10-12-2021, 11:11 AM | #1 |
Rep 10,878
IND | Indiv G8X M3 / M4 Carbon Air Vent Install Guide
Tools Required:
Constructed of Carbon Fiber Pre-Preg, this carbon air vent begins as a genuine bmw core that is modified with carbon trim to add a bit of flare to your interior and match the other carbon trim found in the G8x M3 / M4 and M Performance models. Step 1: Begin by using a pry tool to pop the dash side panel away from the vent. STEP 2: With the side of the vent exposed, pull the air vent outward and down to remove it from the dash. STEP 3: Remove the Purple and Black connectors from the vent by gently inserting a flat-head screwdriver to release the small tabs. STEP 4: With the vent free from the vehicle, peel back the felt strip covering the purple connector and unclip it from the housing. STEP 5: Separate the outer trim console from the vent by releasing the 5 tabs and pull the vent and console apart. STEP 6: On the new carbon trim console, remove the purple connector from it's holder and snap the vent assembly into the new carbon trim. STEP 7: Reattach the purple connector to its receptacle and re-cover the data ribbon and connector with the felt strip. STEP 8: Re-connect the purple and black connectors and insert the vent back into the dash. Complete the install by pressing the side panel back into the dash.
10-12-2021, 11:13 AM | #2 |
Rep 10,878
We've also prepared a short Install Video:
10-12-2021, 02:30 PM | #5 |
Rep 10,878
Ambient lighting and a position sensor for air volume wheel.
10-14-2021, 01:52 PM | #6 |
Rep 2,135
