08-22-2022, 09:26 PM | #1 |
Rep 748
Winter wheels: 19x9.5j ET20 square
I am following up on a discussion in this thread and thought it was worthy of it's own thread. It kind'a got buried and was off topic in that thread.
https://g80.bimmerpost.com/forums/sh...1933294&page=3 Does anyone run 19x9.5j ET20 square wheels with 275/35R19 tires? It has been suggested that will not work. But no one has specifically said why. I think they will work. Exhibit A: - 826M front wheel is 19x9.5j ET20 with OEM 275/35R19 tires. Exhibit B: - 829M rear wheel is 19x9.5j ET20 with OEM 275/35R19 tires. Isn't that proof of the concept working? What am I missing here? Seriously, am I missing something? Because I am about ready to pull the trigger on some awesome wheels and don't want to be disappointed the first week of December if they don't fit. (I'm sure I'll get the new wheels before then, but nothing would be worse than everything being out of stock and me having $4K tied up in a winter set that doesn't work....)
BMW M3 Competition xDrive, Dravit Grey over Tartufo
08-22-2022, 09:40 PM | #2 |
Rep 1,241
Just for clarification, is your choice between two different OEM wheels, or are you going aftermarket wheels?
3/19/22: Deposit placed on MY2023 Skyscraper Grey M3 Comp xDrive / 6/08/22: Dealer order placed - Status 047 / 6/25/22: Added Full Leather / 8/05/22: Received Allocation & Added Personal eSIM 5G / 09/18/22: Asked Dealership to Add M Drive Professional to My Build and They Canceled My Order
08-22-2022, 10:14 PM | #3 |
Rep 748
Aftermarket square set.
08-22-2022, 11:47 PM | #4 |
Rep 99
I run 19x9.5" with 275/35R19 squared for track days. The wheels are ET40 so I use a 20 and 22mm spacer to bring them out a bit. I actually use the 22mm in the front because there is less inner space vs the rear. The 20mm should work in the front too but I did it this way just in case since track tires run a bit wider and there is more tire deflection at higher G's.
Your only issue with with 19x9.5" ET20 + 275/35 will be that the rear will look tucked. |
08-23-2022, 12:02 AM | #5 | |
Rep 748
I don't think I'll be bothered by the tuck. They should look the same as the OEM 829M winter setup.
08-23-2022, 06:53 AM | #6 |
Rep 2,709
Of course they will work, I would still prefer smaller tires for winter but that's just my preference.
08-23-2022, 09:34 AM | #7 |
5906
Rep 5,621
I run 19x9.5 et 22 square with 257/35 for winter... I kept my spacers on though (15f/12r) it works fine, with no issues; even lowered on AST springs.
Current: 2025 G80 M3 6MT | Boston Green | Tartufo
Former: 2022 G80 M3 6MT SG | KO, 2018 F87 M2 6MT | AW, 2016 981 Cayman 6MT | JB, 2015 F80 M3 DCT | TZB | GB, 2013 E92 M3 6MT | MW | FRB |
08-23-2022, 10:50 AM | #8 |
Rep 184
fyi the OEM 829M winter package has 9Jx19 front and 9.5Jx19 rear. Totally no idea why they do this since the tires are 275/35R19 squared. But still I see no reason why a squared set won't work out and I'm planning to do so as well. Glad you brought this up and created a thread, I'd also like to see other feedbacks.
08-23-2022, 11:24 AM | #9 | |
Rep 748
I’m not going to sweat an inch of width. I’d probably worry more about it if I had a RWD.
08-23-2022, 11:26 AM | #10 | |
Rep 748
What wheels are those? Got a pic from the side?
08-23-2022, 11:30 AM | #11 | |
Rep 748
If anything it confirms that a 19x9.5j ET20 works on the rear. Like I said above the 826M is 19x9.5j ET20 in the front.
08-23-2022, 11:57 AM | #12 |
Rep 5,782
Drives: '24 iX50; '23 Audi RS etron GT
He is running VMR V710.
JTO24 cast or their flow form version?
'24-I20 iX 50; '23 RS etron GT; '23-G26 i4 M50*; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
JTO245906.00 |
08-23-2022, 05:00 PM | #13 | |
Rep 184
Nevertheless, I believe a squared set, although bmw has never officially offer any OEM squared sets, will work fine. That's why I'm also ordering a 19' squared set for my winter setup. I spent much time researching on the forum and I've seen many members with squared sets working fine, either on 19' or 20' sets. |
08-23-2022, 05:06 PM | #14 | |
Rep 748
I agree on that last part and will be doing the same. Literally the only difference with my anticipated set is 9.5j front versus 9j on the 829M. A quarter inch on either side is the same footprint as an 826M front. And many on this board have wheel and tire sets that are a lot more divergent from OEM and not had a problem with fit.
08-23-2022, 07:02 PM | #15 | |
Rep 184
08-23-2022, 07:41 PM | #17 |
5906
Rep 5,621
Thanks, yes! and just the cast version
09-13-2022, 11:14 AM | #19 | |
Rep 50
09-13-2022, 02:11 PM | #20 |
Rep 99
It should be +2 +12.8 +10mm so a 24 or 25mm spacer would probably do. I'm getting the 2 to bring ET 22 to 20, 12.7 since its a 9.5" vs 10.5", and then the 10 since thats what forum users have been using to make the rear flush. To achieve the same 'tuck' as the front it would be a 14-15mm spacer.
lorob12121.00 |
09-19-2022, 04:42 AM | #21 |
Rep 439
I have just purchased CSL Wheels (4x19) for my winter setup and plan to run 12mm spacers on the rear to account for the difference between the stock 20s and the 19s. Will report back once I have them installed.
2022 M3 Comp xDrive - Frozen White
2024 X5 40i xDrive - Black Sapphire Metallic 2021 X5 40i xDrive - Black Sapphire Metallic - SOLD 2012 Audi A4 Avant - SOLD Insta: mtn_m3cx |
09-19-2022, 01:36 PM | #22 | |
Rep 1,121
kiw1623.00 |
