03-31-2021, 10:04 AM | #1 |
BMW Miniature Collector!
13490
Rep 7,987
Rear Axle Transmission. M3 and M4 - explained, Episode 16
03-31-2021, 10:15 AM | #2 |
Rep 1,048
I followed this until about 5:00 when he talked about his favorite detail - the left output shaft being slightly larger. I thought nothing that followed even began to address what?, why? or how?
03-31-2021, 10:40 AM | #3 | |
Rep 1,083
I believe it's angular momentum in physics
14
Scorp!on1511.50 ryanb0655.00 ando2000.50 ParkNuts99.00 upsidedownfunnel1996.00 houbmw65.50 Zirenz20061542.00 DecemberStorm590.50 untiedshoes4.50 Ibiza3611.50 tbaig79.50 dappercivility203.50 Kevin_The_Clean13268.00 floating.spirit1017.00 |
03-31-2021, 11:09 AM | #4 | |
240
Rep 241
03-31-2021, 11:11 AM | #5 | ||
Rep 313
03-31-2021, 01:00 PM | #6 |
General
21117
Rep 20,741
Drives: 2021 911 turbo
Actually he does explain it fairly well, albeit in very technical terms. What I understand is that the two output shafts are designed with a different stiffness to minimize harmonic behaviour in lower traction conditions; read reduce axle hop.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 04-01-2021 at 02:10 PM.. |
ornicar136.00 Ibiza3611.50 KoenG1428.50 ashtaron141123.00 djbonsu113.00 irunalot1518.00 agentrnge380.50 floating.spirit1017.00 |
03-31-2021, 03:38 PM | #7 |
Rep 1,522
Yes, should be spot on. The torsional rigidity is higher for the left axle, leading to different harmonic behaviour both in amplitude and frequency, avoiding under equal load (diff lock) both axles amplify each others distortive dynamics resulting in hop. Is indeed a clever trick!
CanAutM321116.50 floating.spirit1017.00 |
04-01-2021, 02:41 AM | #8 |
Rep 3,912
This is one very VERY advanced differential.
1998 E36 M3 - Totaled
2003 E39 M5 - Gone but not forgotten 2011 E90 335i M-Sport - Daily Driver 2017 F87 M2 - Sold & missed 2020 F97 X3 M Competition - Finally arrived /// |
04-01-2021, 04:56 AM | #9 |
Luxury at the redline :)
9105
Rep 7,563
Yea, it's a pretty good electronic LSD unit but don't let this video make you believe that it's something new; it's literally the same identical technology used in the F8Xs M cars, of the last generation.
F80 M3 / F82 M4 Active M Differential: Deep Dive and Interview https://f80.bimmerpost.com/forums/sh....php?t=1018024 . |
Poodle64.50 floating.spirit1017.00 |
04-01-2021, 05:22 AM | #10 |
Rep 9,709
From some of the comments made by journalists in that the G80 seems to be able to accelerate even with high yaw angles (better than F8x), I was expecting to see some torque vectoring technology. Twin clutch packs. But nope, just the same carry over diff from F80.
The programming that controls diff function is extremely important, perhaps they have taken this to another level? Or maybe it is a just the wide 4S that helps. |
04-01-2021, 06:07 AM | #11 | |
General
21117
Rep 20,741
04-27-2021, 06:15 AM | #13 | |
Rep 3,337
Cadillac discovered that if they employ the proper ratio of torsional stiffness between the two IRS half-shafts (based on that huge number of variables overall dynamics problem), they can allow for absorption/release (so to speak) of said energy and greatly reduce the cyclic build-up/release cycle. Said design was first on the gen2 CTS-V but then also shared with other GM cars with an IRS.
Current Stable:
2024 G20 M340i Melbourne Red/Cognac 2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg 2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8 |
04-27-2021, 06:18 AM | #14 | |
General
21117
Rep 20,741
Maybe axle hop was more of an issue on the G8X so they had to remedy it.
