11-04-2021, 01:49 PM | #1 |
Rep 426
Engine temperature warning
Hi all,
I have got this error in my dash while my car was stationary and i kept the engine running for some heating. A few minutes later, i got this message. Quite shocking. I turned the car off and about half an hour later, i started driving and the temperature did not rise. I slow moving traffic, the temperature started to rise again and i turned on start stop which got rid of the problem. I drove for about miles at 5000 rpm and no issues whatsoever, temperature was stable at around 100C. Came home and recreated the problem but turning the engine on and idling. I could see the bar rising with time. What i have noticed is that the radiator fan is not turning on. Is my suspicion correct that i may have blown a fuse? I recently took the car in to bmw for a software related light failure error. I had to remove my hardwired dash cam and rewire it again when i got the car back. I will check if i put a fuse in the wrong slot. The driver (passenger for you US guys) footwell fusebox is very tricky to get into. Any suggestions before i call bmw assist? I want to make sure i havent messed up anything. |
11-04-2021, 01:57 PM | #2 | ||
Rep 717
Drives: BMW M3 xDrive
11-04-2021, 11:38 PM | #4 |
Rep 6,962
My fan often runs when I get out of the car, for a minute or two. Somtimes under spirited driving.
YT: G Dubyou |
11-05-2021, 04:00 AM | #5 |
Rep 426
Thanks guys.
An hour and a half of engine running at idle, temp between 100 to 110C now. I just removed the dash cam. The accessory connection was tapped into F70 which I believe is for radiator fan. I am going with tapping into the fusebox in the rear. Is this temperature normal now? |
Limegrntaln13475.00 |
11-05-2021, 09:04 AM | #6 |
Rep 190,807
Take it to the dealer and please let us know how it goes.
Hopefully this is not going to be a recurring problem
11-05-2021, 11:24 AM | #7 | ||
Rep 717
madmedman275.00 |
11-05-2021, 12:07 PM | #8 | |
Rep 426
As soon as I changed the slots, viola, i heard the sound of radiator fan turning on and the temperature guage turning down. I guess i still need to have it checked by the dealer? Do you think the engine heat warning gets logged into the bmw systems? Thanks. The dealer is closed over the weekend but i will keep an eye on the temp guage. If there is any issue whatsoever, i will call bmw road side assist. |
Limegrntaln13475.00 Hjp1230.00 |
11-05-2021, 06:59 PM | #9 |
Rep 6,962
Its probably still recorded on the cars black box.
YT: G Dubyou |
madmedman275.00 |
11-05-2021, 07:30 PM | #10 |
Rep 426
