12-06-2021, 01:18 PM | #1 |
Rep 144
Break-in Period
To the ones that have already received their new cars, have the dealerships recommended to follow the break-in protocol? Or is anyone following it?
12-06-2021, 05:54 PM | #4 |
Rep 653
Drives: 2022 G20 M340i
Garage List 2021 BMW X5 [0.00]
1991 Ford Mustang GT [0.00] 1993 Ford SVT Light ... [0.00] 2020 Harley-Davidso ... [0.00] 2013 Porsche Boxster [0.00] 2018 BMW 340i M-Spo ... [10.00] |
Does anyone actually follow those directions for the full 1200 miles?
Chuck
2022 G20 M340i PB/Oyster Last- 2018 F30 340i 6MT ZHP AW/CRed |
12-06-2021, 06:17 PM | #6 |
Rep 31
I could be mistaken, and I am paraphrasing here, but i thought at one point there was some debate around whether you should drive a car hard during the break-in to heat up the engine block and properly seat the o-rings in the cylinders (or something of that nature). I feel like this was a topic of discussion ten years ago on the forums with regard to the N54 engine.
That being said, I tend to be a rule follower on certain things, so i will likely follow the break in guidelines (at least to 1,000 miles; doubt i will be willing to spare the extra 200 miles). |
12-06-2021, 06:47 PM | #8 |
Rep 653
Yes, the theory is that running the engine harder, not babying it or beating the heck out of it, from new helps to seat the piston rings in the bores. This will help the engine have a better seal and possibly make a little more power/run "better", burn less oil, etc.
Personally, I'm careful for the first ~500 miles and don't use cruise control or let it idle for long periods, but I also make 1/2-3/4 throttle runs higher and go higher in the RPM range as time goes on too. There are some manufacturers now that don't even require break-in periods. YMMV.
Chuck
12-07-2021, 06:51 AM | #9 | |
Rep 159
Current: 2022 M240i X-Drive Thundernight
Previous: 2014 435i M-Sport Estoril Blue PCD 5/20/14 2007 335i ED 4/13/07 2003 325i |
12-07-2021, 09:04 AM | #10 |
Rep 24
I watched a video comparing break in differences on a motorcycle. One they followed the manual and the other they just drove the crap out of it. Both engines were identical before and after break in. (They were taken apart and measured before and after). While there is more to break in on a car than a bike, and we most often drive cars for much longer mileage during the course of their lives, I suspect that the result would be similar.
12-07-2021, 09:32 AM | #11 |
Rep 875
I follow it. If you have an issue and the ECU shows you do not follow break in then the dealer can deny coverage if related. The distance is not so far is it? Amazed this topic continues to occupy forum space. I find it amusing yet ridiculous.
12-07-2021, 09:35 AM | #12 |
Rep 653
I'm not sure that is the same in the US? I have not heard of anyone being denied warranty service due to break-in recommendations being followed or not.
Chuck
12-07-2021, 09:38 AM | #13 |
Rep 278
Drives: '22 G42 m240ix, '18 X5 35d
the thing is if you at any time put the car in sport plus mode or move the shifter into sport mode, its practically impossible to keep the revs under 4500 unless you are manually shifting. I think avoiding a bunch of redline shifts with a cold engine is sensible but unless you never drive spirited, keeping the engine to a 4500 "redline" isn't easy.
-Nicholas
2022 BMW m240i x-drive 2018 BMW X5 35d x-drive 2015 VW Golf 1.8t 5-speed (sold) 2004 Chevy Cavalier (hopefully crushed by now) |
12-07-2021, 09:53 AM | #14 |
Rep 653
What is the actual redline?
Chuck
12-07-2021, 09:59 AM | #15 |
Rep 144
If you're amazed this topic continues to be talked about then no need to reply. Simply scroll past it.
Good 4 2 reasons462.00 |
12-07-2021, 10:18 AM | #16 |
Rep 875
12-07-2021, 12:16 PM | #17 |
Rep 111
12-07-2021, 09:53 PM | #18 |
Rep 162
Just normally drive it , modern car no special brake in needed . But you can do a early oil change around 3k miles , it is good for your car .
12-08-2021, 08:14 AM | #19 |
Rep 174
I thought about this but my car came with free maintenance for 3 years. I doubt they would do an early oil change for free.
12-08-2021, 09:13 AM | #21 |
Rep 3,550
Might depend on how long you plan to keep the car as to how well you treat it.
If you plan to keep it a long time, ask yourself if you know more than the BMW engineers who designed the engine, have the most experience with them, and made the recommendations. If you know more, then do what you know is best. If they probably know more, maybe do what they recommend. |
12-08-2021, 09:17 AM | #22 |
Rep 144
