BMW 3-Series (E90 E92) Forum
Problem: Right Xenon (D1S) bulb MUCH brighter than Left
01-19-2009, 06:21 PM | #1 |
Trance Life
315
Rep 4,706
After taking my car home from the dealer just now, my father drove in front of me and noticed that the right headlight assembly D1S bulb is much brighter than the left one which looks dim. I drove his car and I noticed the same thing...what could cause this? I have no errors on the dash...but I do have Mtec H3 and GP 7500K angel eyes and foglights, as well as LED license plate lights (with built in resistor).
I'm seriously disappointed with the electronics in this car. If it's not one thing it's the next. I had problems like this even before I modded anything. |
01-19-2009, 06:25 PM | #2 |
Rep 2,213
Could it be that in US spec cars the left bulb points downward slightly so as to not blind oncoming traffic. Due to this, when you look at the headlights shining on the car in front of you the right one may seem brighter because it is more directly pointing at the car in front?
Just a guess
Current: 07 335i e90 Previous: 09 Acura TSX PWP Tech Previous: 07 335i e90 with L.E.T. Flash |
01-19-2009, 06:26 PM | #3 | |
Trance Life
315
Rep 4,706
Well, to be fair, when I look at the car head on (as in standing directly in front of each headlight) both Xenons look equally bright, but for some strange reason when I'm at a distance, one looks MUCH brighter than the other. |
01-19-2009, 09:15 PM | #5 |
Trance Life
315
Rep 4,706
01-22-2009, 04:33 PM | #7 |
Trance Life
315
Rep 4,706
Fixed
Turns out there is a knob that you can adjust under the headlight cover. All I did was adjust the knob on my left headlight on the drivers side (which was sitting lower than my right) by turning the knob to the left quite a few times until both bulbs hit my eyes at the same angle.
02-01-2009, 03:33 PM | #9 |
Rep 211
im having the same problem after i got into an accident
|AW E90|Blacklines|Black and White Roundels|LUX 5.0|LED Front Turn Signals|LED Sidemarkers|Silver CF Overlays|Black 328 Emblem|Black Grill|LED Interior|15% Tints|19" Hyper Silver Maya STM's|Black Roof|
02-02-2009, 11:37 AM | #10 |
860
Rep 35,253
02-02-2009, 01:00 PM | #11 |
Mr. Monaco
155
Rep 4,197
I also have this problem. I have a feeling it has something to do with getting hit on that side, but dealer says its normal http://www.e90post.com/forums/showthread.php?t=185120
02-03-2009, 12:38 AM | #12 | |
169
Rep 12,680
Drives: like an asshole
03-02-2009, 06:42 PM | #14 |
169
Rep 12,680
theres a diy look it up under exterior
03-02-2009, 08:55 PM | #16 |
169
Rep 12,680
i have an e92 its under the hood just behind the light its a little circle type knob where u can put a flathead of phillips
03-02-2009, 09:17 PM | #17 |
Watch This!
33
Rep 705
If it is truly dimmer than the other, it is not normal. Like the others have said it sounds like the aim of the "dimmer" light is pointed down more. Go and put your car right up to a wall and see if both lights are at the same level(both hot spots almost side by side). If not then just adjust the aim.... If they are both leveled it could be that you have a bad ballast. To make sure you might swap bulbs from the head lights and see if you still have the same problem. If you notice the problem follows the bulb then obviously you have a faulty bulb... try this and you will find your answer. Good luck!
03-02-2009, 09:20 PM | #18 |
Once upon a time ......
276
Rep 5,048
Drives: 2008 JB E92 - SOLD 5/2010
Had the same problem after a wreck. Light was replaced however, the xenon was not powering on 100%. Turned out the xenon was defective and replaced. No worries now.
03-03-2009, 07:11 PM | #20 | |
Trance Life
315
Rep 4,706
I meant that the passenger side xenon is aiming higher than the left (drivers side), I would like to know a way to raise the angle of the passenger side xenon to match the driver side. but it definitely appears "dimmer". |
03-03-2009, 07:12 PM | #21 |
Trance Life
315
Rep 4,706
03-03-2009, 07:18 PM | #22 |
276
Rep 5,048
Should be 2 turns counter-clockwise to raise the beam level with the passenger side. Flathead screw driver if need be .....
