10-26-2021, 12:47 PM | #1 |
![]() 3168
Rep 22,698
Posts ![]() |
▀▄ eas | The G8X M3/M4 Showroom - An ongoing journal
![]() Featured on BIMMERPOST.com To start off 2021 Black Sapphire Metallic G80 - AST lowering springs - Macht Schnell spacers 10F 12R [Pirelli's] ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
19
ROBERT11831625.50 JTO246455.00 VonB1126.50 Salespunk1936.50 _E90S65_743.50 Seedster2378.50 m4ml2117.00 jesm217.50 Blindside_1377785.00 GerryM5246.50 NorCalAthlete3406.00 GTP_M310317.50 Teargas41534.50 Jason46352.00 DMD572.00 rajahfl41.00 Sean@PSI2628.00 Saywhat4118482.50 dynebolik33.00 |
12-06-2021, 06:09 PM | #2 |
![]() 3168
Rep 22,698
Posts ![]() |
Isle of Man M3 getting a KW HAS kit, PSI midpipe and spacers all around
17
Seedster2378.50 m4ml2117.00 _E90S65_743.50 MannyM5208.50 JTO246455.00 jesm217.50 DavidXJ777.50 GerryM5246.50 NorCalAthlete3406.00 Gxs615127.00 nathanm4692.50 tropicatango476.50 Teargas41534.50 Jbonly211496.50 Sean@PSI2628.00 dynebolik33.00 PlainEnvelopes51.50 |
12-06-2021, 10:17 PM | #3 |
![]() ![]() ![]() ![]() 744
Rep 674
Those 824Ms lookin' meaty!
2021 M340i Portimao / Cognac
2018 F80 M3 Silverstone / Sakhir (gone) 2015 M235i Estoril / Black (gone) 2011.5 E90 M3 Silverstone / Black (gone) |
12-22-2021, 07:07 PM | #5 |
![]() ![]() ![]() ![]() ![]() 477
Rep 944
It's sad that bmw put a tiny rear caliper only for electronic e-brake
Mclaren for exemple have a super tiny caliper only for ebrake and a really massive caliper for braking Bmw should have gone this way... Very nice guys, keep posting |
tom @ eas9057.50 |
12-22-2021, 08:23 PM | #6 |
I /// M FAN
![]() 439
Rep 427
It's really annoying that the brake disks are already rusted in the vent part. On my F82 they replaced the rear one 2 tines under warranty because they were warped. The front one did the same later.
FrankieNuo1471.00 |
12-23-2021, 01:36 PM | #9 |
![]() 3168
Rep 22,698
Posts ![]() |
12mm up front looks good and fits properly, however the sidewall profile of the Pirelli makes contact with the fender liner turning. Michelin's or other brand tires can run a larger spacer without that issue.
12-23-2021, 01:50 PM | #10 |
![]() 9058
Rep 19,292
Posts ![]()
The other alternative would be to trim the plastic fenderwell vents to allow additional clearance if you have the Pirellis or want to run a larger spacer.
12-23-2021, 02:03 PM | #11 |
![]() 9058
Rep 19,292
Posts ![]()
Another AST spring install, Pirellis were removed with Michelin Pilot Sport Cup 2 in its place.
Vehicle: 2021 BMW M3 Competition Suspension: AST Lowering Springs Tires: Michelin Pilot Sport Cup 2, 275/35-19 (F), 295/20-20 (R) Spacers: Macht Schnell Competition Spacers: 10mm (F), 10mm (R) ![]() ![]() ![]() ![]() ![]() Enjoy!
12-23-2021, 02:04 PM | #12 |
![]() 9058
Rep 19,292
Posts ![]()
2021 M3 Competition X-Drive AST install in the bag. M3 looks, drives and feels absolutely fantastic. Drop is identical to non X-Drive.
Vehicle: 2021 X-Drive BMW M3 Competition Suspension: AST Lowering Springs Tires: Pirelli P Zero, 275/35-19 (F), 295/20-20 (R) Spacers: Macht Schnell Competition Spacers: 10mm (F), 12mm (R) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
12-23-2021, 02:06 PM | #13 |
![]() 9058
Rep 19,292
Posts ![]()
AST Springs for M4 fitted and look fantastic, measuring at a 30/35mm drop after installing - getting rid of the wheel gap without any rubbing. Specs below:
Vehicle 2021 BMW M4 Wheels F: 275/35-19 Prielli Zero R: 285/30-20 Pirelli Zero Height (OEM) DF: 64.1cm PF: 63.9cm DR: 65.7cm PR: 65.4cm Height (AST) DF: 61.1cm PF: 60.9cm DR: 62.2cm PR: 61.9cm Drop Height F: 30mm/30mm (30mm) R: 35mm/35mm (35mm) Spacers F: Macht Schnell Competition Wheel Spacers - 12mm R: Macht Schnell Competition Wheel Spacers - 10mm AST Lowering Springs - G82 M4 - Before ![]() ![]() AST Lowering Springs - G82 M4 - After ![]() ![]() ![]() ![]() ![]() ![]() ![]()
12-25-2021, 09:33 AM | #15 | |
3306
Rep 8,080
ok so at full lock it wont work. got it. thank you! |
01-04-2022, 02:34 PM | #16 |
![]() 9058
Rep 19,292
Posts ![]()
Jaguar is back trying out different suspension setups, this time the KW HAS kit. Enjoy!
01-04-2022, 03:01 PM | #18 |
![]() 9058
Rep 19,292
Posts ![]()
Intentional. He will be driving around temporarily to get a feel so new carbon lip isn't damaged. Coming in for a readjustment in about a week or so.
There's still quite a bit of range to lower the front and rear if desired.
01-04-2022, 03:04 PM | #19 | |
![]() ![]() ![]() ![]() ![]() 1377
Rep 688
Edit: Ah yes, just checked the pics a bit further. I can see the thread now. ![]() |
tom @ eas9057.50 |
01-04-2022, 03:05 PM | #20 |
![]() 9058
Rep 19,292
Posts ![]()
01-04-2022, 03:08 PM | #21 |
![]() ![]() 3340
Rep 1,952
I'm curious when you re-adjust KW HAS do you do it while fully installed or do you need to disassemble some components? My shop already re-adjusted mine (rears) but they had to unbolt some parts etc.
![]() 2022 G80 M3 Comp M xDrive |
01-04-2022, 03:11 PM | #22 | |
![]() 9058
Rep 19,292
Posts ![]()
Front suspension can just unloaded by jacking the front wheel off the ground and making the necessary adjustments. Rear suspension its easier to remove the perches, measure your baseline and then make the necessary adjustments.
M3AWD3340.00 |
