01-04-2022, 10:28 PM | #1 |
Rep 148
Widest tire width for stock 20" rear wheels?
Hi,
The stock tire is 285/30/20, but I do wonder, the wheel is 10.5" or 11"? What would be the widest without rub or issues? 305/35/20 would be ok? Looking for the r888rs. Thanks. Last edited by 0Camus0; 01-04-2022 at 11:36 PM.. |
01-04-2022, 11:03 PM | #2 |
Rep 541
I ordered an 11" and will try and fit a 305.
Instagram - _MOWE_
01-04-2022, 11:04 PM | #3 | |
Rep 541
Instagram - _MOWE_
01-04-2022, 11:52 PM | #4 | |
Rep 148
I wish Toyo made the r888r in 305/30 instead of 35. |
01-05-2022, 03:21 AM | #5 | |
Rep 290
People are using up to 18mm spacers in the rear, so that means you only have to gain another 12 mm on the inside. I'd get under the car and check how much clearance you have to shocks, control arms etc. If you haven't got the extra 12mm (it would surprise me if you didn't) then you can wind on more camber, which will tuck the tops under more. If these tyres are for the track, more camber will be where you are headed anyway. |
0Camus0153.50 |
01-07-2022, 11:14 AM | #6 |
f82_s55
96
Rep 94
If it helps at all, I was able to fit 295/30 tires on the rear in my G80. These are with the style 826m 19 front 20 rears - so for those asking, 295/30/20 should fit no issue. I did have to remove my spacers in the rear though to avoid rubbing - I may not have rubbed, but it was a bit too close for comfort. will post pictures once I have them!
01-07-2022, 03:44 PM | #7 | |
Rep 830
So if u follow rim / tire norms, the max tire u can mount on that width is 295…depending on the tire manufacturer, they sometimes approve one step higher than official norms, so with approval it would then be 305. But for that the tire manufacturer usually want to know the wheel details and car details and then they check if they can approve that for safety reasons. |
0Camus0153.50 |
01-12-2022, 02:39 PM | #8 | |||
Rep 148
Dr.Deep1827.00 |
01-12-2022, 02:42 PM | #9 | |
Rep 453
01-12-2022, 08:54 PM | #10 | |
Rep 744
01-13-2022, 03:09 AM | #11 | |
Rep 830
09-03-2022, 02:29 PM | #12 |
Rep 39
Has anyone tried or know if toyo r888r 315/30/20 fits on the oem 20" 10.5 826M rear wheels??
PS Just want them for the drag strip, they dont come on 305/30/20 and nittos are on backorder. |
09-04-2022, 09:51 AM | #13 | |
Rep 191,448
I had to make the same decision and went with Toyo 285
06-13-2023, 12:13 PM | #14 |
Rep 2,700
Do you guys think 315/30-19 will fit a 11 wide wheel (I'd guess offset 10) ?
Combined with a 305/30-19 on a 19x10.5 et10 at the front this would be the ultimate setup. Altrough running a 305 square on 10.5 would probably be more cost effective and make the car rotate better.
06-13-2023, 01:09 PM | #15 | |
Riding the knock sensor
2429
Rep 1,612
Drives: 21 X5MC | 23 M4CSL
PLF693771.50 |
07-18-2023, 06:51 AM | #16 |
Rep 1
Was looking around for wheel setups and ran into this thread. I’m running stock comp wheels 19/20 wanted to go with the more meaty drag look ( car makes 680 wheel stock tires don’t hold up anymore) was thinking 305/35/20 m&t et streets any idea if these will fit?
07-18-2023, 08:02 AM | #17 |
#Driver
374
Rep 424
This thread is useless without pics.
2016 Focus RS - ende | 2017 718 Cayman - ende | 2007 911 C4S - ende | 2017 Macan - ende | 2015 Macan Turbo - ende
2023 M3xdrive | 2020 Macan insta: gtsdaddy |
michaelbuzby41.00 |
04-02-2024, 01:10 PM | #18 |
1963
Rep 1,925
Drives: E92 M3
Anyone try 285/35/20 for the rear? That's the closest size the RE-71RS comes in for the rear.
05-09-2024, 05:32 PM | #19 |
Rep 24
I was digging deep in threads for reference pictures without much luck.
Went with the gamble and glad I did. Here are some pictures for reference when it comes to upsizing tires. - Factory wheels. - BMW MP HAS Kit on lowest setting. - 12mm spacers all the way around - 305/30/20 rear - 275/35/19 front |
mpbruin108188.50 |
05-15-2024, 07:06 AM | #20 |
Rep 128
Looks Good Whatarip .
Question at that height setting is there any suspension left ? It doesn't really matter I'm just curious Last edited by saintex; 05-16-2024 at 09:59 PM.. |
Yesterday, 01:13 PM | #21 | |
Rep 2,086
Yesterday, 02:01 PM | #22 |
Rep 47
Little repost since we've given this out before but this customer was looking for something similar the widest possible on a 20x11 wheel
19x10.5 295/35/19 20x11 305/30/20 |
