Bimmerpost
4 Series
Technical Topics Suspension / Chassis / Brakes 374MM rotors on M Sport brakes?
      05-16-2022, 11:31 PM   #1
R3MIX_G20
R3MIX
R3MIX_G20's Avatar
Drives: BMW 330i
2020 BMW 330i  [0.00]
Hello, I keep coming across mixed reviews, so I thought I would put it out there and see if you guys can help.
For my 2020 G20 330i, I just purchased front M Sport calipers from the M340I. My question is can I run the 374mm G30 rotors on the car , and if so, would the calipers still be a direct bolt-on (and/or any issues) given the extra inch in rotors?
Any feedback would be appreciated.
-thanks
      05-17-2022, 02:40 AM   #2
Mr. Li
Drives: BMW 340ix
you cant use 374mm rotors with standard M340i 348mm Msoprt caliper, but if the caliper you purchased was option with Motorsport Engineering package, that caliper run 374mm rotors, take a look at the back of caliper it tells the caliper fit 348mm or 374mm
      05-17-2022, 06:04 AM   #3
Chubbiejones
Chubbiejones's Avatar
Drives: 2020 BMW M340i
-thanks
Check out the link below - has the answer to all your brake questions:
https://www.bimmerworld.com/M-Sport-Brakes-G20-G22/
      05-17-2022, 09:54 AM   #4
Technic
Technic's Avatar
2288
Drives: 2021 i3S, 2024 i4 M50
-thanks
Look at the dimples on your caliper:
- center dimple hole = 348mm rotors
- top dimple hole = 374mm rotors
      05-18-2022, 06:11 PM   #5
Trex
Sport Geezer
28
Drives: X1, F10, G80 (6 MT)
Chubb-Perfect link.Thanks.
      06-10-2022, 03:42 PM   #6
panki_86
Slovenia
112
Drives: G20 M340i xDrive Individual
With 374mm brake discs you can have 18" wheels. I have M Technology package and style 796m 18" rims for winter set
      06-10-2022, 03:47 PM   #7
Chubbiejones
Nice information to know! I'm sure the clearance is super close
      06-11-2022, 12:21 AM   #8
panki_86
Slovenia
112
Yes it is. This is winter set that BMW said is for M340i with option 33T. Even on mine CoC ( Certificate of Conformity) i have 18" wheels.
      06-11-2022, 07:13 AM   #9
Chubbiejones
Looks great! I'm sure the pictures and information you provided will assist others in the future.
panki_86112.00
      06-14-2022, 09:06 AM   #10
kevinm03
kevinm03's Avatar
57
Drives: E92 M3 Comp Santorini Blue
That guide is incorrect. The 348mm and 374mm pads are not the same. They are not interchangeable. See the below video.
Keeper: 2012 E92 M3 Comp KA401 - Santorini Blue
Daily: 2022 iX3 M Sport Pro - Phytonic blue with laser lights & towbar
Previous: G20 M340i, F36 430d, Mk7 GTI PP, Mk5 GTI ED30
      06-14-2022, 09:08 AM   #11
Chubbiejones
No doubt you and the video are correct.
g20
