bimmerpost/
BMW M2 and 2-Series Coupe
      01-19-2023, 02:10 PM   #1
Expert@ApexWheels
Expert@ApexWheels's Avatar
3530
Drives: M3
APEX G42 2 Series Test Fitment: 19x9.5 ET25 square VS-5RS
As many of you know already, a few intrepid G42 customers have opted to run our 19x9.5 ET25 wheels square as an aggressive rotatable fitment. Stradale Design documented their test of this setup on their G42 on the following thread: https://g42.bimmerpost.com/forums/sh....php?t=1978825
While this was a fantastic initial impression of what this fitment was like on the 2 series, we had always planned to test this setup in-house as well. Since we needed scans of the larger ZTK brake calipers for another project, we dovetailed this testfitment in with an office visit used to collect brake data as well. Luckily enome was able to stop by our office with his ZTK-equipped G42 to help with this test fitment. His otherwise stock G42 was the perfect platform on which to test these wider wheels to compare against Stradale’s lowered example.
All of the final photoshoot photography featured the following specs.
G42 Specifications:
Suspension & Alignment: Stock
Spacers: None
Wheels: VS-5RS in Satin Bronze
Front & Rear: 19x9.5 ET25
Tires: Falken Azenis RT660
Front & Rear: 265/35-19
Front:
Overall the front fitment looks great, even at the stock ride height and with the stock alignment. We’ll touch on the tire model later but this is one of the wider 265/35-19 options on the market. The fitment is aggressive and might poke beyond the stock fenders of a non-ZTK car, especially with wider tire models. It is an extremely flush fitment which can be especially important if you need to run spacers. Bonus points for those who spot the F87 M2 CS Racing lurking in the background waiting for its time to shine…
Front Suspension: Strut Clearance
The photo above shows the strut clearances between the wheel and tire and the front strut assembly. The wide RT660 sits extremely close to the strut body. No tire witness marks or audible rubbing were noted with this fitment during the photoshoot but if driven aggressively on the track or street, a 3mm spacer would be a great addition to prevent the tire from contacting the strut when the tire sidewall flexes and deforms.
Above the tire, there is room between the tire and the OE spring perch. Aftermarket coilovers or HAS (height adjustable spring) kits that limit inner clearance because of a lower spring perch that sits further down than the OE configuration will need a wider (5-12mm) front spacer and additional negative camber to run this setup.
Front Brake Clearances: ZTK and More
Clearances were tight between the front ZTK calipers and the VS-5RS spokes, but they did clear without issue. There is plenty of clearance between the barrel of the wheel and the calipers which is where road debris and gravel are more likely to sit momentarily and get caught between the components. Overall the brake clearances for the 374mm ZTK brakes are acceptable with the VS-5RS but a 3mm front spacer would help build back that spoke-side margin if you’re concerned about road debris. We tested the VS-5RS and SM-10 19x9.5 ET25 wheel designs against these ZTK brakes, the 348mm front “MSport” brakes, and the base 230i brakes along with all applicable rear brakes and these wheels cleared.
Rear:
The rear fitment has less overall notes. Easy brake clearance and a ton of inner clearance for these wheels moved our focus to the fender clearance around the upper portion of the tire. Overall the fitment is once again quite flush especially with the wide RT660 tires. No rubbing was noted during our testfit, but the car was not driven hard. Extreme suspension compression and tire flex on track might lead to fender rubbing with wider tires which could be dialed out via alignment adjustment. The ZTK flares help with visual poke but aren’t a significant benefit to an otherwise unmodified car.
Tire Notes:
Falken RT660s are an excellent extreme-performance tire option that performs well on track. They also run quite wide. Per Tire Rack, the RT660s in the 265/35-19 size showcased here run 10.9” wide for their section width which is generally the widest point of the tire sidewall. A Michelin Pilot Sport 4s in the same size has a 10.6” section width. When moving further down to the contact patch, the RT660 has a massive 9.8” tread width while the PS4S has a 9.3” tread width. This is the portion of the tire that contacts the road, but it's also the part of the tire we care most about when it comes to suspension and fender clearances as it's this portion of the tire that is closest to these pain points. Both of these tires were measured on a 9.5” wide wheel.
The RT660s are wider at every point but are especially big where it matters most for us. The Michelins are a fairly wide tire already but they don’t come close to the RT660. I often get asked by customers what size of tire I recommend. It's a hard question to answer because of variances like this within the same listed size by manufacturers trying to eke out more performance or chase various characteristics. 265/35s make sense here for a track performance setup but again the width and fitment will vary depending on the tire you select.
Alternate sizes:
While 265/30-19s could be used front and rear for a slightly easier fit, the tire model availability is far better in 265/35-19. A solid selection of track tires is available in this size making it the obvious choice for someone that tracks their 2 series. 255/35-19 has even better availability than 265 although most of the tires in this size are street oriented. You can run 255/35-19 for street tires on these wheels, but if you wanted an easy bolt-on fitment, the 255/35-19 could also be run on our 19x9 ET25 square fitment. As always, additional fitments can be found on our guide here.
