BMW X5
      02-16-2022, 06:49 AM   #1
Scottdip
Drives: 2020 BMW X5 M50i
Dahler Exhaust Flap/Valve Control Module
Has anybody installed this on their x5 M50i?
It's a little pricey compared to pulling a fuse, but this would allow full control of the exhaust flap with the the ability to just have it operate in stock mode.
https://www.kiesmotorsports.com/coll...39668953612373
      02-16-2022, 12:08 PM   #2
toronto_m50i
Wawaweewa
toronto_m50i's Avatar
2020 BMW X5 M50i  [10.00]
i actually used this:
https://x-ph.com/cg-precision-vsc-2-...nd-controller/
Unlike the dinan module, this doesn't need any additional power or ground. It literally plugs right into the stock harness and thats it. I was even able to take the remote and sync it to my homelink so now i just use the homelink buttons on my mirror to open and close the valves.
Cheapers, and better product imo. Make sure you get the extension harness otherwise it's two short to go from one valve to the other
      02-17-2022, 08:15 AM   #3
ghostleo816
Drives: X5M
Thanks man
      02-17-2022, 10:59 AM   #4
toronto_m50i
Wawaweewa
Originally Posted by ghostleo816 View Post
Thanks man
you're welcome
      03-03-2022, 08:28 PM   #5
NYCX5M50i
Drives: 2021 X5 M50i executive/DHP
few questions. These may sounds dumb.
default settings and activated settings options. Can you explain?
and wow! the extended harness is expensive.
how hard is it to connect to homeland? otherwise there is a separate controller I assume?
      03-05-2022, 09:26 AM   #6
toronto_m50i
Wawaweewa
hey its basically whatever you want. for example i have mine set to default as the exhaust flaps are open, and activated as my exhaust flaps are oem. you also have the option to make the activate option the exahsut flaps closed.
The extended harness is expensive. Its actually one signal wire that goes frome one actuator to the other so i just cut it and added an extra 2.5ft of wire, heat shrinked, and that was it.
To connect to homelink theres no extra module. You literally just take the remote it comes with and pair it to your homelink like a garage door opener
      03-08-2022, 07:54 PM   #7
NYCX5M50i
Very cool. So don't buy the extension and just add wire. Ill have to order this. Thanks for explaining.
      03-09-2022, 04:42 AM   #8
Scottdip
Mine should be here in a few weeks. I'll post back once I have it installed.
      03-09-2022, 12:19 PM   #9
toronto_m50i
Wawaweewa
awesome
      03-12-2022, 03:59 PM   #10
NYCX5M50i
I'm going to order this as well. Will report back.
      05-05-2022, 08:02 PM   #11
NYCX5M50i
Finally received mine. Can't wait to install this thing.
      05-05-2022, 11:09 PM   #12
elite-fusion
Drives: 335xi
Video of it once installed please
      05-07-2022, 07:43 AM   #13
Lifeisgood20
Drives: 2019 X5 M Sport
This is a nice find so thanks for sharing toronto_M50i. I assume vehicle fitment is only for M50i, M Comp? I don’t see 40i listed as compatible.
      07-26-2022, 07:47 PM   #14
pfaezi
Drives: BMW X5 M 50i
Hey Guys,
I am in Toronto and was wondering if anyone can recommend somewhere to install this on my M50 i
https://www.dahlerusa.com/products/d...mw-x5-m50i-g05
      08-01-2022, 08:26 PM   #15
NYCX5M50i
I installed mine. Makes a little difference. I also decided to do a resonator delete. Between that and valves open I am happy.
      10-03-2022, 09:17 PM   #16
irpirate
Drives: 21 x5mc
Just installed mine, did not need the extension harness.
FI Exhaust.
xbimmers
