BMW Lease Deals
      08-04-2023, 10:06 PM   #1
chujk1985
Drives: 2023 G80 M3 X Comp
iSweep Pads Shifting and Clicking
Anyone else with iSweep (1500) pads that shift slightly and click? I get it when going forward and then backwards and hitting the brakes.
Any way to reduce this? Better lubricant?
      08-04-2023, 10:36 PM   #2
Chubbiejones
Chubbiejones's Avatar
Drives: 2020 BMW M340i
I know I’m no help to your question but I’m definitely interested in the responses that others might have.
      08-05-2023, 04:45 AM   #3
evoi19
evoi19's Avatar
Drives: 2022 G80C
I get the same on the 2000. When starting off the pads “slap” “clunk” and also sometimes when on full lock turning. Also on some bumps but not as much compared to low speed. Had my shop and another shop look at them and they’re installed correctly. Currently I don’t have a solution and unfortunately could be a function of the pads itself.
chujk1985557.00
      08-05-2023, 09:00 AM   #4
sleepy75
Drives: Honda Civic
I have the 1500's and haven't noticed this. Very happy with them.
      08-05-2023, 11:33 AM   #5
chujk1985
Same here. It’s quite annoying. Makes me paranoid about suspension issues, but didn’t have any prior to install.
evoi191726.00
      08-05-2023, 11:59 AM   #6
evoi19
evoi19's Avatar
Drives: 2022 G80C
Others here haven’t experienced the issue so I’m at a lost also. For what they cost compared to other pads and little options out there, I expected better. The no squeal and low dust is nice tho lol
chujk1985557.00
      08-05-2023, 11:17 PM   #7
Curious41
Curious41's Avatar
74
Drives: '22 M3C, '23 330e
If it makes you feel better I'm experiencing the same with my OEM front pads now that they've worn down a bit.
      08-05-2023, 11:34 PM   #8
JDUNITNOW
JDUNITNOW's Avatar
Drives: BMW 335I, 750li, X5 G80
I think this is normal if you want to call it that. I have a clicking sound in my rear pad I believe. Also my x5 have Akebono pads and they do the same. I think its a hit or .uss with ordering aftermarket pads.
Formerly Wyndi335I
2009 BMW 750li sold
14 BMW X5
04 BMW X5
11 BMW 335i convertible (sold, sellers market
      08-06-2023, 06:58 AM   #9
beamlord
Drives: 2023 m3c
This.
Please stop panicking at something absolutely normal for performance cars.
Whatever pads you will get, will eventually do that as they wear down, due to very necessary tolerance variation in these calipers to accomodate high performance driving and resulting heat cycling.
      08-06-2023, 08:30 AM   #10
fanofbmwe46
Drives: M3
I have isweep2000 pads and they are perfection. No noise, not one squeak, much much lower dust, and great stopping power.
M4Tejas1090.50
      08-06-2023, 07:48 PM   #11
chujk1985
Originally Posted by beamlord View Post
This.
Not panicking. Just annoying.
      09-19-2023, 03:59 AM   #12
Kevin_The_Clean1
Kevin_The_Clean1's Avatar
Drives: 2020 X3 MC
I've heard there are some shims you can out on the back of the pads to reduce and/or eliminate this sound / noise.
1998 E36 M3 - Totaled
2003 E39 M5 - Gone but not forgotten
2011 E90 335i M-Sport - Daily Driver
2017 F87 M2 - Sold & missed
2020 F97 X3 M Competition - Finally arrived ///
      09-19-2023, 07:31 PM   #13
chujk1985
Link?
      05-27-2024, 11:12 AM   #14
Berzerker
Drives: 2025 X5 M60i, 2019 F87 M2C
2025 BMW X5 M60i  [0.00]
2019 BMW M2  [0.00]
Originally Posted by dz883m View Post
Try squealing.. my isweep 1500 does that and I’ve taken it back to be checked, apparently there’s a rock that may be lodged in. Super annoying. I will look for redstuffs instead.
I think whoever installed them did something wrong. None of us with 1500s (I'm on 2000s now, though) have had any squealing issues ever.
Burrcold6299.00
r33_RGSport13885.50
      05-27-2024, 11:30 AM   #15
Burrcold
Drives: 2024 M3 Comp xDrive
You are switching pads because you got a rock lodged and it's creating noise? Get it out and get back to nice and silent iSweeps!
Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5
r33_RGSport13885.50
      05-27-2024, 12:15 PM   #16
TopJimmy
TopJimmy's Avatar
Drives: 2023 M3 Comp xDrive
The pads come with a small tube of nice thick copper brake lube/grease. On the fronts you want a good thick smear in the slides and where the pistons touch. You want a light smear on any metal edges of the pads that make side contact with the caliper metal. You want a light paintbrushing of grease on the springs where they touch pads.
On the rears you need to grease up U brace real good, that’s on the opposite side of the single piston/EPB. Grease the slides good. Grease the piston medium.
When the grease heats up and sets it sticks the pads to the calipers, but still allows them to slide as needed. That grease is really important to be in the right places to keep things sliding and quiet, but not make a dangerous mess on any braking surface.
That’s been working very well for me… I hope it helps you.
mathys220.00
Sp2pilot234.00
r33_RGSport13885.50
      01-06-2025, 06:25 PM   #17
vrships
Drives: X3 M40i, M4C G82 LCI
I put on iSweep 1500 rear pads on my G82 recently and they are surprisingly clean and also bites much better. The only downside is the occasional rattling/cluncking noise.
I couldn't tell if the car is stationary anything is incorrectly loose. I greased on the pad ears and piston contact area but they seem to be shifting around when the car goes over bumpy areas, or starts to move when brake pedal is released.
The noise is sometimes pretty loud and I almost can feel that "bump" with the noise. It's like a bad ball joints or worn bushing.
I know it's because of the pads moving because there's never a noise if I apply just a slight brake pressure.
Does anyone know where exactly the pads are banging at? Is it latterally with the bracket (I have the stainless steel clips there), or axially with the piston? I am a little worried if it causes any premature wear on the non-consumable parts of the caliper.
      01-08-2025, 10:34 PM   #18
menahanna1011
Drives: 2023 BMW M4
[QUOTE=sleepy75;30372505]I have the 1500's and haven't noticed this. Very happy with them.
I second this!
      01-08-2025, 10:42 PM   #19
cozye
cozye's Avatar
641
Drives: 2024 M3 Comp - 328ix (hers)
6000 miles on these pads and I’ve never noticed any rattle or noise from them at all.
      01-08-2025, 11:28 PM   #20
silvermanor
Drives: M3 comp xdrive
Brakes, like many other parts of a car make noise.
      01-09-2025, 12:17 AM   #21
Drives: S4
If the pads are tight in the clips, they’re not going to move around. In reality, they don’t really need any lubricant on the clip to pad ear contact point. I’ve never used any on any of my cars with similar back brakes and never had issues. The pads don’t need to move/slide in the clips as much as you think. When you let up off the brakes, they only no longer clamp down, they don’t actually back off the rotors as much as some people think. They ride very close to the rotor with only a minuscule gap.
      01-09-2025, 12:48 AM   #22
BIGW0RM
You got my money?
BIGW0RM's Avatar
Drives: Ice Cream Truck
2025 BMW G87 M2  [10.00]
2025 BMW G87 M2  [9.90]
I’ve had two sets of 2000’s (m3 and m2) now and have never heard a sound from them. That said I’ve only had 1-2k miles total on both sets combined. But no sounds heard yet.
2025 G82 M2 /// 2025 X5 40i X
