07-21-2022, 01:56 PM | #1 |
Rep 298
First set of tires finally dead
These are the Michelin PS4 that came with the car, ~15 months ago. After 4th and most recent track day, they are loosing chunks of rubber. I haven't seen this before. I assume they are dead and need to be replaced, right? What causes chunks to break off?
Planning to replace with new set of the same - unless there is consensus that something else is way better? I use it for 95% daily commute, 5% track. |
07-21-2022, 09:45 PM | #3 |
Rep 298
BMWRacer5232567.00 |
07-21-2022, 09:52 PM | #4 |
Rep 1,805
Oh yeah, thats a well maintained facility. Def asphalt. I've seen tracks like Sebring tear tires up like that because many sections are concrete and they are very abrasive. Are you sure this is from track? Do you regularly commute on crappy torn up roads?
07-22-2022, 09:10 AM | #5 |
Beware of cheap bait!
726
Rep 714
Chunking can happen when tires are quite overheated, but I'm guessing it's a combo of overheat and just being worn out.
Did you run with revmatch? |
07-22-2022, 09:15 AM | #6 | |
Rep 298
07-22-2022, 09:16 AM | #7 | |
Rep 298
Probably they are just worn at this point. |
07-23-2022, 03:30 AM | #9 |
Rep 99
Also I think for your use case the oem star spec PS4s are the still the best choice. There are more track oriented tires that can take more heat but they dont do well in the rain and are not comfortable on the street.
https://grassrootsmotorsports.com/ar...qMRLYWHotW0TT4 |
dimab0324.50 |
07-23-2022, 08:26 AM | #10 |
Rep 924
If you need wet/winter driving them the mps4s* are the way to go. A little soft and numb for the track but given your usage should be good to go. There's nothing else going to give you good wet traction and decent dry traction like that tire.
2023 F90 M5
07-23-2022, 11:41 PM | #11 |
726
Rep 714
07-23-2022, 11:43 PM | #13 |
Rep 298
Oh rev match is some organization? Then no, not with them. I thought you meant the feature on the m4 to auto rev match when shifting.
07-24-2022, 12:23 AM | #14 | |
Rep 924
2023 F90 M5
07-29-2022, 05:10 AM | #15 |
Rep 668
Except for the massive "ice storms" i have been though here in Texas the last 46 years!
08-03-2022, 01:22 PM | #16 |
Rep 14,318
Drives: G82 M4C X-Drive
Garage List 2025 BMW M2 [10.00]
2022 G82 M4C X-Drive [9.89] 2018 F80 M3 CS [9.90] 2018 BMW i3 REx [5.00] 2015 BMW i3 REx [0.00] 2016 BMW F80 M3 [7.29] 2016 BMW F30 340i ZTR [10.00] 2013 BMW F30 328i [0.00] 2006 Audi S4 25Quattro [7.00] |
Looks just like my front driver side started chunking after 4 CW track days. Most notably after neglecting to check temps and pressure during a triple digit day at Spring Mountain, which has several high speed right turns. With how heavy our G8Xs are, and how much softer the MPS4S* compound is at the corner compared to the non-star, it seems to be much more temperature and pressure sensitive.
I've since mounted Cup2 (240)... I'll be posting an update on wear characteristics and overall performance when I get my car back and get some more seat time. From my one track day on these tires, however, I've already beat my PB and they are pretty damn good.
2025 G87 ///M2 LCI Stock Previous • 2022 G82 ///M4 Comp X-Drive • 2018 F80 ///M3 CS • 2016 F80 ///M3 |
08-03-2022, 01:40 PM | #17 | |
Rep 298
08-03-2022, 01:57 PM | #18 |
Rep 14,318
The MPS4S* has more of the Cup2 compound on it's outer tred, so I imagine it will be about the same or worse, but I figure that since the MPS4S* is a compromise for street wear and occasional track use, I might as well get the track tire for optimal grip since I don't daily drive it!
08-04-2022, 10:04 AM | #19 | |
Rep 924
the 4s's are not as heat tolerant as the cup2, and the sidewalls are much softer. Cup2* are a lot stickier at 180 degrees.
2023 F90 M5
08-04-2022, 10:06 AM | #20 |
Rep 924
Yeah but nobody drives in that weather.... Ive completely lost my tolerance for cold. First winter I never wore a jacket...now I have a hoody on at 65 degrees...
2023 F90 M5
08-05-2022, 09:29 PM | #21 | |
Rep 668
Yea used to be in Local Union 146 when i was a kid...coldest I ever felt in was on the runway at Carswell AFB. I swear it was colder than the 4 years I was in Germany! Something about the tarmac, the concrete super cools the air! I almost seen grown men cry that day. They said "drag up". Tools go back in the gang box. Go the F home! Only one time did I see that in the Union. That one day!
