11-10-2022, 01:34 PM | #1 |
![]() 3168
Rep 22,698
Posts ![]() |
▀▄ eas | Evolution Racewerks Competition Midpipe G8x BMW M3/M4 - Just Released
![]() Featured on BIMMERPOST.com Just Released is the NEW anticipated Evolution Racewerks Competition midpipes for G80/82. Now Available and in stock. Evolution Racewerks Competition Series Mid Pipes are constructed out of 100% 304 grade stainless steel and utilize mandrel bent piping. They are 100% TIG welded by in house fabricators and built in the USA. Exhaust flanges are billet stainless steel that is computer CNC precision cut. The factory bracket hanger is retained. The bracket hanger is laser cut and TIG welded using stainless steel rods. High quality exhaust clamps are used to joint the mid pipes to the rear exhaust muffler section. Competition Series Mid Pipes feature a "H" style crossover. The crossover is used to equalize the pressure between the left and right exhaust pipes. This helps promote better flow and reduce droning. Through testing between an "X" and "H" crossover design, it was found the "H" crossover design helped reduce droning and improving low end torque compared to the "X" crossover design. Thus, incorporated an "H" crossover instead of a "X" crossover. At the end of the day, this is a BMW and do not want droning. The factory mid pipe also incorporates a "H" crossover design so figured BMW also felt the "H" design was the ideal solution for this application. Competition Series Mid Pipes are designed to fit perfectly with either the factory exhaust system or your aftermarket exhaust system designed for compatibility to the factory mid pipes. Available in a 1 piece welded version for local installs or a 3 piece version for shipping. ![]() ![]() Features - Higher Initial Torque Curve. Torque curve hits faster and higher and longer. - Better throttle response and faster turbo spool up times - Deletes factory resonators for improved flow - Mandrel Bent 3" (80mm) piping. Smooth transition through the exhaust system. - 100% Stainless Steel Construction - 100% TIG welded for better quality welds - Precision CNC machined Flanges - Brushed Finish - Compatible with the factory or aftermarket exhaust systems - Track tested durability - Includes all hardware for complete installation - Limited Lifetime Warranty
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by kevin @ eas; 12-07-2022 at 12:03 PM.. |
11-10-2022, 03:51 PM | #4 | |
![]() 3168
Rep 22,698
Posts ![]() |
Not yet, we will be sure to update this thread once installed with a video. Just unboxed one at our shop and quality is top notch. ![]() ![]() ![]() ![]() ![]()
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by kevin @ eas; 12-07-2022 at 12:02 PM.. |
11-10-2022, 06:23 PM | #8 |
![]() 451
Rep 1,118
I wonder if this saves much weight?
russell21148.50 Dinan_Engineering4249.50 |
11-10-2022, 07:11 PM | #9 |
![]() ![]() ![]() ![]() ![]() 1471
Rep 726
I imagine it will sound similar to the x3m midpipe. Maybe Ben can chime in.
r33_RGSport14203.00 Dinan_Engineering4249.50 |
11-11-2022, 05:35 AM | #10 |
![]() 2150
Rep 2,100
How is this even possible? Your going to release a new item on the exhaust and have no sound clip before? WTF is going on? Lol. Hey guys, I have a software for your cars. You will be able to smoke the Tesla plaids and it gives you 35 miles per gallon. It's 599 installed. But, if you order within 5 minutes we will send you 2 for that price. Just pay additional shipping and processing. We don't have it on any of our cars but we will get around to it. In the mean time, send us your money🤡🤡🤡
11-11-2022, 06:47 AM | #11 |
![]() 2905
Rep 1,526
Drives: 2025 G82 MT, 2022 X7 40i
This looks really good. I guess there's no way to ship an uncut system to Canada is there?
2025 skyscraper grey manual G82. Instagram: 6SPDG82
11-11-2022, 11:23 AM | #12 |
![]() ![]() ![]() 22100
Rep 14,945
Drives: G87 M2
Garage List 2025 BMW M2 [9.67]
2022 G82 M4C X-Drive [9.78] 2018 F80 M3 CS [9.86] 2018 BMW i3 REx [4.87] 2015 BMW i3 REx [3.00] 2016 BMW F80 M3 [7.63] 2016 BMW F30 340i ZTR [10.00] 2013 BMW F30 328i [8.50] 2006 Audi S4 25Quattro [7.33] |
Interesting! Need a Guinea Pig?!
![]() 2025 G87 ///M2 LCI - KWHAS, Millway Motorsport Uniball Camber Plates, SPL Adjustable Tie Rods, Unit17 OEM++ Rear Spoiler, Turner Motorsports Front Splitter Previous: 2022 G82 M4 Comp X-Drive • 2018 F80 M3 CS • 2016 F80 M3 |
11-11-2022, 12:22 PM | #13 | |
![]() 9058
Rep 19,292
Posts ![]()
We can compare once we have an install through the doors, the pieces literally just arrived 2 days ago.
Looks like we got our guy, I'll shoot you over a PM.
11-12-2022, 09:32 AM | #15 |
![]() 1299
Rep 1,283
Would like your comparison to the PSI if you have run that on your test bed. I have the ER on my X3M and it's definitely louder cold start than my G82 with PSI. Maybe due to its single pipe design?
/nm. I don't know why I thought the ER pipe for the X3M was a single pipe, and I installed the thing ![]() Last edited by Soylent; 11-12-2022 at 09:35 PM.. |
r33_RGSport14203.00 |
11-12-2022, 03:54 PM | #16 | |
![]() 9058
Rep 19,292
Posts ![]()
PSI/Remus combo is in our YouTube channel, we'll get a clip recorded on the ER midpipe gets installed - preferably with stock mufflers.
11-13-2022, 02:40 AM | #18 |
![]() ![]() 14571
Rep 7,285
Drives: 2024 Model S Plaid
Wake me when the G8X sounds like this. And this is why you can't post a XM video and assume it's going to sound the same on the G8X. It makes zero sense how bad our cars sound, no matter what you do to it. I would have no problem spending $10k on an exhaust, if our cars sounded like this.
SOLD: 2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou ![]() Last edited by Limegrntaln; 11-13-2022 at 02:50 AM.. |
11-13-2022, 07:28 AM | #19 |
![]() ![]() ![]() 3537
Rep 6,627
Features
- Higher Initial Torque Curve. Torque curve hits faster and higher and longer. That’s what she said! ![]() |
11-14-2022, 09:57 PM | #20 |
![]() 9058
Rep 19,292
Posts ![]()
We've got ER midpipes in stock when you're ready.
G-Mann487.50 |
12-07-2022, 11:58 AM | #21 |
![]() 9058
Rep 19,292
Posts ![]()
Pictures from a recent installation of the ER midpipe, also clearly showing the cut points on the stock exhaust as some had questions where the OEM cut points were located.
6SPDG822905.00 |
12-07-2022, 12:00 PM | #22 |
![]() 9058
Rep 19,292
Posts ![]()
Quick sound test of ER Midpipe installed:
We have stocking inventory of ER midpipes, no waiting.
ny2nj214.50 |