Going Lower + Track Alignment: Featuring Stradale Design
As we mentioned already, Stradale Design is running the same setup on their G42 build as documented in their thread. At this point, most of you will have seen their thread already, but here are some shots of their car on these wheels with Falken RT660s lowered on MSS springs:
Once they dialed in some camber, these wheels tucked a bit more than is showcased here. In-depth photos can be found on their thread but we wanted to take advantage of this rare opportunity to compare and contrast a stock car with a lowered car. You can see some of the additional static camber gained from just from lowering the car at work helping to tuck the upper edge of the tire in despite the distance from the fender to the tire decreasing at the same time.
Aftermarket camber plates are going to be the best option to dial in additional negative camber up front from a wheel and tire fitment perspective as these will pull the top of the strut inward and improve fender clearance at the upper edge. Availability for plates like this is likely thin right now but as these cars get older more options should come onto the market.
Final Thoughts:
Overall these wheels work surprisingly well even on a stock car. Narrower street-oriented summer tires or all seasons would make essentially all aspects of the fitment slightly easier for street customers looking for a rotatable square fitment but this setup truly shines with aggressive track tires. We’ve been working on and building wheels for the 1 and 2 series chassis for years with the E82 and F2X 1 and 2 series and it's great to see aggressive G42 fitments take shape. Owners right now may not be as interested in fitments that require some modifications but we hope this thread helps to give anyone interested in a rotatable square fitment for the track a great new option. These are also the most concave wheels available for the G42 2 series in our lines currently with an unmistakably deep face profile.
While this thread showcases our Forged VS-5RS, all the same notes apply to our Flow Formed SM-10 as well giving you multiple options at different price points. I’ve been a big fan of our Flow Formed wheels for a long time and while the forged wheels are great, if you need multiple sets to support a track program or want to save for suspension or HPDE fees, the SM-10s are a great option for any budget.
Even if you aren’t considering APEX wheels, we hope this showcase helps with notes about the offset and fitment on the G42. If you are considering our wheels, we’ve added this fitment to our guides and both of these wheels will be going on our G42 shop-by-vehicle page shortly.
A huge thanks goes out to our volunteer enome for giving up your time and lending us your car for a few hours. We hope to see you on APEX wheels again soon. Another thanks goes out to Stradale Design for picking up a set and letting us use your photos.
Let us know what you think about this fitment and if you have any questions!
-Tom and the APEX team
VS-5RS /// SM-10 /// Chassis Specific Guide
Appreciate 20
XC3LLR82062.50
Coconut751.00
enome19.50
Red_sir131.50
shonseb148.50
M3 boi3211.00
6speed_M23633.50
T0RM3NT3642.00
SVR514.50
PeterWT253.50
hooked190.00
meko178.50
2srsman68.00
Sonic RR118.50
VegasG42373.50
      01-19-2023, 03:11 PM   #2
XC3LLR8
2063
Drives: Super73
Looks amazing! Any plans to bring out Motorsport Gold for this wheel? Choosing between that and Bronze could be a tough call.
      01-19-2023, 06:35 PM   #3
Expert@ApexWheels
3530
Drives: M3
Yes indeed. Motorsport Gold will be coming in the future, but won't arrive for a while. Bronze on the other hand is already here as you've seen haha. April-ish eta on the Gold depending on how things shake out.
-Tom
XC3LLR82062.50
Sonic RR118.50
      01-20-2023, 09:49 AM   #4
shonseb
Drives: '23 240ix, gone: '14 Audi RS5
2023 m240ix  [0.00]
Awesome write up, so much useful info! Thanks!
      01-20-2023, 09:57 AM   #5
XC3LLR8
2063
Drives: Super73
Tom - which color do you believe will hide brake dust better, Satin Bronze or Motorsport Gold? I also wonder if Motorsport Gold will look a little “soft”, aka: feminine, on Brooklyn Grey?
      01-20-2023, 12:14 PM   #6
Expert@ApexWheels
3530
Drives: M3
It depends on the pad, but probably Satin Bronze for brake dust. Neither color are really optimal for hiding brake dust though. If that is your goal, Anthracite is really the best choice.
Motorsport Gold: I'm certainly hoping to have more photos from the G80 customers shortly, but there's always going to be an element of personal preference. It looks great on the Porsche we shot and I should have several BMWs eventually to give you a better idea of how it looks on-car.
-Tom
XC3LLR82062.50
      01-20-2023, 01:24 PM   #7
XC3LLR8
2063
Drives: Super73
-Tom
Yes, that Porsche looks amazing! But it's obviously a different category of car and there's really no color combo that will make those look bad.
I'm so close to pulling the plug on the Supra Satin Bronze wheels; it just sorta sucks having more patience in my older years than my younger ones. lol
      01-20-2023, 07:24 PM   #8
zero21
Drives: G87 sold
Absolutely does not work on this car IMO.
