12-17-2021, 02:04 PM | #1 |
Rep 327
Octane Booster long term
So basically where I will be working only gas 87 gas. I know octane boosters boost it by 1 point and treats 21 gallons. Basically if i put in around 2 to 3 prior to fill, octane will go upto 90.2 to 91.8. Will it be okay to use the booster every time I fill up for long term? Tank is around 13 gallons so
12-27-2021, 01:10 PM | #2 | |
Rep 276
12-28-2021, 05:29 PM | #3 |
2120
Rep 2,035
Drives: E92 M3
How often do you need to fill up? You might be better off buying a 55 gallon drum or two and filling it up with 91 or 93-octane ethanol-free gas elsewhere. Ethanol-free fuel will last for up to 6 months, a bit more if you add fuel stabilizer.
The problem with octane boosters you can buy in stores is that many of them don't work that well. The ones that do work and can find online are pretty expensive per gallon.
12-28-2021, 06:27 PM | #4 | |
salty cowboys fan
7075
Rep 3,744
Possibly relevant to you here, I recently read an article on fuels and they had this blurb about octane boosters:
Der_Wolf898.50 |
01-20-2022, 01:59 PM | #6 | |
Rep 566
|2021 M4 Competition| |2018 M3 Competition| |1994 525i|
///M |
Vervish157.00 |
05-11-2022, 10:12 PM | #9 |
Rep 393
Drives: 22 G80 Sao Paulo Yellow
I don't even care about the question kidding but where are you at that only has 87 octane seriously?
You can buy unleaded race fuels from Sunoco and if you mix it with 87 it might equal out to 93 I'd love 95 |
07-24-2024, 05:30 PM | #10 |
Save the Manuals
1808
Rep 3,038
I’m looking at Sunoco 260 GT to add to my V power 93 tank.
Any thoughts from folks who have used the Sunoco fuels?
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT |
07-24-2024, 08:44 PM | #12 |
Rep 249
Do you have a tune or a piggyback. Is the car completely stock?
0-60 3.08 sec (dragy verified 8/21/24)
1/8 7.18 sec (dragy verified 10/3/24) 1/4 11.18 sec (dragy verified 10/11/24) 60-130 9.11 sec (dragy verified 11/14/24) 0-130 12.29sec (dragy verified 10/3/24) |
07-24-2024, 09:17 PM | #13 |
Save the Manuals
1808
Rep 3,038
Stock
2023 G80 6MT, CCBs
07-25-2024, 07:32 AM | #14 |
Rep 5,650
Add 2gal of E85 per tank (or 1.5gals of E98) to boost pump gas octane. Adding GTX would be a waste. The GTX is 98 octane at $20+ a gal. E85 is 101 octane and $3 a gal.
07-25-2024, 12:05 PM | #15 |
Save the Manuals
1808
Rep 3,038
260 GT 100 octane
$10/gallon: fresh in Indianapolis Not GTX E10 Street legal
2023 G80 6MT, CCBs
07-27-2024, 07:19 AM | #17 | |
Rep 5,650
E85 is still a better octane improver since it’s evaporation pulls more heat than gas and has the same ~101 octane.
07-27-2024, 07:21 AM | #18 |
Rep 5,650
No, 2gal of E85 in a tank doesn’t push us over the recommended E limit, and it doesn’t push the HPFPs too hard either. It’s my Friday Street Night mix.
07-27-2024, 08:45 AM | #19 |
Rep 249
So even with a stock tune mixing 2 gallons of ethanol to 13 gallons of shell 93 will result in benefits??
07-27-2024, 10:16 AM | #21 |
Rep 5,650
The driver manual says to use fuel with a maximum of 10% ethanol. But…
I’ve added 2 gal of E85 then topped up with 93 to make my E20, and the car runs fine, better than pump gas alone. My short term fuel trims (STFTs) stay around 1.0 which means the computer is pushing normal fuel volume, not increasing STFTs which would show adding volume to compensate for E being “thin”. At E25 then I saw the trims start to increase, so I’ve seen that E20 is safe and E25 would start to be too much E for a “pump gas” tune/map. I guess that’s why an E30 map is the next level above a 93 map.
07-27-2024, 01:02 PM | #22 | |
Rep 7,583
