Bimmerpost
4 Series
Technical Topics Suspension / Chassis / Brakes 2020 330i G20 Brake/Caliper Question
      10-07-2021, 07:52 PM   #1
Stove
Drives: BMW G20 330i xdrive
New BMW owner here! I was wondering if anyone could give some advice/info on brake/caliper options for a 2020 330i xdrive with m sport package. I really want to upgrade to the bigger m calipers (red or blue). Just not sure where to begin. Any feedback would be greatly appreciated, thanks!
Current setup pictured.
      03-16-2022, 10:33 PM   #2
DarrylW
Drives: 2018 M4(deceased)2018 M5
There are a couple other threads on this. I’m looking to do the same. There are different size rotors depending weather you have the base setup, M sport brakes or the M performance brakes. I’m still working out the sizes myself so I cant give you a lot of details yet.
I have the same setup as you do. I’m looking to swap the red calipers from my wife's 530 to my 330 and put blue ones on her car
      03-17-2022, 06:56 AM   #3
Chubbiejones
Chubbiejones's Avatar
Drives: 2020 BMW M340i
Originally Posted by DarrylW View Post
There are a couple other threads on this. I'm looking to do the same. There are different size rotors depending weather you have the base setup, M sport brakes or the M performance brakes. I'm still working out the sizes myself so I cant give you a lot of details yet.
I have the same setup as you do. I'm looking to swap the red calipers from my wife's 530 to my 330 and put blue ones on her car
For your reading pleasure:
https://www.bimmerworld.com/M-Sport-Brakes-G20-G22/
I personally have the performance brakes and I after discussions between individuals who have the upgraded sport brakes the difference is negligible for the cost; I am waiting for aftermarket options.
      03-21-2022, 06:50 AM   #4
helmet91
helmet91's Avatar
Netherlands
298
Drives: BMW G20 330i X-Drive M-Sport
Those of us with the crappy 1-piston stock brakes however... The M-Performance is a HUGE upgrade (330x24 to 374x36 on the front rotors; 1 to 4 pistons on the calipers).
I'm getting ready just to pull the trigger on the M-Performance setup. To source the M-Sport setup piecemeal from the dealer actually ends up costing quite a bit more. There is the used route, but I'm not a big fan.
      07-26-2023, 12:30 AM   #5
Two3Series858
Two3Series858's Avatar
Drives: 328i, 330i
2019 BMW 330i   [0.00]
2015 BMW 328i  [0.00]
helmet91 it's been a minute, but did u go with the M-Performance setup? Do u like it? You mentioned it costs more to just go up to the M-Sport upgrade(?)... so its actually twice the benefit to get the better brakes at a slightly cheaper cost? Even if it prices out a JUUUUUST a little higher, that large caliper with the slotted rotors in the front would make it worth it IMO.
Seriously considering this route with $3K to play with
      07-26-2023, 01:56 AM   #6
helmet91
helmet91's Avatar
Netherlands
298
I actually ended up getting an essentially new set of M-Sport brakes off of an M340 with around 500 miles it it… for $1500. Threw in some Turner stainless lines and Motul 660.
The setup is fantastic. It worked amazing on the Ring with no fade the last 1/3 of the lap like I had on the junk stock brakes.
I’ll probably get some Endless pads next spring and go with ECS discs when the time comes.
      07-27-2023, 12:12 AM   #7
Two3Series858
Drives: 328i, 330i
Yeah I saw looking into other threads. I've decided to go with just the M-Sport route also. Sweet deal. I'm hoping to score something within the next few months.
g20
