European Innovations
      08-10-2021, 05:28 PM   #1
IND-Distribution
IND-Distribution's Avatar
10214
Drives: G82 / G87 / G90
IND BMW M Performance G8X M3 / M4 Steering Wheel Install Guide
Tools needed:
  • Socket Wrench
  • 10mm socket (for battery terminal)
  • 16mm socket (for steering wheel)
  • Pick tool (for ground cables and harness)
  • T20 Torx Driver
  • T25 Torx Driver
  • Narrow Flat-head Screw Driver
We also put together a quick video:
STEP 1: Remove trunk floor panel to reveal the battery. Before removing the OEM steering wheel, disconnect the negative terminal to discharge the car using a 10mm socket.
STEP 2: With the car discharged completely, insert a flathead screwdriver into the steering wheel recess. Depress the airbag spring while gently pulling the airbag away from the steering wheel to release it. Repeat this process on the other side of the steering wheel.
STEP 3: Before removing the airbag completely, unplug the airbag connector that tethers it to the OEM steering wheel. Follow by unplugging the black steering wheel control plug from the column.
STEP 4: Use a 16mm socket to remove the steering wheel retaining bolt. Pull the wheel gently towards you to remove completely. For automatic transmission cars, unplug each shift paddle connector and remove two T25 screws that affix them into place.
STEP 5: The OEM trim and contents must be transferred onto the BMW M Performance version. Unfasten two T25 screws from the rear and two T20 screws from the front to remove the carbon steering wheel trim.
STEP 6: Unclip the multifunction controls and the steering wheel heater button and remove the carbon steering wheel trim completely.
STEP 7: Remove the T25 Torx that secure the M1 / M2 buttons to the plastic upper trim. Unclip the wiring harness and remove the plastic upper trim completely.
STEP 8: At the foot of the steering wheel, remove two T20 screws securing the Driver Assist motor module. Subsequently, unclip the wheel heater cable.
STEP 9: Loosen the three T25 screws that secure the airbag baseplate. Brace the plate while unfastening each screw as the plate itself is tensioned via springs. Before removing completely, unclip the baseplate ground.
STEP 10: Carefully unseat the steering wheel harness ground from the steering wheel peg. With all connections removed, unseat and remove the harness cradle completely.
STEP 11: On the new M Performance steering wheel, remove the four included T25 screws and remove the upper alcantara trim.
STEP 12: Installation of the steering wheel contents is the reverse of removal. Transfer and seat the harness cradle into the M Performance replacement and reattach the harness ground.
STEP 13: Reattach the driver assist motor with the two T20 screws and properly seat the black control module on the right side of the wheel. The steering wheel heater plug can be tucked away as the M Performance wheel is not heated.
STEP 14: Reattach the alcantara upper trim piece, reinstate the wiring harness, and secure both M1 / M2 buttons to the upper trim.
STEP 15: Secure the plate to the M Performance wheel with the three T25 screws—pressing downward onto the plate to ensure each spring is equally compressed. Subsequently, reattach the airbag plate ground.
STEP 16: Reattach the carbon steering wheel trim and plug in controls. For Automatic Transmission cars, plug in and reattach the shift paddles with the T25 hardware. For 6MT cars, secure M Performance alcantara covers to fill the steering wheel voids.
STEP 17: Gently press the M Performance wheel back onto the steering column in the same orientation it was removed and secure the 16mm retaining bolt. Plug in steering controls connector and airbag. Press the airbag uniformly into the steering wheel recess until seated.
STEP 18: Reconnect the negative battery terminal in your trunk and check that all steering wheel controls (save for the steering wheel heat) function properly.
chicagofan0020573.50
mzcp3261.50
rgrovr422.50
M4Tejas1101.00
      08-10-2021, 08:47 PM   #2
chicagofan00
chicagofan00's Avatar
Drives: 2024 X5 M60i
Instead of the blue stripe up top, can that be customized to another color?
Current - 2024 G05 X5 ///M60i in Java Green
Past - 2005 E53 X5 3.0i in Titanium Silver; 2008 E92 335i in Montego Blue; 2019 G01 X3 M40i in Glacier Silver; 2022 G80 M3 Competition in Twilight Purple
Limegrntaln14450.00
M4Tejas1101.00
      08-11-2021, 04:59 PM   #3
IND-Distribution
10214
Yes we can change it to another color or even go more extreme like we did for another G8X customer. Full alcantara with red stripe
ggelpi71.00
      08-11-2021, 05:19 PM   #4
chicagofan00
Good to know, thanks!