Teutonic2709.00
      01-20-2023, 07:35 PM   #9
Maverik259
Maverik259's Avatar
Drives: F90 M5 / F15 50i
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Wheels look good. Don’t think those studs are quite long enough though. Lmao
'07 Yamaha R1 (sold)
'06 C55 AMG (sold)
‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe
'14 X5 50i (wife’s now)
      01-20-2023, 09:52 PM   #10
rwemersonrw
rwemersonrw's Avatar
535
Drives: BMW M2 Competition, Acura TSX
Loving that CSR in the background haha
      01-20-2023, 10:29 PM   #11
ryo-
Drives: '22 MWM M240i
I'm definitely waiting for gold to put on my white 240. should look pretty good
      01-21-2023, 08:06 AM   #12
G30 B58
Pace Car Driver
1548
Drives: '22 AW G30 B58 M-Sport
Proper. Nicely done. APEX wheels are SO popular amongst our BMW racers here in NASA NE.
Can you test fit a G30 maybe?
      01-21-2023, 08:34 AM   #13
hokejka
Drives: Past: 135i 6mt
Any more new pics of staggered setups on different xdrive cars?
Plans for sm10 and arc8?
Nice work guys!
      01-21-2023, 11:15 AM   #14
XC3LLR8
2063
Drives: Super73
If you're referring to the Brooklyn Grey, I think it works just like the Tacora Red leather works. Sure, black interior and black wheels are always a safe bet, just like one would find on a Camry.
      01-21-2023, 12:01 PM   #15
zero21
Drives: G87 sold
Was referring to the race wheels on a cushy road car. The cars exterior styling just doesn't jive with wheels and tires like that. Not a performance critique, strictly talking "looks" here.
Teutonic2709.00
      01-21-2023, 12:32 PM   #16
XC3LLR8
2063
Drives: Super73
I find the wheels gives the "cushy road car" a more aggressive performance look. Afterall, it's a cushy road car that easily does sub 3.5 0-60 with a few basic mods. And with less unsprung weight, it only makes things more cushy.
      01-21-2023, 01:01 PM   #17
Frosty
Frosty's Avatar
780
Drives: M240i - 2021 - 6MT -
This looks fantastic
M240i Coupe (6MT) (2021: 6/2021 build )
Accord Coupe (6MT) (2017)
335i Coupe (6MT) (2007: 9/06 build SOLD 8/2016)
Prelude (5MT) (1995)
      01-21-2023, 04:20 PM   #18
Jack@AUTOID
Jack@AUTOID's Avatar
1773
Drives: G87 M2, G42 M240i, F87 M2, E36
This is epic info guys. Thanks so much for sharing!
      01-22-2023, 08:36 AM   #19
abc
Drives: 325
yummy!
      01-22-2023, 12:59 PM   #20
zero21
Drives: G87 sold
I explicitly stated my post had nothing to do with performance, and everything about being a middle-of-the-road sporty vehicle, wearing race wheels and tires and nothing else on the exterior that matches.
And you just couldn't let it be. Just bc you own one doesn't mean it's an insult and you had to keyboard warrior.
      01-22-2023, 05:06 PM   #21
XC3LLR8
2063
Drives: Super73
Alrighty
Mike_H_264.50
      01-23-2023, 11:58 AM   #22
Expert@ApexWheels
3530
Drives: M3
Glad to hear we’re making an impact in NASA. Hopefully we’ll see more of our wheels out on track in your region once it thaws out!
G30: We’ve actually already testfit our same g20 and G42 fitments on a G30. I’ve been tied up working on other projects, fitments and such but most of our 3 series wheels are carryover direct fit options for a G30:
This car is running our 19x9 ET25 front and 19x10 ET38 rear wheel set (VS-5RS) with 255/35-19 front and 275/35-19 rear tires. This tire selection is not ideal for the larger 5 series and I’d swap out the front tire for a 245/40-19 especially if the car is xDrive, but the wheels fit really well on a car with stock suspension:
We also tested the square 19x9.5 ET25 fitment. It’s a bit more aggressive on the outer edge than the Staggered fitment, but it can certainly work. Tires were 265/35-19.
Edit: 1 caveat here: we haven't brought in and scanned every G30 brake kit yet. This car was the first of our initial tests so if the car is running really massive brakes, small spacers might be needed. There was quite a bit of room for these brakes.
Nice work guys!
Thanks! I’m not sure if you mean other xDrive cars ie chassis other than the G42 or just other xDrive G42 2 series. Most of our 2 series photos can be found here: https://g42.bimmerpost.com/forums/sh....php?t=1956884
G20 3 series: https://g20.bimmerpost.com/forums/sh...1#post29391031
Some of the sets feature non-xDrive tire sizes, but we have recommendations for xDrive options on the associated fitment guides. Each fitment you see in the 5x112 VS-5RS in the non-M sizing is also available in our SM-10 design. ARC-8 isn’t something we offer yet for the new 5x112 PCD, but we’ll look into it as we work on expanding flow-formed options in the future.
-Tom
G30 B581548.00
g87
