E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90/E92/E93 Marketplace (For Sale / Trade / Wanted) > SPONSORS Classifieds/Groupbuys/Specials Area > Turbo Engine / Drivetrain / Exhaust Parts > ** SupremePower / Proud to offer Helix Motorsports products!!! **
Reply
      12-16-2008, 08:39 PM   #1
Craig@SupremePower
G.O.A.T.!
Craig@SupremePower's Avatar
Drives: '18 GMC Yukon XL
SupremePower is Proud to offer you Helix Motorsports products!!!
Call to order at 714 632-1951 or PM me with any questions you have!!!
Helix Stepped Core Intercooler - $969 + Shipping
Install:
Fits in stock location- YES
requires no cutting,removal and/or permanent modification- Yes
Can it be installed without removing front Bumper- YES
Utilizes factory mounting points- Yes
Design:
More core volume than stock- Yes 56%
More Ambient face than stock- Yes 56%
More charge rows than stock(8)- Yes 13
Bar and Plate construction- Yes
Removes restrictive stock O ring connectors- Yes
Seals to factory radiator fan shroud so air is drawn through when car is not in motion- Yes
Performance:
Helix intercooler at 13.5psi 63 degree ambient temps:
372whp +22whp
turbo outlet temperature 228 degrees F(estimated using a 63 degree ambient and 65% compressor efficiency at 13.5 psi)
AIT temp- 75 degrees F - 54 degree drop over stock
pre and post intercooler temp drop- 153 degrees F
Intercooler efficiency- 93% - 33% improvement in efficiency over stock
Core pressure drop spec is .5psi at 450hp(600cfm) airflow
Helix Blow Off Valve (BOV) - For a limited time this will be at an introductory price of $349 + Shipping
The Helix Blow Off Valve (BOV) Kit replaces the stock diverter valves on the BMW 135/335 cars and allows you to safely release boost pressure to atmosphere. The helix BOV kit helps prevent compressor surge and reduce exhaust gas temperatures by allowing excess air to escape instead of recirculating, which slows the turbine wheel response. This becomes even more important once boost is raised because the engine will require a larger volume of air to flow between the turbo and the inlet of the engine. By reducing compressed air surge, the Helix BOV kit prolongs engine life. Due to superior design and extensive spring testing, the Helix BOV does not cause check engine lights or problems with idle. It sounds stock under normal driving conditions, but will add that traditional turbo 'whoosh' to your BMW 135/335 under heavy acceleration.
Helix's kit includes high-quality machined elements and is easy to install using normal hand tools. There is no cutting or drilling necessary and is easily reversible.
      12-17-2008, 09:25 AM   #2
Craig@SupremePower
G.O.A.T.!
PM's replied...
      12-18-2008, 08:19 AM   #3
Craig@SupremePower
G.O.A.T.!
PM's replied....
      12-19-2008, 09:38 AM   #4
Craig@SupremePower
G.O.A.T.!
PM's replied!!!
      12-20-2008, 09:52 AM   #5
Craig@SupremePower
G.O.A.T.!
PM's replied...
      12-21-2008, 11:50 AM   #6
Craig@SupremePower
G.O.A.T.!
PM's replied...
      12-22-2008, 08:59 AM   #7
Craig@SupremePower
G.O.A.T.!
PM's replied....
      12-23-2008, 08:14 AM   #8
Craig@SupremePower
G.O.A.T.!
PM's replied...
      12-24-2008, 10:39 AM   #9
Craig@SupremePower
G.O.A.T.!
PM's replied!! Happy Holidays!!
      12-25-2008, 11:02 AM   #10
Craig@SupremePower
G.O.A.T.!
PM's replied!!!
      12-26-2008, 10:46 AM   #11
Craig@SupremePower
G.O.A.T.!
PM's replied!!
      12-27-2008, 11:37 AM   #12
Craig@SupremePower
G.O.A.T.!
PM's replied...
      12-28-2008, 11:08 AM   #13
Craig@SupremePower
G.O.A.T.!
PM's replied!!
      12-29-2008, 01:03 AM   #14
sd390r
sd390r's Avatar
Drives: AW M3
2008 E90 335i  [0.00]
good luck!!
2008 E90 M3 - Sold
2006 Evo IX SE - Sold
2008 E90 335i - Sold
      12-29-2008, 10:49 AM   #15
Alex@AKMotorwerk
Alex@AKMotorwerk's Avatar
Drives: 2012 AW F10 535i
Very nice... didn't know SP started offering Helix products.... Good luck
      12-29-2008, 11:04 AM   #16
Craig@SupremePower
G.O.A.T.!
PM's replied.... ...thanx guys!!!
      12-30-2008, 04:27 PM   #17
Craig@SupremePower
G.O.A.T.!
PM's replied....
      12-31-2008, 10:19 AM   #18
Craig@SupremePower
G.O.A.T.!
PM's replied!!
      01-01-2009, 12:15 PM   #19
Craig@SupremePower
G.O.A.T.!
PM's replied.... Happy New Year!!!
      01-02-2009, 10:28 AM   #20
Craig@SupremePower
G.O.A.T.!
PM's sent...
      01-03-2009, 11:55 AM   #21
Craig@SupremePower
G.O.A.T.!
PM's replied...
      01-05-2009, 09:44 AM   #22
Craig@SupremePower
G.O.A.T.!
PM's replied....
Reply
e90post
