BMW X5
      10-12-2021, 01:32 AM   #1
2978386166
Drives: x6m50i
burble and pop on m50i
Hi guys, does anyone know how to create pops and cracks on the 21 x6m50i? The car has some good cracks and pops during revs on sport plus. However, I do not hear any during the drive.
On the gle53 I noticed I could get pops and cracks by accelerating to a high rpm and just press the brake a little. I tried the same on x6m50i which is a v8(praise on bmw) compared to a straight 6 on the gle53 but it didn't work. Is there something I should try?
I am also thinking of tuning the car to create more obvious burbles as I do enjoy the sound. However I am just worried of it voiding the warranty.
Any suggestions would be highly appreciated!
Thank you!
      10-13-2021, 06:05 PM   #2
zhangyi17
zhangyi17's Avatar
Drives: BMW X5
AMG want ppl to hear them, not BMW (even a V8)... I would like to make some popping sound too
      10-13-2021, 07:09 PM   #3
TFresh47
Drives: 2022 X6 m50i
Thank you!
Thank you!
I'm interested too
MissVito216.50
      10-14-2021, 02:33 AM   #4
2978386166
Drives: x6m50i
Originally Posted by TFresh47 View Post
I'm interested too
sick! what color is that?
BTW I have experimented with setting the engine sound into sporty and putting on sport plus. I would press the gas relatively hard to 3000rpm and upon release I can hear the pops but not very loud. Then if I keep tapping the gas I would also hear it. It is not loud tho. I will change to a catless downpipe in hope to fix that. I hope people can provide easier ways for the pop to occur so I don't have to excessively tap the gas.
      10-14-2021, 10:03 PM   #5
fstezaws
Drives: 2020 911 S — 2022 X5 M50
I don't know if it applies to the G05, but on my F90 M5C, you had to be in sports plus with the exhaust setting on (the latter is not a function on the G05) and then you would hear pops and burbles between 2500-4500rpm upon deceleration, and possibly only from 2-4th gear.
So if I was cruising slow in 2nd gear, and at 4400rpm lifted off the gas, it would pop/burble instantly, every time.
I don't know if the G05 has similar parameters that must be met, but I'm betting that being in Sports or Sports Plus is probably one of them.
      10-17-2021, 06:22 PM   #6
dananelson1
dananelson1's Avatar
226
Drives: 22 X5 45e, 13 X5xdrive50i SOLD
New Exhaust or potentially modify it. . . see below post.
Many people don't like the overly stimulated AMG - sounds like it's trying to hard to stroke egos. It's a fine balance between sounding mean vs. cheesy.
Resonator delate below - sounds like a good balance
https://g05.bimmerpost.com/forums/sh....php?t=1714383
      10-20-2021, 04:14 AM   #7
Ninefourteener
Ninefourteener's Avatar
1346
Drives: 2020 X5 M50i, 2020 Alfa 4C
Burbles and pops need to be coded into the ECU. I've already asked my tuner about it. They can do it, but do not recommend it on a car that has factory catalytic converters.
Noise regulations have caused many manufacturers to make their cars quieter, compared to (essentially) the same car from a few years earlier.
2020 X5 M50i, Alpine, B&W, Air Susp, anthracite, coffee, **CD player**:
15+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019
690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813
6-Piston/4-piston BBK:https://g05.bimmerpost.com/forums/sh....php?t=2097342
      10-22-2021, 02:24 PM   #8
2978386166
Drives: x6m50i
interesting! How come with the catalytic converters?
      10-30-2021, 11:44 AM   #9
nZtiZia
nZtiZia's Avatar
Drives: eVeRyOnE mAD!
whether you tune the ECU or use lower octane fuel, burbles and pops are essentially 'controlled' misfires.
unburnt fuel makes it past the combustion chamber into the cats where it ignites which decreases their life especially when subjecting OEM vehicle components to a situation that's designed to a limited tolerance.
      11-02-2021, 02:22 PM   #10
jsmonet
Drives: 2020 x7 m50i
The afterfire that causes the pops is abusive to the cats. It's "afterfire" because the unburnt fuel ignites after the combustion process and proceeds on out the exhaust. Backfires ignite in the combustion process and flame out the intake--one of the reasons they're so destructive.
You're basically popping a temporary rich condition to overload the combustion chamber's programmed ability to burn fuel so that it passes on through to be ignited in the exhaust, causing the tiny explosion down stream where the cats are
2020 bmw xHippo, v8tt edition
      11-02-2021, 11:48 PM   #11
2978386166
Drives: x6m50i
I see, thank you for your explanation. So would removing the cats itself make the pop louder?
Thanks
      11-03-2021, 10:26 AM   #12
jsmonet
Yeah, and everything would become a little raspier, but there is absolutely no reason to take the cats off a street car, at all, anymore.
      11-05-2021, 03:39 PM   #13
XtremeMaC
Drives: 2022 X6 xDrive40i G06
Is your vehicle ECU tunable???
I did have the new Supra for 3 years with pops on burbles at max with factory cat, no issues. It's tested that way.
If your cat goes bad one day after years, you'll just have to replace it... If you're way too environmentally conscious, well you'd better look for ev, fuel cell, etc. anyhow.
      11-05-2021, 03:56 PM   #14
MOTOP
MOTOP's Avatar
Drives: 2021 X5 M50i, 2018 Raptor
Maybe off-topic, but i'll say this for the first time.
I'm in for iX M60 without farts and cracks.
Hopefully in 2022.
      11-05-2021, 04:03 PM   #15
2978386166
Drives: x6m50i
Interesting. why is that?
I personally already ordered a cattled downpipe, I guess it's too late to change. However I am open to hear any concerns.
      11-06-2021, 11:47 AM   #16
Bearco
Bearco's Avatar
65
Drives: 2022 X5 M50i
My understanding is it used to be removing cats would help performance. Removing modern cats doesn’t help anymore, other than additional pollution with the benefit of sounding a little cooler.
      11-07-2021, 12:29 AM   #17
jsmonet
Yeah. There are better ways to make power now and cat designs are good enough that the difference in peak power isn't enough to warrant the extra emissions. The other reason we used to run test pipes was spool because we had fairly low static cr, which is why "turbo lag" was such a big deal. Modern direct injected setups run much higher static cr and have plenty of off-boost power
xbimmers