Might have to consider this wheel with a Twilight Purple type stripe at some point down the road. 😃
      08-11-2021, 11:42 PM   #5
LOW4LYF
LOW4LYF's Avatar
2234
Drives: E92 M3 & F85 X5M
I4 with blue start stop button gets a M performance wheel with red stripe...
G8x with red start stop button has a blue stripe...
Really?
      08-12-2021, 02:10 AM   #6
Limegrntaln
Limegrntaln's Avatar
14450
Drives: 2024 Model S Plaid
When the new wheel is installed, does it index correctly? Ive changed a few wheels on past cars, and "most" cars need the steering alignment redone, which is usually a pain, because most places cant seem to get the wheel back to straight, even if the drive it.
SOLD: 2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou
      08-12-2021, 03:21 PM   #7
LOW4LYF
LOW4LYF's Avatar
2234
It fits in one position only...no alignment needed.
      08-12-2021, 04:47 PM   #8
Limegrntaln
14450
Ok, good. When I changed the one on my C7, it had a notch at the top of the splines. That's the only one that lined up, correctly. The other 3 cars all needed to get the wheel indexed.
YT: G Dubyou
      08-17-2021, 10:06 PM   #9
BadBoostedBMWM3
BadBoostedBMWM3's Avatar
Drives: e36m,F80,G80;TRX; 992 TTS; F95
Very nice… I’d say that I’m creeping up the wrong street, but does this retain the heating function?
This is my signature...
      08-18-2021, 10:24 AM   #10
IND-Distribution
10214
You would lose the heating function.
      08-19-2021, 02:54 PM   #11
///M ARMY
Drives: F90
ill do the full alcantara
2022 RAM TRX
2021 Ford Bronco
2022 BMW M3
      10-22-2021, 06:48 PM   #12
element56
element56's Avatar
1110
Drives: 16 X3 '22 M4XC '23 X3M40i
Is the heating function not available with alcantara? or is it something that would negatively affect alcantara in the long run? why is heating not an option?
Would a "donor" wheel be needed to retain the heating?
      10-22-2021, 07:26 PM   #13
moproblems
Beware of cheap bait!
moproblems's Avatar
731
The OEM Alcantara wheels simply do not have the heating function. You can get your current oem wheel recovered and more than likely retain it.
Limegrntaln14450.00
element561109.50
      10-28-2021, 07:02 PM   #14
Nexus_One
Nexus_One's Avatar
79
Drives: 2020 Camaro 2SS
Any chance of a flat bottom version?
      11-14-2021, 02:33 PM   #15
m20e3087
m20e3087's Avatar
Drives: 991.1 & Bimmer
2019 BMW M2C  [0.00]
Is the MP steering skinner than the OE one?
      11-14-2021, 06:21 PM   #16
jpsimon
Team Zissou
jpsimon's Avatar
Drives: 2022 AWD M3 Comp - SMB
The F80 m-performance one is thicker than stock. I would think it’d be the same here but maybe not. It’s definitely one of my favorite mods I did for sure, I’ll be picking one of these up for the G80.
      11-15-2021, 10:27 AM   #17
kbkura
Drives: 2019 BMW X5, 2021 BMW M4
It's tough to get over losing the heating function… probably one of my fav features. Maybe worth getting a custom alcantara wrap on the existing steering.
      11-18-2021, 06:29 PM   #18
element56
element56's Avatar
1110
Exactly what I am hoping to do. Would like to "donor" my wheel to get it done, but don't want to be without the wheel for obvious reasons. (and the car hasn't even finished quality check yet )
      11-20-2021, 01:22 PM   #19
mgokev
Drives: 2022 BMW M3 Competition xDrive
Looks great — losing the heating function is a non starter for me though. But if you all end up selling the precut alcantara/leather wrap with contrast stitching and thread, I'd buy and try stitching myself.
Any plans to sell just the wrap for the stock G80 wheel?
2017 Audi S3 APR Stage 2 (sold)
2012 BMW 135i Dinan Stage 2 (sold)
2008 BMW 135i (sold)
      11-20-2021, 04:56 PM   #20
m20e3087
m20e3087's Avatar
2019 BMW M2C  [0.00]
Check out Coby Wheel.
      11-22-2021, 08:52 PM   #21
Yas_sir
Yas_sir's Avatar
398
Drives: G80
It was actually one of my favorite mods for the f80 too.
Wish the performance wheel was thinner and smaller in diameter though.
/// Santorini G80 6MT
Pics and stuff
      11-23-2021, 08:59 AM   #22
jpsimon
Team Zissou
jpsimon's Avatar
BTW for anyone worried about losing the heating functionality... the alcantara doesn't feel as cold as cold leather. You won't miss it
RockinPA4894.00
bn_gm20.00
Search this Thread:
Advanced Search
