02-04-2022, 11:11 PM | #1 |
Rep 72
Is Style 792 Code 1VZ the widest NC wheel?
I don't mind the lip but if I am understanding the pricing guidelines correctly, it looks like the Style 792 Code 1VZ would be the widest wheels one can order without paying extra (NC - no charge)
Is this correct? If so, has anyone ordered with this and have any photos? Seems like a really good deal! |
02-05-2022, 01:12 PM | #2 |
Rep 63
I believe it will be same 8/8,5 as others. Looks like, 792M - just style, but specs are different. I saw one car on them, it does not looks like 9,5”.
https://www.getbmwparts.com/oem-part...27-36118089894 https://www.getbmwparts.com/oem-part...40-36118089895 Last edited by Perets; 02-05-2022 at 01:19 PM.. |
EM3RLD82.50 |
02-05-2022, 02:29 PM | #3 |
Rep 196
I did option my car with the 1VZ and its still in transit on a ship.
danallxt also spec'd the same option and should be getting his car before mine. Other fellow member are correct in that the 792 wheels are only available as 19x8 and 19x8.5 and hence it wont have the lip on the fender. Ive talked to genius and my dealer several times about the proper tire size (especially the fronts) and they all seemed to think the order guide was showing the right sized tires for this option. 245 wide tire should technically fit a 8in wheel and so I am hoping it still comes with 245 wide front. Shouldn't be a problem for rears to fit a 255 even if the wheel is only 8.5 wide which is similar to the other staggered wheel options such as 791 or 797. The 893 wheels are wider front and rear as shown in the order guide.
Thunder Night Metallic w/ Cognac interior
792 wheels with Red calipers Premium pkg Park asst pkg HK audio Aluminum trim |
EM3RLD82.50 |
02-05-2022, 06:42 PM | #4 | |
Rep 72
That's too bad. Would be great to have a wheels option with 8.5 and 9.5 width at no charge. Instead of having to spend an extra $2400. Tbh i'd probably be willing to spend for the 893m wheels. It looks so nice it's just hard to justify the cooling and bigger brakes when I will only be using it to commute to work on a 2 lane highway haha. When you get your car, can you please share the photos of your wheels? 🙏 |
02-05-2022, 07:18 PM | #5 | ||
Rep 196
I was torn between the 792 vs 893 and ultimately chose the 792. Figured I could spend the money on other goodies or perhaps on M perf exhaust when it eventually comes out. I will definitely post pictures when I get it but its a month out before I pick it up.
02-05-2022, 08:01 PM | #6 | |
Rep 706
Actually the for 255 rear i wish they would have had the 9" rim which is perfect for a 255 (yes the 8.5 is ok). A 9.5 inch rim with the 255 is stretching the tire a bit but is commonly done. A 265/275 would be ideal for a 9.5 inch rim. |
Jashue190.50 |
02-05-2022, 09:29 PM | #7 | |
Rep 196
To get an 8.5in upfront, we need an offset of 25~30 as the 893 wheel is 19x8.5 ET 25, 19x9.5 ET35 vs 792 wheel is 19x8 ET27, 19x8.5 ET40. I dont know if the 792 in 19x8.5 will necessarily fit the front with enough clearance to the suspension. Hence, I was thinking it might still end up coming with the 8in wheel. Anyways, we shall see as you get your car in a few days hopefully without any further delays |
02-09-2022, 09:28 PM | #8 |
Rep 706
I picked up my M240x today. Had the 1VZ option and i was going to report back here as to front tire/wheel size, specifically if 8 or 8.5 inch wheel. Others have posted that the 8.5 likely will not work on the front due to the 40ET.
So what did i get, dealer screwed up, i did not get the 1vz option. It is listed on my sheet from the dealer when i placed the order (S01VZ). Well i look the car over and see it has 225/40s on the front. What really pisses me off, very early in track my BMW i noticed no mention of that, rather it just mentioned "standard". I specifically called twice to have the salesperson verify if i was getting the 1VZ option. She said yes. Didn't happen, my car list as built shows a ZWH tire/wheel??? Which is 225/40 front. So i point out this problem and get no-where as there is no recognition that 245 front is an option. She is insisting that what i got is actually the 1VZ and they just don't stay consistent with the codes and that so that is why it says ZWH instead of 1VZ. Then was saying no way you want wider fronts than the rears???? My reply was look at the order guide 245 front/255 rear...whaddya talking about? Like she didn't have a concept of 245vs255vs225? Anyway i got no where with her and said screw it and took the car as is. Simply put somehow she screwed the order up, i think she was thinking as long as its style 792 wheel its fine, my guess is that is what she checked on and did not have the awareness of the 1VZ option being a wider front. Simply there was no recognition on here part that 245 front was a No Cost option. Having said all that, perhaps 1VZ is not a wider front and the order guide is wrong???? When someone gets a 1VZ optioned car, please let me know. I did get the summer non-run flats at least. In her favor i think she was focused on NonRFT tires with the 792 style wheel and that is what she checked on and missed the 245s specific to 1VZ. |
02-09-2022, 10:48 PM | #9 | |
Rep 72
I'd love to see photos of your car though. I'm sure it's still beautiful |
02-10-2022, 07:24 AM | #10 | |
Rep 196
This confirms that the order guide under the wheel section is incorrect which is frustrating and they added a new code (ZWH) to correct the tire size but didnt update the Wheels section to reflect the right size. Regardless, congrats on your car!! I am close to getting mine. Should know a date for PCD by tomorrow. |
02-10-2022, 08:21 AM | #11 |
Rep 1,477
Drives: BMW M2
Guys you should pay more attention to these details before placing your order, sometimes pricing and ordering guides may contain errors, better double check all information, you can find a lot of information online.
