engine Light
Hi everyone,
I have a 22’ M4CX with MST CAI and R44 Catless DP installed. I am running the R44 Catless DP with Big Daddies Mini-Cat spacers. The CEL comes on for days, then goes away for a day or two and then comes back on. I’m not worried about the CEL, but I am more worried about if the catless dp might cause an issue to the engine? The code I get is something about running to rich or too lean. Is that something I should be worried about? Thank you! |
08-28-2023, 07:11 AM | #2 |
Rep 5,188
It’s the upper O2 sensors that control AFR. Those haven’t been messed with.
The lower O2 sensors detect catalytic heat up and health. If you’re catless then a lower O2 CEL means nothing. Ignore it. I guess your cat spacer needed a hair more space.
08-28-2023, 09:43 AM | #3 |
Rep 191,216
Running catless won't cause any issues to the engine.
MagicF8x99.00 |
08-28-2023, 04:32 PM | #4 |
Rep 5,033
Like others have said if it's just the lower o2's throwing a code for emissions it's not a huge deal. If possible try and read the codes to be sure it's that and not something else. You may also want to know if it's just one bank or both banks. If it's one bank you may have a cracked cat in the o2 spacer and its easily fixed with a new spacer.
MagicF8x99.00 |
08-29-2023, 09:13 AM | #6 |
Rep 191,216
08-29-2023, 11:01 AM | #7 |
Rep 5,033
Try and read the codes before if possible. You can grab a cheap maxiscan off amazon for like 30 bucks.
08-30-2023, 07:41 AM | #8 | |
Ballin’ on a Budget
Rep 15
08-30-2023, 09:14 AM | #9 |
Rep 6,786
You need to look up the actual code:
"When an OBD-II equipped vehicle has a stored P014B code, it means that the powertrain control module (PCM) has detected a delayed response time from the downstream (or post catalytic converter) oxygen (O2) sensor or circuit for engine bank two. Bank 2 specifies the bank of the engine which does not contain the #1 cylinder. Read more at: https://www.obd-codes.com/p014b Copyright OBD-Codes.com" In this case, seems very logical to get this fault if you are running with no cats. |
09-05-2023, 02:41 PM | #10 | |
Rep 23
09-05-2023, 03:02 PM | #11 | |
Rep 742
So I'm not sure I'd agree that the delayed response codes are expected due to simply not having cats. But maybe expected/likely if using any type of spacer that moves the postcat sensor tip (too far) out of the exhaust flow? I've seen some people saying that lamba = 1 for the precat sensor is calibrated based on the postcat sensor reading since the postcat sensor should theoretically be more accurate right at lamba = 1. Can't find specific detailed info for s58 to confirm/deny. Wish some real ECU tuners would chime in since maybe they know if that sort of calibration actually exists and if it's disabled when tuning cars with no cats. |
09-05-2023, 03:29 PM | #12 | |
Rep 23
09-07-2023, 12:25 AM | #13 |
Rep 237
I tried the BDG minicats and BDG spacers w my 200 cell DPs, both caused the delayed codes. Dropped all spacers and went w OEM direct mounting to the DPs and no CEL. If you're only getting the delayed code, you likely just need to go OEM or the short empty spacers w catless.
09-07-2023, 10:27 AM | #14 | |
Rep 5,033
09-07-2023, 01:56 PM | #15 | |
Rep 237
BM3 tuned but haven't disabled the "Catalytic Monitors (CEL)", never received the cat efficiency codes. I'm in Phoenix, so environment likely plays into it a bit. Low has been mid 80s here lol. |
Info@mad-us.com1977.00 |
09-07-2023, 02:44 PM | #16 | |
Rep 5,033
Tags |
bigdaddiesgarage, catless, catless downpipe, cel, lean, r44, rich |
