09-10-2021, 02:33 PM | #1 |
Rep 672
Drives: 2021 M3C
Spacer Talk - Factory Wheel Staggering/What's needed front vs. back for flush etc.
Hey guys,
Looking into spaces for my G80....watched a ton of spacer/G80 vids, and lots of folks going different directions...both because of preference and because of tires we received (Michelins/Pirelli). All that to say I have a couple questions: Has anyone tried a 10mm all around set up? I have the Michelins, and I like the idea of keeping the stock staggered-ness by making the same spacer-adjustment at all four corners...but I know a lot of you are going larger spacers in the front vs rear (e.g. 15mm front/12mm rear)....then some of you are going larger back than front, like "what's your forte," in this video is going 12mm front/15 mm back: Lastly, Turner Motorsport has two "Complete Flush Kits," which are the same spacers, just one is ECS and other is Turner Branded...and those are 12.5mm Front/15mm Back: https://www.turnermotorsport.com/p-1...ront-and-rear/ https://www.turnermotorsport.com/p-3...-g80g82-m3-m4/ I'm really struggling here in figuring out what to get..I don't like the idea of larger spacers in the front than the back, as that would seem to remove factory staggering on the wheels....doing 10mm or 12mm at all corners sounds good, as it pushes all tires out equally, thus keeping that factory staggering....but I spoke with someone at Turner, and they said they tested many spacers and "determined 12.5mm front and 15mm back was the best set up for equal flushness at all four corners," though I forgot to ask with what tires. Again, I have Michelins, and I'm leaning towards 10mm or 12mm at all four corners to keep factory staggering of the wheels while gaining more flushness, but thought it best to run all this by everyone and just get your thoughts on pros/cons with all these options to see if really there is a preferred way to go on the G80. I don't know if 10m or 12mm is enough at all corners or not, and I don't know what is really necessary to get flushness on front vs back. I hope my concerns and questions make sense here...but happy to clarify if needed on anything. Thanks in advance. |
09-10-2021, 02:51 PM | #2 |
Rep 478
You're over thinking this. It isn't going to mess up the ride dynamics and we are literally talking about millimeters here. I had 15/12 on my m3 and am about to step up to an 18mm spacer in the front. To get your wheels to look flush, I'd recommend a 15/12 or a 12/10 for less aggressive fitment.
Medal483.00 |
09-10-2021, 03:36 PM | #3 | |
Rep 672
Drives: 2021 M3C
Did you go with longer lugs or did you go bolts? Thanks for the response; appreciated. |
09-10-2021, 03:55 PM | #4 |
Rep 478
I went with the longer lug bolts. The future classic spacer kit I bought actually came with them. I now have 12mm, 15mm and 18mm and they all came with the appropriate length lug bolts. I will probably switch to studs later on.
Medal483.00 |
09-10-2021, 03:59 PM | #5 | |
Rep 672
Drives: 2021 M3C
Again, appreciate your comment. Just needed the push I guess. |
09-10-2021, 04:36 PM | #6 |
Rep 1,083
I have an M4 G82 with Michelin’s and the 19/20 wheels.
Currently running 15F and 13R from BMS. The setup looks good but maybe poking out a little much for my taste in the back from certain angles. I ordered a pair of 10mm and will try 13F and 10R next. |
Medal483.00 |
09-10-2021, 04:51 PM | #7 | |
Rep 478
Medal483.00 |
09-10-2021, 11:00 PM | #10 |
Rep 672
Drives: 2021 M3C
Thanks all! Since I ordered the turner kit, and has 12.5mm and 15mm spacers, sounds like I should put the 15's in front vs back like the kit says too….good to know and I will certainly try both ways. Just looking at the rear, they obviously need less "correction" than the front but we'll see. I don't think I've seen anyone try this turner kit so I'll most definitely share my experience after final setup. Including if I go with changes in spacers and order more if I don't like either way with the two sizes that come with the kit
Driving: 2021 M3C
Semper FI |
09-11-2021, 06:26 AM | #11 |
Rep 1,383
Definitely put the bigger ones in the front. I have 15's up Front and thinking I could have gone for 18's. The smaller 19' wheel really gets lost up front where as a 10mm spacer fills out the rear quite nicely. You still have the staggered look as the rear wheel is wider, bigger in diameter and concave.
Medal483.00 |
09-11-2021, 01:10 PM | #12 |
Rep 672
Drives: 2021 M3C
Couple more questions, all:
As I said, I ordered this kit: https://www.turnermotorsport.com/p-1...ront-and-rear/ I believe they are steel….though I can't confirm via the product description…but it does say the lug nuts are steel, so I think the spacers are too. Now I'm looking at a stud conversion kit…likely this one: https://ind-distribution.com/product...30859058970693 Question one is, does anyone know if that stud kit and my spacers ordered are ok together? I believe they are both steel and metal-wise, but if anyone can confirm favor me, I'd much bette about order this stud kit. Second question is, is it worth getting this lug kit for the studs? : https://ind-distribution.com/product...19000869879877 Cosmetically speaking, I'm hoping for improvement, but not sure if this type of kit is what I should be looking at or if there are other, stud-lug kits that are better for appearances? Additionally, this lug kit appears to only come as a pack of 16, and I think I would need 20, right? Really appreciate it, all!
Driving: 2021 M3C
Semper FI |
09-11-2021, 06:48 PM | #14 |
Rep 754
Drives: 2022 M3 Competition
ok, potentially dumb question here...
Why put the thicker spacers up front? Is it for maintaining the staggered look while pushing the wheels out a bit? If you're looking for a "flush with the fenders" look it appears that 12/15 is the way to go. Would appreciate the insight here.
2022 M3 Comp BGM/Fiona Red, Executive, Drivers Assistant Pro, Parking Assist, 826M black wheels
(SOLD) 2018 M2 BSM LCI, DCT, Executive, Drivers Assist, CarPlay |
Medal483.00 |
09-11-2021, 07:27 PM | #15 | |
Rep 1,083
So to make them look more flush with the fenders they require a slightly thicker spacer compared to the rear. IND made these great photos to illustrate: https://g80.bimmerpost.com/forums/sh....php?t=1808816 |
HTTP 4102141.50 |
09-11-2021, 07:58 PM | #16 | |
Rep 754
09-11-2021, 08:07 PM | #17 | ||
Rep 672
Drives: 2021 M3C
Anyone that can help me with this I would be grateful..
Driving: 2021 M3C
Semper FI |
09-11-2021, 10:18 PM | #18 | |
Rep 1,083
09-12-2021, 02:12 PM | #20 | |
Rep 1,083
09-12-2021, 04:03 PM | #21 |
Rep 1,410
@voyagergab nice man. I have 13sq on order, should get them by Friday
09-12-2021, 05:38 PM | #22 | ||
Rep 672
Drives: 2021 M3C
Driving: 2021 M3C
Semper FI |
