01-11-2023, 12:24 AM | #1 |
Rep 18
Catback install help
I am trying to install a full catback, do I need to lift the car on 4 jack stands or can I just lift the front and its enough space? thanks for the help!
01-11-2023, 06:49 AM | #2 | |
Rep 263
4 jack stands would be optimal
YouTube: OEM+ IG: @_oem3_
2021 BMW M3, 2021 Porsche Macan S, 2022 VW atlas cross sport, 2000 BMW 528i, 1987 BMW 635CSi, 2024 Porsche Carerra S (April delivery) |
01-11-2023, 09:57 AM | #3 |
Rep 788
Someone correct me but I think you can lift the front to loosen the downpipe to midpipe bolts then lower the car and then raise the rear and pull everything off if you want to avoid 4 jacks.
01-13-2023, 04:23 PM | #4 | |
Rep 18
01-14-2023, 07:53 AM | #5 | |
Rep 263
Some people use front ramps and rear Jack stands too. That could be a better too
01-14-2023, 02:11 PM | #6 |
Rep 456
Drives: G80 M3 Competition
Do it right the first time and use all four or quickjack.
01-14-2023, 03:28 PM | #7 |
Rep 18
Sadly my quickjack I bought 3 years ago won’t fit this car because they decided to make the jack points so far apart. What do you mean by do it right? Will there be issues doing front then rear instead of at the same time?
01-14-2023, 03:31 PM | #8 | |
Rep 456
I had to drop the whole thing level and then slip it out. See sawing the exhaust out is going to be pia. |
01-14-2023, 06:23 PM | #9 |
Rep 2,030
I’ve done all of my exhaust work with 2 jack stands and ramps.
I back the car onto the ramps and put the front up on the 2 jackstands. Ramps are pretty cheap. |
01-15-2023, 12:04 AM | #10 |
Rep 750
Drives: 22 M4c vert
I've done a few cars with the "lift one axle, lower, lift the other axle" method, but I would NOT suggest it on this car. I did mine with the rear on ramps / front on jackstands. Given the weight of the stock exhaust / it being one piece, not having the full run of the car would be challenging. Additionally, doing the final tightening / tweaking for fit would also be really hard, as this again requires the full run of the length of the car. Get it up on all 4. - once you do, this is a pretty easy install.
