bimmerpost/
BMW M2 and 2-Series Coupe
      01-26-2023, 09:56 AM   #1
fredfufufu
Drives: 22 M240i
Fitting 245 front tires with Non-ZTK wheels?
I'm thinking about swapping P0 to PS4S* (ZTK) tires for the upcoming spring/summer. My car is a 22 M240ix with 792M wheels (non-ZTK so OEM tires are 225 front and 255 rear NRF P0).
I checked bmwtirecenters.com for PS4S* tires. I found PS4S BMW Original Tires (BSA) under two specs:
(first of all, hopefully these are the correct tires I'm looking for, if not, please point out)
Supposedly this is for non-ZTK OEM wheels:
225/40R19 | 93Y
255/35R19 | 96Y
And for OEM ZTK wheels:
245/35ZR19 | 93(Y)
255/35ZR19 | 96(Y)
Personally I'd like to go for the latter 245 front without changing wheels, for increasing front grip and better braking efficiency, and (hopefully) more lively rear movements.
I don't know too much about wheel specs and fitness for different tires. Would anyone recommend going for 245 front or should I stick with OEM tire sizes (aka 225 front) because of wheel differences?
      01-26-2023, 02:57 PM   #2
XC3LLR8
2063
Drives: Super73
Rim width range for 245 is 8-9.5". What rim width is your front wheel?
Running too wide of a tire for your wheel could result in sloppy turn-in and possibly more understeer.
      01-26-2023, 03:51 PM   #3
fredfufufu
Drives: 22 M240i
I believe my front wheel is 8’’ , just on the edge according to the range you provided.
More details for anyone who might be interested:
My current setting: (non-ZTK package with non runflat)
225 front 8J X 19” ET27 -> I’m trying to do 245 front, same wheel
255 rear 8.5J X 19” ET40
The 245 front tire comes from ZTK package:
245 front 8.5J X 19” ET25
255 rear 9.5J X 19” ET35
      03-26-2023, 10:43 PM   #4
mmwwhats
Drives: m235 xdrive
I’m in the same boat. I have 245 front and 255 rear winter tires used on my M2 that I’d like to now use on my non-ZTK M240. Would love confirmation that these fit.
      03-27-2023, 07:08 AM   #5
Roadwar
Old Grumpy Guy
Roadwar's Avatar
129
Drives: M240i xDrive
Your front wheels are 8.0" and the rears are 8.5". 245/35/19 in front is fine on an 8.0 rim and is a good diameter match to keep the x drive system happy. I swapped out my stock Pirellis for Michelin Pilot Sport All Season 4s late last fall.
2022 M240iX Brooklyn Grey, Black Sensatec, full Shadowline trim, Premium Pkg.
gone: beloved '74 Mazda RX-3, various V8 Camaros and V8 Mustangs, various other Mazdas including a '10 Mazdaspeed 3, several late model Dodge Chargers including a 6.4 liter R/T. There were others along the way but I didn't love them much.
      03-27-2023, 07:38 AM   #6
Mike_H_
Drives: M240ix, 370z, Highlander
With x drive, the perfect set up would be same diameter front and rear, but within 1% is OK for BMW.
The reason for this is that size differential on AWD puts strain and wear and tear on the system.
I've found Bimmerpost threads (for other models) where owners who claimed they kept tire sizes within range had xdrive failure around 50k miles.
The standard tires for non-ZTK and ZTK is less than 1% (.8 of 1%)
This LINK is a tool that enables you to enter different tire sizes to ensure that you are within that 1% range.
Another consideration, as mentioned by XC3LLR8 earlier, is rim width.
Every tire has an "ideal" rim width but also a range that's acceptable.
The best guide for matching the ideal or acceptable rim width to a tire is Tire Rack, as they list that in the specifications for every tire.
PL4NCK10.50
      10-05-2023, 12:57 PM   #7
fredfufufu
Drives: 22 M240i
Anyone has any updates on the topic? any info will be much appreciated.
      10-05-2023, 02:54 PM   #8
danallxt
danallxt's Avatar
Drives: 2022 M240x, 2007 Honda VFR
Dunno if helpful, but a general rule is to match THREAD width to wheel width.
Another site i saw saying having TREAD width 90-100% of wheel width for best handling response. Keep in mind different tire manufactures and models of tires will have different tread widths for a given tire aspect ratio....not all tires of the same size will have identical tread widths. Tread width is NOT stated on the tire.
      01-19-2024, 04:35 AM   #9
TobyY
TobyY's Avatar
Drives: BMW G42
I am in the same boat. I love how 792M looks ok the car but would also like a wider front tyre. Any update on this will be really appreciated ☺️
      01-19-2024, 07:56 AM   #10
Wasp_Factory
Drives: 2023 M240i xDrive
Yes - you can run 245/35ZR19 on your existing 8" rim.
      01-19-2024, 09:17 PM   #11
TobyY
TobyY's Avatar
Drives: BMW G42
Thanks for the info. Would that also fit the xdrive system without any issue?
      01-22-2024, 01:53 PM   #12
Wasp_Factory
Yes. You need to replicate the ZTK tyre sizing.
245/35/19 front and 255/35/19 rear - this is a 1.06% difference in rolling circumference, which technically is above the 1% that BMW apparently advise.
However, if you can, go for Michelin Pilot Sport 4S* which has some of the Cup2 compound - see link https://www.tyrereviews.com/Article/...t-OE-Tyres.htm
The key point of using the star rated BMW homologated tyre is that if you dig deep enough, you will allegedly find that the rolling circumference of the star marked tyre is very slightly different to the non star rated tyre, which brings the rolling radius within the 1%. Can't verify this myself, but if BMW specify it as OEM, you can't go far wrong.
Hope this helps.
TobyY3.00
      01-26-2024, 02:46 AM   #13
TobyY
TobyY's Avatar
Drives: BMW G42
Just thinking about it today.
Does it solve the problem if I use 245 width both front and back? Then I don't have the xdrive compatibly issue?
      01-26-2024, 05:28 AM   #14
Wasp_Factory
You could - 245s will be fine on an 8.5" rim at the rear, but why wouldn't you just go with 245/255 MPS4S* per my post above? Is it that you just want to be able to rotate the wheels?
      01-26-2024, 03:17 PM   #15
TobyY
TobyY's Avatar
Drives: BMW G42
Hard to get PS4S*. in Australia. Was just thinking about all the options I have. Thanks mate. Your reply is really helpful. I now know I have two options to change my tyres with 792M.
      02-17-2024, 01:38 PM   #16
M240iWhizz
Drives: M240i G42
This tool doesn't take into account rim width used so there's a margin of error. Does anyone know a tool that takes rim width and tire spec into account?
      02-19-2024, 04:56 PM   #17
ap2x
ap2x's Avatar
Drives: '23 M240xi
Anyone know if I need 245/35ZR19 or 245/40ZR19 Michelin ps4s on my 19x8 OEM square wheel setup? Which aspect ratio is better or do both work? Looking to do a square setup
      02-20-2024, 02:54 PM   #18
BG42
Drives: M240ix
run the 35 star tires.
ap2x21.00
g87
