06-27-2022, 06:28 PM | #1 |
Rep 91
Drives: 2023 M240i X-Drive
Winter wheels and tires
Looking to see if anyone has ordered any dedicated Winter setup.
Wheels and tires as a combo. I believe I saw someone who posted that the M340I Xdrive with high performance pack would have the same ET and work as far as ordering goes. I'm not ready to spend $2-3k on a maybe, so I am wondering has anyone done any more research and found what ET works with our cars. Mine is specifically equipped with ZTK so I want to make sure that what I get would fit. Currently looking at a set up from Tirerack that (using the M340I x drive with high performanace tires option) is a 19X8 with 2 offset options of either 28 or 32. Which would work best, and not potentially cause issues. Thanks in advance. Just want to make sure I am ready since the PS4S aren't the best here in north east ohio Last edited by HotsauzF82; 06-27-2022 at 06:28 PM.. Reason: wront url |
06-28-2022, 07:08 AM | #2 |
Rep 119
wheel size and offsets
I'm in a similar situation, as Wisconsin is not a place for summer tires from December through March (JK - more like Dec-May!). Given the newness, here's what wheel-size.com has listed for the G42:
fronts: 8 x 19 et 27 (225/45/19) rears: 8.5 x 19 et 40 (255/35/19) Running a 225/45 square set-up on 8 x 19 et 28 seems the easiest. Rears would be inboard a bit, but spacers would make it look better. I would like to run at least "-1" on sizing. Given that, a 225/45 tire on a 8 x 18 et 28 wheel would work - but I have no idea if it clears the calipers (my guess is it will). I would prefer "-2" in sizing - and a 215/55 on a 7 x 17 et 26 wheel seems ideal, but the calipers would have less clearance than the 18's. For me, 225 is a tad wide for winter (particularly as we do get snow accumulations), and having the higher side wall really helps with our massive potholes. I'm confident TireRack will have the fitments uploaded soon - maybe I will actually have my car by then |
06-28-2022, 10:18 AM | #3 |
Rep 1,188
Drives: 2008 e92 335xi
This is what I'm leaning towards doing for my winter setup. It would be nice if Tire Rack would get their database updated to show what wheels will fit.
06-28-2022, 01:22 PM | #4 | |
Rep 91
893 spec for the wheels are 19X8.5 ET 25 F 19X9.5 ET 35 R So just wondering if ill run into issues with either the ET of 28 or 32 for the wheels i've seen used on the M340i X-Drive configurator with the HP package via Tirerack Last edited by HotsauzF82; 06-28-2022 at 01:58 PM.. |
06-29-2022, 05:49 AM | #5 | |
Rep 119
https://g42.bimmerpost.com/forums/sh...04&postcount=3 |
06-30-2022, 01:27 PM | #6 | |
Rep 91
06-30-2022, 02:48 PM | #7 |
Rep 326
Sorry I did not include offsets in my post.
Wheels go on and off quickly at the garage and happened when I was distracted by other things. Anyway M340 configurations seems to work and 18" winter wheels drive very well.
Retired: '08 335xi E90. "Long may you run."
Retired: '19 M240xi "You also" |
08-10-2022, 01:26 PM | #8 |
Rep 375
Here is what I have for the winter. Standard M Sport Brakes
I just test fit the rims today, plenty of room. Wheels https://www.tirerack.com/wheels/msw-...-black-painted Manufacturer Part #:W19354002TC5 Tires https://www.tirerack.com/tires/tires...num=34VR8PA5XL Last edited by Ruebarb; 08-10-2022 at 01:34 PM.. |
09-02-2022, 07:50 AM | #9 | |
Rep 157
Ruebarb375.00 |
09-07-2022, 07:25 PM | #10 | |
Rep 36
Thanks for this! When you say “standard M sport brakes” does this mean with ZTK package? I’ve been running around trying to find an 18” wheel setup and can’t seem to find an answer for offset. Parts at my dealer advised I could run 8x18 at the front and 8.5x18 at the rear on 225/45/18 and 255/40/18, respectively. I’d be going with square setup (using front configuration) but no idea what offset I need to clear brakes (I have ZTK) |
09-08-2022, 08:41 AM | #11 | |
Rep 375
09-13-2022, 03:11 PM | #12 | |
Rep 119
09-13-2022, 03:35 PM | #13 |
Rep 187
Might of off topic slightly, but has anyone tried mounting up a VW / Audi set? Not a lot of options for BMW locally..
I'd need to get spacers probably (Planning on getting 12/15 F/R anyways), and also hub centric rings. Specs are: 18" 5X112 et35 245/40R18 tires My logic is - the 19" OEM's fit with a 25 offset.. So a 35 offset rim with a 12mm spacer should equal 23 offset?
https://www.instagram.com/g87_smurf/
@g87_smurf |
09-13-2022, 09:38 PM | #14 | |
Rep 36
I’m getting a set of wheels this week I plan to get fitted to test in the next week or so. 18” 5x112 et 25 CB 66.6. Wheels are 245/40R18 like you, square setup. Will keep you posted! |
tubingchamp102.50 |
09-14-2022, 10:07 AM | #16 |
Rep 187
Sweet, thanks
@g87_smurf |
09-18-2022, 12:56 PM | #17 |
Rep 36
tubingchamp102.50 |
09-19-2022, 11:43 AM | #18 | |
Rep 187
Thanks for the heads up.. Which wheels were they?
@g87_smurf |
09-21-2022, 11:18 AM | #19 |
Rep 36
09-22-2022, 01:15 AM | #20 | |
Rep 25
10-22-2022, 03:40 PM | #21 |
Rep 119
Now that the car has finally arrived, I can enjoy at least a few more weeks until snow becomes more probable in these parts (Milwaukee). I followed the path of Hpirx and Ruebarb and used the M340i via Tire Rack. Did a test fit this morning and everything fit with plenty of room. Set-up as follows:
ASA "GT16" (gunmetal finish), 18x8, ET28 with Vredestein 225/45/18, total weight with tires 46 lbs [square set-up] FYI I do not have the ZTK option. Also - I weighed the OEM 19's with tires. I have style 797 with Pirelli P-Zero's. Fronts @ 46 lbs, rears @ 50.6 lbs. Per manual, torque setting for lug bolts @ 101 lbs/140 Nm Front: Rear: |
