      08-10-2021, 11:32 AM   #1
Mani59
BMW Miniature Collector!
United Kingdom
13453
Drives: E38 735i SE Individual
BMW M - How-To. Adjusting M Traction Control in your BMW M.
Learn in this video how to configure and adjust the the M traction control with the optional equipment M Drive Professional in the BMW M3 and BMW M4 and their Competition models.
Visit my (mainly) BMW gallery http://jetone.co.uk
CadHater766.00
F85MTuNED1620.50
SYT_Shadow11462.00
      08-10-2021, 02:02 PM   #2
iviegatron
iviegatron's Avatar
Drives: G80 M3
I thought the M traction control is there by default (without any optional package) on the non X-drive models. Is that not true?
      08-10-2021, 02:06 PM   #3
dimmy
Drives: 2022 M3 Comp AWD IOMG
Not true. You still have to add M Drive Professional to have access to it for both Competition and Competition xDrive.
AndrewC198910910.50
LLNM4180.50
      08-10-2021, 02:57 PM   #4
iviegatron
iviegatron's Avatar
Drives: G80 M3
Well that sucks. Too late to add it to my build now. Hopefully it's just a software update.
      08-10-2021, 03:29 PM   #5
///M TOWN
///M TOWN's Avatar
Drives: M GmbH
2018 M2  [8.78]
Or potentially done with simple coding
LLNM4180.50
spridge643.00
      08-10-2021, 04:58 PM   #6
M_Adaptive
M_Adaptive's Avatar
Drives: E92 M3, 2022 G82 M4 AWD
You do have traction control. It’s different with the M drivers package or whatever its called. That mode gives you the option to set the traction control from 1-10. You cannot do this without the package. Without the package you can either have traction on or off.
IG: Adaptiive_M
E46 M3 (Sold)
E92 M3
2022 G82 M4C Xdrive
      08-10-2021, 05:03 PM   #7
Solarium
Drives: 2016 BMW M4
I read someone asked their dealer and it was not possible via simple software upgrade. I didn't add it to mine either, since the only time I want to do RWD is when I want to completely turn it off. But now FOMO has gotten me and I can't help but wonder how much that 10 step traction control can help during slides.
      08-10-2021, 05:28 PM   #8
swampfox94
swampfox94's Avatar
1187
Drives: 2020 F87 - M2 Competition
The 1-10 traction levels is definitely my favorite new feature. Seems like a great way to build up your control. Coming from someone who is just tipping their toes into mdm on the f87 it's a bit scary lol
      08-10-2021, 05:31 PM   #9
MHOW996
MHOW996's Avatar
306
Drives: 2021 G82 M4, 2022 Ford Bronco
That is the one option I wish my car had. Let's see if it does become a software upgrade in the future.
      08-10-2021, 06:13 PM   #10
_E90S65_
_E90S65_'s Avatar
736
Drives: 2021 M340i
Thankfully, not another vertically-shot video.
      08-10-2021, 07:59 PM   #11
Ibiza
Ibiza's Avatar
Drives: 22 G83 comp & 2024 X5 M60
I spec'd for my pending G83 build--which is probably overkill for a vert.
2022 G83 PCD & 2024 G05 S68 PCD
Retired:2021 F95 ZCP PCD,2018 F85 PCD,2018 F83 ZCP- ED/PCD, 2015 X5 50i PCD, 2015 435 vert ED, 2011 X3 PCD, 2011 335is vert ED/PCD, 2007 X3is PCD, 2007 335i vert PCD, 2004 328i vert PCD
      08-10-2021, 08:39 PM   #12
iviegatron
iviegatron's Avatar
Drives: G80 M3
Is this option grayed out in the iDrive if the car is not equipped with the M drive professional package?
Hopefully I'm not mistaken but I recall seeing the 10 stage traction control setting on the base vehicle that did not have the M drive package on the window sticker. The option was there just grayed out and I couldn't move the slider. If that's the case I'm hoping all it takes is a software update or coding to enable the feature.
      08-10-2021, 10:12 PM   #13
KevinGS
Drives: Past 2015 M4, Current 2013 M3
Since I lost the tire lottery and didn't get the Michelins, I've been playing around with the 10-stage traction control late at night on an abandoned warehouse parking lot. I figure I may as well learn how to use it now with tires I care less about. And it's brilliant in its execution, but you certainly need to practice in a closed environment or a track, not on public roads.
But once you understand how the car will respond with various throttle inputs at the different stages of TC, you can have some fun on certain roads like on-ramps and off-ramps (with no vehicles approaching you).
The BMW engineers should be applauded for giving us the video-game like option in a $75,000 M3. And the fact that it will rate drifts is just remarkable, hard to believe this made it past BMW's legal department.
      08-10-2021, 10:16 PM   #14
CanAutM3
General
CanAutM3's Avatar
Drives: 2021 911 turbo
Don't confuse Traction Control (TC) and Dynamic Stability Control (DSC). The former only uses engine power output management to control rear wheel slip, the latter uses individual brake application at the different wheels to regulate yaw angle.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black
      08-11-2021, 02:19 AM   #15
thaalrasha
Drives: G81
What color on the video ? It has some copper / bronze color but it's not as bright as zanzibar either.
I'd like some clarification too... i'm sure i've seen the option on cars that were not speced with the M driver's package... Car was not started but i could see the 10 step traction controls on the Xdrive model which by the way requires DSC OFF in 2WD mode to be enabled.
edit: I figured it out, for ireland / UK cars, the option 1MB "M Drive Professional" is listed under standard equipment. That's why it didn't appear as on option on the cars I was looking at at the dealership. Saw the standard equipment set on the full quote print out.
      08-11-2021, 09:32 AM   #16
jmg
jmg's Avatar
18650
Drives: G82 M4C X-Drive
2022 G82 M4C X-Drive  [9.85]
2018 F80 M3 CS  [9.87]
2019 i3 BEV  [0.00]
Or just turn off traction control completely and learn the limits in a controlled environment.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing
Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3
IG: Raging_G82
      08-11-2021, 09:55 AM   #17
calbears
Drives: 2018 F80 M3 CS,2017 F87 LBB M2
2011 M3  [10.00]
2017 M2  [10.00]
2018 M3 CS  [10.00]
It may be Oxide Grey
2018 F80 M3 CS
2017 M2, LBB, DCT, exec, car play, MPE, diffuser
2011 E90 M3 ZCP
Past: E90 328i, F10 535i, F80 M3 (murdered)
      08-11-2021, 10:31 AM   #18
thaalrasha
Drives: G81
I don't think so, oxide grey doesn't have those bronze / copper reflection in the sun. I'm now leaning towards sepang bronze..
      12-23-2021, 12:48 AM   #19
aaron.ricci
Drives: AMG c63s
How are you holding up without it? Curious as a build I am following doesn't have this option. Have you been sliding around?
      12-23-2021, 12:49 AM   #20
aaron.ricci
Drives: AMG c63s
Have you been utilizing the setting fully off for the most part on a few slides or setting 3/4? Extremely close to purchasing a vehicle without this option, I really wanted it.
      12-23-2021, 01:18 AM   #21
iviegatron
iviegatron's Avatar
Drives: G80 M3
No sliding around. Surprisingly, the traction on the RWD is really good. I have had AWD cars in the past and sometimes it feels like my M3 is AWD even though it's not. I have more confident exiting out of turns at high speeds.
Search this Thread:
Advanced Search
