06-13-2022, 02:54 PM | #1 |
Rep 139
Can someone tell me if these are aftermarket or oem shocks by the label? 2020 m340ix was purchased new fully loaded with adaptive suspension.
Dealer had to change my shock mounts for whatever reason saying the parts were on back order. Got the car back with the suspension being lifted around and inch and the car rides soft and in all settings. Took a picture today having it lifted at a garage to get the tires changed and saw that the label said Monroe. Are these aftermarket? I remember the coil covering being black and its worn out and a yellow colour.
2020 M340ix
2017 Porsche Macan Turbo 2014 Audi RS4 2010 E60 M5 2006 Honda S2000 2001 Integra Type R |
06-13-2022, 05:12 PM | #2 | |
Rep 1,521
Here are a couple pictures of the front strut and rear shock off my 2020 M340i |
06-13-2022, 05:49 PM | #3 |
Rep 380
The adaptive dampers on my M440i are also Monroe. Different part numbers but probably due to M440i vs M340i.
Chubbiejones891.00 |
06-13-2022, 08:35 PM | #4 |
Rep 4,660
Unless someone went out of there way to create a sticker with a BMW logo, aftermarket parts typically don't have an OEM logo anywhere.
07-12-2022, 12:33 PM | #5 |
Rep 139
They could be bmw parts but I have reason to believe they were swapped out. The height is different and the ride is unstable and super soft and bouncy.
Running adaptive suspsension. Wish there was a way to tell them apart. Will serial numbers or anything else.
2020 M340ix
07-12-2022, 11:44 PM | #7 |
Rep 219
The suspension could need to settle in. As for stiffness, it could be that your first suspension had the shipping blocks left in (it's a common issue for Supras, less common for g20s) or was just bad resulting in a harsher ride. I'd also be very shocked to see a dealer use aftermarket parts on a warrantied item.
BMW M340i
-Stg 2 Full Flex (Ecutek), downpipe, Ohlins R&T, Dinan intake, Dinan Turbo Inlet @g20.m340i Porsche 911 Carrera T (retired) |
07-14-2022, 02:50 PM | #8 |
Rep 1,115
Drives: 2022 M340i Mineral Grey
Just an FYI to all, Monroe does in fact produce parts for BMW at the OEM level. Some parts are currently supplied by Monroe and may not have Monroe branding or label. Many large aftermarket manufacturers are OEM suppliers.
Present: 2022 M340i Mineral Grey
Past: 2019 330i, 2012 Evo X GSR |
07-14-2022, 03:37 PM | #9 | |
Rep 139
It's like nobody can read. My shock mounts were suppose to be replaced not the suspension, and it came back with something that feels and looks like a base models 3 series suspension. Thanks for the pic. Are these the adaptive shocks/suspension?
2020 M340ix
07-14-2022, 05:03 PM | #10 |
Rep 15,858
Your first picture shows part of the proportional valve on the damper body, therefore it is an adaptive damper.
If all have the valves fitted, (sticking out of the damper body), with wire attached, why are the modes not working? |
07-14-2022, 08:12 PM | #11 | |
Rep 219
BMW M340i
07-17-2022, 03:58 AM | #12 | |
Rep 13,001
- You should have told your dealer that your car suspension looked higher than normal at pickup, and inquire about what exactly was done to the suspension other than replacing the shock mounts "for whatever reason". But you did not do that. Forum members are trying to answer your "my dealer should be the one answering my crap"" non-issue, and the best response of yours is "you all can't read". Freaking child. |
VipinLJ1941.50 |
07-31-2022, 04:31 AM | #13 | |
Rep 139
The only option I have, which I am trying to avoid is to take it apart myself and examine things. There must a serial number for the part right?
2020 M340ix
07-31-2022, 04:40 AM | #14 | |
Rep 139
I doesn't look or feel like the same car. Very soft and wobbly. Front end has a lift around 1 inch higher. Looks ridiculous and feel even more ridiculous or small humps in the road.
2020 M340ix
07-31-2022, 04:48 AM | #15 | |
Rep 139
You think they could have installed shipping blocks onto the replacement shock mounts? lol I check it out. Car had no shipping block before the repair.
2020 M340ix
08-02-2022, 01:47 PM | #16 |
Rep 219
Very doubtful and the shipping blocks wouldn't account for the extra height that you are seeing. Maybe measure out the ride height and see if anyone who is stock can give you their measurements to compare.
BMW M340i
04-29-2023, 07:35 PM | #17 | |
Rep 139
2020 M340ix
04-29-2023, 07:36 PM | #18 |
Rep 139
I notice your struts have g20 printed infront of the strut. Mine say e46.
2020 M340ix
