Technical Sections Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      02-03-2023, 05:54 PM   #1
Blk5er33
Blk5er33's Avatar
24
Drives: G82 M4
Which differential and manual trans fluid to buy?
I have a 6MT '21 M4 with ~15K miles. It has been to 4 track days last year and plan to do 8-10 days this year. Is it worthwhile to change diff and manual trans fluid once per year n a car that is both a daily driver and weekend track car? And if so, which specific fluid is needed?
A search on Turner motorsports yields this: https://www.turnermotorsport.com/BMW...erential-fluid
And bimmerworld recommended this for trans fluid:
https://www.bimmerworld.com/Red-Line...uid-Quart.html
And this for diff:
https://www.bimmerworld.com/Red-Line...Oil-Quart.html
Not sure if this is correct though.
2021 G82 M4 6MT
2022 G07 X7 40i
2017 G30 530i
      02-22-2023, 08:40 AM   #2
doctor_tran
Drives: Alpina B8 4.6 Touring
Also looking for this information.
      02-22-2023, 10:34 AM   #3
doctor_tran
I believe the part numbers are as follows:
BMW MTF-LT-5: 83222239654 (1.6L needed so x2 bottles)
BMW Hypoid Axle Oil G4: 83222447362 (1.5L needed so x3 bottles)
      02-22-2023, 09:19 PM   #4
Blk5er33
Blk5er33's Avatar
24
Drives: G82 M4
Thank you! I have been unsuccessfull in finding it so far.
2021 G82 M4 6MT
2022 G07 X7 40i
2017 G30 530i
      02-23-2023, 09:21 AM   #5
doctor_tran
Seems like an alternative part number for the MT fluid is 83222156969
      09-01-2023, 09:03 PM   #6
doctor_tran
Just did the diff and transmission fluid along with an extra oil change at 5k miles.
Definitely some metal in the diff so worth doing the fluids despite having the diff fluid changed at break in.
It was super easy for both with plenty of room so you don't need any special low profile hex sockets.
somer966.00
      09-02-2023, 10:03 AM   #7
somer
Drives: F10 M5 CP
You think about getting one of those magnetic diff oil drain plugs?
      02-28-2024, 12:04 PM   #8
dimab0
Drives: BMW M4 (G82)
I'm still unclear about how often it is recommended to change the rear diff fluid. I don't see it mentioned in the service manual. My car does have some track days to it and when cold I now hear a clunking noise from rear when turning, until I suspect the fluid warms up. The dealer, of course, thinks it's unrelated to rear diff fluid....
      03-06-2024, 04:10 PM   #9
dimab0
I convinced the dealer to change the rear differential fluid. So far I think that has resolved all of my clunking noises. The car has about 30k miles on it.
      04-04-2024, 09:37 AM   #10
geko29
Drives: 2023 M3 6MT
Diff fluid and Transfer case fluid for xDrive models is indicated at the 5th oil change or 50k miles. Maintenance schedule does not list trans fluid at all.
