03-17-2022, 12:53 PM | #1 |
Rep 44
Car Jack and Spare Tire Recommendation
Can anyone recommend a good car jack for the m240i ? Also, Has anyone bought a spare tire? if yes, where from? Thanks Tire size 225/40/19
03-17-2022, 03:39 PM | #2 |
Rep 425
I'd highly recommend just buying the tire inflater set that comes with the car (for those that ordered without run flats). It'll cover you about 90% of the time, and you'll still be able to use your trunk.
By the time you get a jack and a spare in your trunk it'll be full... |
03-17-2022, 03:41 PM | #3 |
Rep 425
BMW Mobility Kit: Part # 71-10-2-333-674 for about $150
Or get a can of fix-a-flat for twenty bucks if you want to save a buck There's a reason these cars don't ever come with a spare tire. The mobility kit is the "OEM" solution. |
03-22-2022, 07:19 PM | #4 |
Rep 375
Modern Spare, not cheap$$
https://modernspare.com/ I bought the jack kit, not the spare, spare would leave no room in trunk. Between the BMW mobility kit and the tire repair kit I bought, I should get by without a spare. The jack may be needed to repair the tire, as you may need to remove it to patch. |
jbazz256.50 |
03-23-2022, 09:57 AM | #5 |
Rep 44
Thanks for your reply. I'm waiting to hear back from them. Seems like they only have size 18? Are there any other options from BMW? Do they offer a space savor for our car? Did anyone actually get another full size wheel and tire and throw it in the trunk?
04-03-2022, 04:30 PM | #8 |
Rep 23
I just received this and it fits with the spacer. I put it in the trunk. With the frequency of punctures in Northern NJ, I want to have a spare and am glad to have it.
04-04-2022, 02:17 PM | #10 |
Rep 23
The procedure is to bolt the spacer to the hub with the OEM hardware. Then you bolt the donut to the spacer. I wasn’t trying for any speed records in my garage as I wanted to learn how to do it. I would say that bolting the spacer to the hub is a few minutes. But I’ll add that the complete kit is pretty good. I strapped the wheel in the trunk using the tie down hooks.
04-05-2022, 07:41 AM | #11 |
Rep 44
Thanks for your reply ! I ordered the whole kit. Did you actually change you tires to non run Flats? I did and I noticed a big difference. Pilot sport 4S
04-05-2022, 11:42 AM | #12 |
Rep 23
Anytime! The car came without run flats so I do t know how that feels. However when I saw the mobility kit and remembered the damage I’ve had due to pot holes, I felt that a donut was in order. Get a pair of tie downs and use the hooks in the trunk to keep it from sliding around.
04-06-2022, 11:38 AM | #15 |
Rep 53
I got a jack from modern spare (they’re very responsive btw) and have ordered a stock OEM wheel and tire from my dealer. Pricey, but I’ve been jammed up on road trips before and would rather make space than be without on a long trip.
F30 and E92 NOW G42
10-13-2022, 09:26 PM | #17 |
Rep 267
10-13-2022, 10:32 PM | #18 |
Rep 502
Doesn’t the mobility kit come with the $2400 HD Cooling and Tire Package?
10-14-2022, 07:54 AM | #19 |
Rep 97
I'll be buying a full-sized spare wheel for my 230i when it arrives. The goo only works on basic punctures, not if there's a gash in the tyre or a damaged rim. And rural driving in Australia can mean a long distance between towns, and even further between towns likely to have a suitable replacement tyre.
On a recent club trip, one car hit a pothole badly enough to bend the wheel and destroy a tyre. Fortunately I had a spare wheel - we were out of cell phone range a long way from the next town. For our next road trip, at least 4 cars have spare wheels now! |
