10-05-2022, 03:20 PM | #1 |
2063
Rep 1,559
BEWARE of Chemical Guys Water Spot Remover
Ordered the Chemical Guys Water Spot Remover to clean up…well, the obvious. I read the instructions and followed them carefully before beginning and made sure it didn't mention anything about not using on mirrors, as that's where I was beginning.
Thankfully I only did one mirror (passenger side) before moving on. For some reason it left a heavy haze on the inner-third of the mirror. I tried getting it off with water, then water and soap, and then vinegar, all with no luck. I ended up calling Chemical Guys and told the employee what happened and he said, "Yeah, there are some outside mirrors it shouldn't be used on." I politely stated it would've been nice if the instructions had stated that. He put me on hold to speak with someone else and came back suggesting to reapply it and quickly neutralize it with water and if that doesn't work try wax cleaner. I did the reapply, neutralized it, and no change. I then got out the Meguiar's Ultimate Compound and rubbed it in with a soft cloth, followed up with Meguiar's Mirror Glaze and that FINALLY did the trick. Now I'm not comfortable using the Chemical Guys Heavy Duty Water Spot Remover anywhere else on the car, but their Synthetic Quick Detailer has been great. |
10-05-2022, 04:04 PM | #2 |
Rep 122
That is interesting that it etched the mirror's glass surface.
Knowing that it can potentially etch surface, I'd approach with caution on painted surfaces as well. IMO, polishing glass surface is usually good enough to remove water spots. But in general, how I think you should fix the blemishes are going gradually from weaker stuff to stronger stuff until you see an effect (wax -> compound -> heavy duty stuff). |
10-05-2022, 04:26 PM | #3 | |
2063
Rep 1,559
Prior to finally getting it fixed with the Meguiar's I was on hold with the BMW parts department thinking I would have to replace the mirror, but they were backed-up and I finally hung-up. That's when I tried the Meguiar's only because it was already in the garage cabinet. Thankfully it worked! |
10-05-2022, 04:39 PM | #4 |
2063
Rep 1,559
Now that's it's been about an hour since using the compound I'm seeing maybe 20% of the haze still there - is it slowly creeping back?
I've read where people have had luck using a small polishing wheel, so it makes me feel better knowing that while it may not be 100%, it can at least get there...eventually. |
10-05-2022, 04:46 PM | #5 | |
Rep 122
XC3LLR82062.50 |
10-05-2022, 05:13 PM | #6 |
Rep 269
Most chemical guys products are pretty good. I didn't like their glass cleaner - it was similar in that it left a heavy haze that was difficult to get off.
Water spot removers can be pretty intense so I wish you the best of luck. The goal is to make life easier and some of these are just too intense. =\ |
10-05-2022, 06:13 PM | #7 |
Rep 9
I had a look at the SDS. Chemical Guys are surprisingly transparent about their formulations. No surprise why it etched your glass - the main ingredient is ammonia bifluoride which produces HF the most common etchant for SiO2 surfaces such as glass.
I'm actually surprised they're able to sell this as a DIY product. HF down the drain is a big nono, |
10-05-2022, 06:50 PM | #8 | |
Rep 487
10-05-2022, 07:16 PM | #9 |
Rep 355
what's a good product to remove water spots (stains?) on the glass black trim? I was washing my car today and noticed that the markings don't come off at all, even with hard rubbing w/ soap and detailer spray.
10-05-2022, 07:20 PM | #10 | |
2063
Rep 1,559
I'm still rubbing compound on that one mirror as the haze (a little more diminished each time) keeps coming back. So glad I didn't let it touch anything else. Really surprised at how many good reviews it has. |
10-05-2022, 07:22 PM | #11 |
Rep 9
Add a tiny bit of acid such as vinegar to your usual car wash soap. Water spots are usually just leftover soap and minerals from washing or use. Add it to the rinse fluid for good measure.
10-05-2022, 07:25 PM | #12 | |
Rep 9
For your problem - I'd use something silicone based or labeled as a ceramic. The SiO2 will restore the ectches in the mirror and then you should just polish until restored. |
XC3LLR82062.50 |
10-05-2022, 07:29 PM | #13 |
2063
Rep 1,559
Are you suggesting a ceramic-based wax? Any specific name/brand you recommend?
10-05-2022, 07:33 PM | #14 | |
Rep 487
https://www.griotsgarage.com/ceramic-all-in-one-wax/ https://www.griotsgarage.com/ceramic-3-in-1-wax/ |
10-05-2022, 07:42 PM | #15 | |
Rep 487
https://www.griotsgarage.com/one-ste...ant-16-ounces/ |
ryo-250.50 |
10-06-2022, 12:09 AM | #18 | |
Rep 122
