11-06-2022, 12:54 PM | #2 | |
Rep 1,057
I have a '22 F97 and will be installing a Match 10 DSP with its plug-in harness (match pp-bmw 1.9ram-hk). This harness allows to wire the new DSP/amp in series with the OEM RAM/Booster. I want to add a subwoofer to this new setup. Will your harness allow me to do this without interfering with the new setup? Since the Match amp and its harness tap into the main amp, I dont think it will but want to check with you. Let me know what you think. Thanks |
11-07-2022, 04:08 PM | #5 | |
Builder / Tinkerer
74
Rep 83
Drives: '21 X3 m40i Pre-LCI
For example: https://www.jlaudio.com/collections/...-systems-93335 You can put that under the floor of the trunk, wire the amp built into that sub box to your match amp using the Line Out and Remote Out to let the amp know to turn on. |
