01-23-2023, 09:50 AM | #1 |
d[-_-]b
487
Rep 968
826M cleaning?
Okay, not much of a car washer but want to keep the G80 pristine.
Did the Garry Dean method for my first wash and the car is looking damn good. Went to clean the wheels and gave up ( microfiber towel with ONR ). So many nooks and crannies... What tools are you guys using to clean these? |
01-23-2023, 10:21 AM | #2 |
Rep 374
This is the best tool IMHO (I’ve tried a lot of them)
https://a.co/d/inoUVsv Many coats of ceramic are necessary though (just cheap self applied stuff works wonders). The best tool is no tool if you can get a hose to work (lots of ceramic coat is necessary for this though)
2023 G80 6MT | Tartufo Full
FDfranklin487.00 |
01-23-2023, 10:29 AM | #3 |
Rep 64
Drives: 2023 BMW M3 Comp
I would not use ONR waterless to clean wheels. Brake dust is extremely abrasive and it gunks up microfiber clothes very quickly.
I recommend using a non-acid based wheel cleaner with iron contaminant removal properties. Then rinse off and use snow foam to lubricate the wheel while you use a wheel woolie or two to clean the wheel properly. Rinse and then use a microfiber for finishing. Cleaning wheels properly is a huge pain and these wheels are on the harder side. Ceramic coating will help considerably but it won’t allow for 100% contactless washing, in my experience. |
FDfranklin487.00 |
01-23-2023, 10:54 AM | #4 | |
d[-_-]b
487
Rep 968
01-23-2023, 10:56 AM | #5 | |
d[-_-]b
487
Rep 968
Have any recommendations for some of those products? |
01-23-2023, 11:27 AM | #6 |
Rep 687
Links to CG for illustration only, replace with your vendor of choice
Wheel brush for 'barrels' https://www.chemicalguys.com/red-roc...%20Suggestions various size wheel woolies for wider areas https://www.chemicalguys.com/wheel-w...Best%20Sellers wheel wash mitts for everything else https://www.griotsgarage.com/microfi...itts-set-of-2/ plus whatever wheel/wheel and tire cleaner of your choice. wish I would have sprung for CCBs sometimes, it's a bear man Last edited by astroricardo; 01-23-2023 at 11:48 AM.. |
FDfranklin487.00 |
01-23-2023, 11:28 AM | #7 |
Rep 64
FDfranklin487.00 MannyS361.50 |
