      12-25-2022, 12:21 AM   #1
tsardar
Drives: G80 Comp xDrive, 2022 X5 40i
Reverse Light Brightness
So I might be blind, but the stock reverse lights just don't cut it for me. When I'm backing up to my garage at night, the camera image is pretty dark and borderline unusable.
I've been curious about the GTS style lights as well and these from Euro Klasse look to have a brighter reverse light.
https://euroklasse.com/products/bmw-...=jC3rKtB2vk6SD
Thoughts? Opinions? Am I just crazy?
Anyone have any experience with Kies vs Euro Klasse?
      12-25-2022, 11:06 AM   #2
montrokc
montrokc's Avatar
Drives: 2023 IOMG G80 6MT
https://euroklasse.com/products/bmw-g80-g82-m3-m4-g20-g22-gts-taillights?_pos=4&_sid=e0ec538cb&_ss=r&ref=jC3rKtB 2vk6SD
Have you played with the brightness settings for the rear view camera?
      12-26-2022, 05:47 PM   #3
hotsauce_bukkake
Drives: 2023 G80 6MT BG/FR
I have this same issue and cannot for the life of me find brightness settings for the camera in iDrive 8.
MunkyTool580.00
      12-26-2022, 07:21 PM   #4
Murf
Drives: 2021 G80 M3C - Dravit Grey
Can you just replace the bulb with something brighter?
      12-27-2022, 02:41 PM   #5
tsardar
Nope. They're LED boards inside the tail lights.
      12-27-2022, 02:44 PM   #6
tsardar
I have. The brightness settings only help the image on screen. My issue is that there is not enough light output for the camera. So even if the image on the screen is brighter, the image the camera is getting will be unaffected.
      12-27-2022, 08:28 PM   #7
montrokc
montrokc's Avatar
There should be a setting to modify the exposure of the lens
      12-27-2022, 08:40 PM   #8
forza1976
forza1976's Avatar
2022 BMW M3X  [9.50]
Found the mod for you OP. Just put them on the rear 🤣
FISH225511.00
Fugazii245.00
SpinalTap131.00
Sonic RR168.00
USMC G2159.50
      12-27-2022, 11:41 PM   #9
MunkyTool
MunkyTool's Avatar
Drives: 2023 G80 Comp X-Drive
Same. Can’t find reverse camera adjustment settings anywhere in iD8
      01-08-2023, 11:06 AM   #10
ibmc
Drives: 22 M4 Comp G82 RWD
Not sure if this is related, but I had a similar issue with my 2018 M4 Comp when I first got it brand new. Backup video was scary as I simply could not see clearly. After a couple trips to the dealer, it turned out that the white color of the car and bright plate light was interfering with the camera. They added a strip of tint to the plate light to dim it a bit, and that fixed the issue. Hope this helps.
SpinalTap131.00
      11-16-2024, 12:16 AM   #11
2015-328i
2015-328i's Avatar
Drives: 2025 Bmw M3 Comp xDrive
Where is this setting for the camera?
      11-28-2024, 01:39 AM   #12
stbm5
Drives: 2018 M5 DG
I agree this is an issue. There’s no setting to increase brightness of light, you just have to hope radar keeps you from bumping into something.
