04-21-2021, 01:09 PM | #1 |
Rep 102
IND Spacers 15mm buyer beware
All, got 15mm spacers up front and just installed them and they make the tire rub against the wheel well liners please see pictures.
I spoke to IND since their website doesn’t mention any issues. Their response was that they hadn’t tested/driven their car enough so they had no complaints. As you can see it broke two tabs from the fender lining this was while backing out with some steering. IND said they aren’t willing to swap them out for a smaller size since they aren’t returnable. Just a heads up to anyone wanting these 15mm up front will rub with the stock wheel and tire. Cheers |
04-21-2021, 09:03 PM | #2 |
Rep 630
Drives: 2021 G80 M3
Thanks for the heads up I had these in my cart today. What tires came stock for you?
04-21-2021, 09:48 PM | #4 |
Rep 2,163
Many thanks, Space, for the PSA. Much appreciated. 12mm fronts for me then, for my M4 (because I believe the front fender widths are identical between the M3 and M4). That's just too close for comfort for me.
Osheatwo206.50 |
04-22-2021, 04:11 PM | #7 |
Rep 102
04-22-2021, 04:21 PM | #8 | ||
Rep 2,163
I figured if Pirelli's rub, then definitely Michelin's would rub. |
04-23-2021, 01:11 AM | #9 | |||
Rep 315
KevinGS3359.00 |
04-24-2021, 07:30 AM | #10 | |
Rep 1,607
"Beware of false knowledge; it is more dangerous than ignorance."
04-24-2021, 09:36 AM | #11 |
Rep 102
I agree, but to be honest I’m done arguing/dealing with situations like these, I just move on. I wrote the post as a heads up not a company bashing post. I mean people are able to formulate their own opinion from this. And that is sometimes the better outcome, let the consumer make decisions based on real customer/seller interactions.
04-24-2021, 12:10 PM | #12 | |
Rep 1,607
I did see that 12mm/12mm seems to be the best combo anyways.
04-26-2021, 01:29 AM | #13 | ||
Rep 67
The Dream is free, the Hustle is sold separately.
04-26-2021, 05:58 PM | #15 |
Rep 1,255
i have 13mm in the front with pzeros and even those are rubbing a little in reverse when cutting the wheel sharply. I dont think they are going to snap off any of those tabs but it definitely touches that protruding part of the wheel well.
04-26-2021, 09:33 PM | #16 | ||
Law Enforcer
25090
Rep 22,283
Penguino1605.00 |
04-28-2021, 03:22 PM | #17 |
Rep 11,374
Wanted to address a few of the concerns in this post. We have been a sponsor of Bimmerpost for many years and will always take care of the members no matter what.
First. IND does not build any spacers. The brand you are running is from Future Classic and are the best spacers produced on the market in terms of build quality and motorsport testing. They are one of the only spacers brands on the market that come with extended hubs bolts on top of the black extended lugs bolts. They are made right here in IL and all design and testing is completed by Fall-line motorsport. https://ind-distribution.com/collections/future-classic Second. The iND wheel spacer information thread was based on the G82 M4 that we own. We created this thread to assist the community and offer some guidance based on the factory ride heights. I'll be updating the thread after the KW HAS kit install and give insight on spacer recommendations after we lower the car. Any G80 member on here is more than welcome to chime in and help the community. For example, 15mm fronts on a G80 with pzero causing rubbing issues in reverse. This kind of information should assist the community and not be used to put down a company on this new platform. https://g80.bimmerpost.com/forums/sh....php?t=1808816
04-28-2021, 03:30 PM | #18 | |
Rep 1,607
I'd expect a vendor to honor any issues if I were to purchase their recommended spacer size. From a customer's point of view, I'd be much more inclined to continue doing business and recommend business to a shop that steps in and takes care of a customer, specially with such a small ticket item that's sub $100. Even more so when the fitment is being recommended by the vendor as the "most popular" and broke some of the inner suspension panels on the customers car. "Sorry about that, this is a new platform and we are still experimenting, we'll be happy replace it for a 10 or 12mm spacer if you'd like, at not cost to you". That would get you 10X more business.
13
Sedan_Clan25089.50 sk3let0nz80.00 ONE1125.00 DandyDan25.50 Ftpohyeah285.00 amzbimmer299.50 BIGW0RM3156.00 nathanm4683.00 Zirenz20061542.00 DS_BMW1603.00 Flying051305.50 dirtyfreebooter340.50 TypeDre111.00 |
04-28-2021, 03:33 PM | #19 | |
Law Enforcer
25090
Rep 22,283
04-28-2021, 03:42 PM | #20 | |
Rep 11,374
SetAlias223.50 |
04-28-2021, 04:02 PM | #21 | |
Rep 11,374
04-28-2021, 04:03 PM | #22 | ||
Rep 1,607