There is one and only one 792M rim since 2019 and it is 8/8.5", anywhere that reads something different is a typo. The 1VZ part number only refers to the tires (performance not runflat), the 1PW are performance runflat tires but ALL on the same 792M rims. Same name, same rims. Bmw wouldn't call the same rims by the same name if they had different sizes, it would be a mess. Just an example, 826M and 892M have exactly the same design, but different size, so different name |
02-10-2022, 09:02 AM | #12 | |
Rep 196
With that being said, one could technically install a 245/35R19 on the Front 8in wheel same as how the car comes with 255/35R19 on the rear 8.5in wheel since they are both the max recommended tire widths for both wheels respectively. Hence, when the initial order guide specified the wider wheels for 1VZ, I didn't think it was an error as was confirmed by both BMW Genius and the dealer several times over the past months. Its not that I didnt research enough but rather the indicated tire size in the order guide and its feasibility that got me to choose it. In the end, it doesn't really matter as I will remove these tires to swap for UHP All seasons and can upsize from the stock 225 in the Front. |
02-10-2022, 10:15 AM | #13 | |
Rep 706
02-10-2022, 08:35 PM | #14 |
Old Grumpy Guy
129
Rep 84
I, like you guys, was disappointed to discover 2 days before my car was delivered about my 1VZ option coming with "narrow" wheels and "narrow" tires. On the other hand I've been impressed with the Pirelli P Zero PZ4 tires I received. They handle very well and are quiet also. So, somewhat of a silver lining to the small cloud of disappointment.
02-11-2022, 11:22 AM | #15 | ||
Rep 706
Yes that problem is now known, but remember when most of us ordered these cars there was no track record or cars received with that option to validate. Going to a supposed BMW "knowledgeable source" obviously is of no use. I'm not irked but it created a situation between me and the dealer where i was wrong and questioned the dealer. I ended up apologizing, but the source of the problem is BMW itself. |
02-11-2022, 01:07 PM | #16 | |
Rep 1,477
Drives: BMW M2
Double-checking the info means comparing the US price guide to the other markets (UK, Germany, AU), and you would have found that only in the US one did they mention the 245 front tires with the 1VZ option, so there was probably something weird going on (first flag). Also, the wider tires come with extra lips, and the extra lips are not mentioned with the 792M, so probably the car doesn't come with the wider tires (second flag). Plus, there are plenty of photos and videos online since the press release (July 2019) where you can perfectly see that the car with the 792 rims and non runflat high performance tires (1VZ) rides on 225s. We had already discussed this here in December, I hadn't seen the car in person yet (the first G42s arrived in Europe only at the end of January), and it's confirmed that it was as I said and that the Bmw geniuses are not so "genius"... It was totally clear to me from the beginning, I'm not smarter than you, I just don't trust everything I read and used logic. Fun fact: when I had the 1M they wanted to put 10W60 oil on my engine "because it's an M car, Bmw recommends this oil for M cars". Ok but this isn't an M engine, it's the same N54 engine as the 335i, would you put 10w60 on a 335i? "Also your owner's manual and our service guide say to use 10w60". Please use your brain and double check with Bmw. Long story short, I was right and Bmw changed the recommendation later with a note to all dealers. |
02-11-2022, 04:39 PM | #17 | |
Rep 706
Yup i made an incorrect assumption. My point of the last post, even when the error is presented and pointed out to BMW Genius they continue to provide incorrect information. The inability to provide correct information even when the error is pointed out is disconcerting. As far as checking/comparing Order Guides for different non -US markets...well options and option packages, and standard equip all varies often by market. |
02-11-2022, 10:11 PM | #18 |
Rep 197
Why are you talking to this bmw genius hotline any ways? Talk to your CA dude. This bmw Genuiss team is basically just a call center that's trained to just go off the ordering guides and never even see these cars nor really know anything about them.
02-11-2022, 11:20 PM | #19 |
Rep 706
In which case the BMW Genius portal needs to be renamed the BMW maybe sometimes, not always correct hotline/portal. And no it was not a call but an email contact. I find automobile dealer "salespersons" quite often not very well informed and often provide incorrect information as well.
It is what it is. |
02-12-2022, 03:55 AM | #20 | |
Rep 1,477
Drives: BMW M2
The options change by market, but not the option codes. The 1VZ code universally means "792M wheels with 225/255 non-runflat performance tires," in the US, Europe, Asia, or Mars. In Europe, the M240i comes with 1VZ as standard and guess what? 225/255 tires, as you would have seen from July 2021 at the press release. Picture 33 set 1 https://www.press.bmwgroup.com/globa...pé?language=en If you don't understand this there is nothing we can do, but of course you are free to continue to follow the call center guys, the genius and other pseudo-experts and live happily. Or use logic and avoid these awkward situations. |
