Login
04-05-2021, 10:01 AM | #1 |
BMW Miniature Collector!
![]() 2855
Rep 6,593
Drives: E39 530i Champ. & E46 330i Inv
M Traction Control. M3 and M4 - explained, Episode 17
![]() Featured on BIMMERPOST.com
![]() My (mainly) BMW gallery: http://jetone.co.uk Previous : E90 ///M3 | F20 M135i | E63 630i | E65 730d | Plus many 3 and 5er's |
04-05-2021, 01:10 PM | #3 |
///M Powered for Life
![]() 7659
Rep 7,868
That's one consistent feedback for sure, it puts the power down very very well
04-05-2021, 01:15 PM | #4 |
Facts matter
![]() 130
Rep 130
This video seems to provide a very clear explanation for why the G80 puts down power so much more effectively than the previous generation. Essentially, it seems to be down to a faster reaction time to changing CoF.
04-05-2021, 01:17 PM | #5 |
![]() ![]() ![]() ![]() 306
Rep 605
pretty wild they went down his much of a rabbit hole with developing the RWD traction control system with AWD model in the pipeline, impressive I have to admit.
04-05-2021, 02:14 PM | #6 |
![]() 773
Rep 1,016
And they also limit full torque being available in lower gears at lower speeds.
But I don't mind that at all. And I'm so psyched about the 10-stage traction control. I can't wait to teach my girlfriend and niece how to drift with this new BMW system, since both are so very interested in high speed cornering and drifts. This new M will make it quite easy for them to get the hang of it. Brilliant, BMW, brilliant... ![]() ![]() And if Pirelli's come on my M, they won't last long. I'm going to burn those babies down to the chords at the track, with my Michelin's waiting in the wings. ![]() |
04-05-2021, 02:38 PM | #7 |
![]() ![]() 1489
Rep 1,850
Drives: 2021 M340 xdrive w/MPE
I would be willing to bet the AWD model also benefits from all of this research and tech. Where the RWD model has engine, trans, individual wheel brakes and the rear diff as levers to control the car, the AWD model adds the center diff to the equation to help balance the power front and rear. As I understand it M xdrive does not run separately from the traction control, just like the M diff on RWD models it is an integral part of the traction control.
04-05-2021, 03:26 PM | #8 |
![]() ![]() ![]() 287
Rep 509
I think M division learned their lesson with the F80's terrible traction issues, that a more dynamic traction control system was necessary to control all that power. It also helps that they totally shifted the low end hp/tq to the midrange (once the car is at speed).
There's really no way to cure the problems with the F80's power curve although getting the GTS engine tuning does help a bit. |
04-05-2021, 03:37 PM | #9 |
![]() 3605
Rep 2,310
These guys really are insane and I really do love them for it. No one else is doing this.
Fire Orange 6MT G80 On Order
M3 CS with M Perf Exhaust Retired - Yas F80 - 6MT - Hex Stage 1 - MPHAS |
04-05-2021, 04:14 PM | #10 |
![]() ![]() ![]() ![]() 156
Rep 494
I'm still confused how this compares to MDM. Yeah, M traction level 1 allows for way more slip. How about levels 9-10, how do those compare to MDM?
2008 E90 M3
2015 M3 (ED on May 26th, 2015) 2022 G83 (planning on ordering soon after SOP) |
04-05-2021, 04:30 PM | #11 |
Luxury at the redline :)
![]() 6484
Rep 6,419
The braking, traction, e-diff, ect. is now all electronically actuated, instead of hydraulically controlled, which now allows them to individually modulate the vehicle's stability and traction with a lot more precision and end-user fine tuning abilities.
QuarterMileJoe7.50 |
04-05-2021, 05:04 PM | #12 | |
Rep 494
2008 E90 M3
04-05-2021, 05:16 PM | #13 |
![]() ![]() 4536
Rep 6,424
“Integrated actuator contiguous wheel slip limitation.”
So that’s the secret sauce. I’d like to see a sketch of that to understand more of How this differ from the F8X limited slip M eDiff? Has TC moved into the eDiff as an integrated solution? As for MxDrive I’m sure it can take full advantage of this new/improved feature in the same way it does include the M active differential on the M5. Last edited by solstice; 04-05-2021 at 05:25 PM.. |
04-05-2021, 05:57 PM | #14 | ||
![]() 6484
Rep 6,419
Since the brakes are now electronically actuated, the slippage, yaw, vehicle angle, ect. can now be instantly modulated, allowing for a higher-level locking intervention to stabilize and enhance the vehicle's dynamics. Google the words "BMW DSCi" to learn more.. https://www.press.bmwgroup.com/globa...rs?language=en . |
04-05-2021, 07:13 PM | #16 | |||
Rep 494
2008 E90 M3
04-05-2021, 07:15 PM | #17 | |
![]() 91
Rep 246
It does help explain why the G80 is so much more planted than the F80 for sure though. This is definitely the greatest improvement generationally from F80. |
04-05-2021, 08:00 PM | #18 | ||||
![]() ![]() 1051
Rep 1,083
Waiting for the AWD G80 M3
![]() Current Ride: '14 335i M-Sport ![]() |
jimbethesda155.50 |
04-05-2021, 08:09 PM | #19 | |||||
Rep 494
Will I stop using MDM all together since now I can fine tune the setting? Are they completely different?
2008 E90 M3
04-05-2021, 10:26 PM | #20 |
Rep 13
I'm not planning to track this car, so I didn't get the "M drive professional" on my build. I've looked through the menus and I'm guessing MDM offers me a 5 on the 0-10 scale of the traction control.
So basically 3 settings instead of 10 in this spec? (on - 5 - off) I have to say I'm a little more confused after watching this video than before. Does anyone have any additional personal experience or insight on the other setups not covered in the video? Thanks in advance! |
04-05-2021, 10:39 PM | #21 | |
Rep 494
2008 E90 M3
04-06-2021, 05:34 AM | #22 | ||
![]() 3605
Rep 2,310
I stand corrected.
