05-02-2022, 03:54 PM | #1 |
BMW obsessed
9590
Rep 10,878
IND | BMW M Performance F97 X3M LCI Carbon Front Bumper Side Grille Set
At IND, its our mission to supply the parts you need to craft the perfect BMW. BMW M Performance has produced Carbon Air Duct Trims or "boomerangs" that replace the factory trim found on the front bumper. NOTE: Fits LCI models ONLY The BMW M Performance F97 X3M LCI Carbon Front Bumper Side Grille Set may be viewed at the following link to our online store: https://ind-distribution.com/product...ide-grille-set Please contact IND by phone or email for more information or to place your order. 866.963.4520 | info@ind-distribution.com
08-10-2022, 07:11 PM | #2 |
Rep 361
Drives: 2017 F80 YMB ZCP, 2022 F97 X3M
IND-Distribution Do you have an install guide for these? Bought them from you all and can't reinstall/connect the sensor.
2017 F80 M3 Competition DCT | Yas Marina Blue Metallic | Silverstone Extended Merino Leather
2022 F97 X3M Competition | Dark Graphite Metallic | Tartufo Extended Merino Leather |
08-10-2022, 11:29 PM | #3 | |
BMW obsessed
9590
Rep 10,878
info@IND-Distribution.com
Sublimeside80.00 |
08-17-2022, 05:11 PM | #4 |
Rep 361
Figured out how to get these installed. In order to properly install these, you have to go through the side wheel well as if you were installing painted reflectors. There's enough access once the arch guard is loose and you can fit your hand/arm in through the the side to plug the wiring harness back into the sensor.
06-24-2023, 09:37 PM | #5 | |
Scottie2hottie27
184
Rep 210
06-25-2023, 01:20 AM | #6 |
Rep 361
Ya. Its not that hard. The most challenging part is disconnecting the sensors. You will have to replace the plastics rivets. You can get them on Amazon.
