NW Carbon Haus
      03-25-2021, 03:35 PM   #1
Saturatedfat
Drives: BMW M3
Mirror Tap
Anyone know which wire to tap for switched power (off when car is off). I tapped the red/black wire but it looks like the radar detector is still on after the car turns off.
Update: Never mind, apparently it turns off after a few minutes.
On the big connect it's the left most (brwn/blk for ground and right most reddish/pink for 12v). All the trim pieces pull of relatively easy.
vitipr176.50
M4Tejas1061.50
      04-01-2021, 09:41 PM   #2
Davem4
Drives: Bmw g82 m4 comp
Thanks for the info, going to hook up mine tomorrow since the 12v plug doesn’t work in mine
      04-18-2021, 01:04 PM   #3
Saturatedfat
Drives: BMW M3
Someone asked so here are. Couple pics
m20e30871225.00
HK485.50
nptguy124.00
sleepdoc259.00
Mpire55.50
m2for2282.50
      04-26-2021, 12:02 PM   #4
m20e3087
m20e3087's Avatar
Drives: G87
2019 BMW M2C  [0.00]
Saturatedfat did you remove the big plug? I can't seem to get mine off.
      04-27-2021, 11:02 PM   #5
Saturatedfat
Drives: BMW M3
Nah, couldn't get it off and my car was hot af and kept burning me lol. Just tap it while it's plugged.
      04-28-2021, 08:39 AM   #6
moproblems
Beware of cheap bait!
moproblems's Avatar
726
Found this out when I tried to use a radar detector in my car for a long drive. It turns out the 12v port is much deeper than normal, and the center pole of the 12v adapter can't touch the bottom. I balled up some aluminum foil and just sent it, seems to work just fine for now.
      04-28-2021, 10:20 AM   #7
chris3g
chris3g's Avatar
3030
Drives: 2023 M3 xdrive
i had the same issue with my front 12v port, first i managed to blow the fuse messing around with it and had to find and replace it (fuse 46 in the front passenger fuse box btw), then ended up adding a little solder to the tip of my charging adapter to make it touch.
      05-02-2021, 12:35 AM   #8
HK4
Drives: 2008 Scion TC, 2023 G80 M3
took mine to dealer yesterday and they were able to swap out that screw at the bottom of the 12 v port. The new screw is 1-2 mm longer than the original.
themnmd1714.00
      06-09-2021, 07:44 PM   #9
barryc365
Drives: BMWM3
Is it hard to take the cover off? Any tools required to avoid breaking clips ?
      06-09-2021, 10:54 PM   #10
vpvasquez11
Drives: 2025 M3
I used these from Amazon and had no issues removing the cover and did not break any clips.
      06-10-2021, 10:45 AM   #11
Molina330
Molina330's Avatar
Drives: BMW M4 2021
I noticed that top part is hot as &$@'. Why is that part on top of mirror so damn hot.
      06-22-2021, 05:15 PM   #12
kwilliams312
Drives: 2021 G80 M3
I can't seem to get the mirror cover off, what direction should I be pulling/prying to get it to release? the 2 halves seem to be attached pretty well.
      06-22-2021, 06:58 PM   #13
barryc365
Drives: BMWM3
I used a flat tool to separate them, they just pop off with a little pressure. No clips broke when I gently forced them apart
      06-22-2021, 07:32 PM   #14
snareman
snareman's Avatar
10365
Drives: ///M8 & X5 ///M60
A video on this would be handy
Current: 2023 ///M8 ||| 2025 X5 ///M60
Retired: 2023 X3 M40 ||| 2021 M4 ||| 2018 M4 ||| 2017 M4 ||| 2014 435 ||| 2009 335 ||| 2007 335
      06-23-2021, 01:08 PM   #15
Asindhidude
Drives: G80 6MT. Brooklyn/Fiona
Subbed for possible video. Appreciate the help.
      06-23-2021, 01:46 PM   #16
Telly9987
Just a guy with a heavy foot
Telly9987's Avatar
Drives: G80
I actually tapped into the Red connector behind the black. Gave me more room to coil up and hide the extra wire. Works flawlessly
Limegrntaln14257.00
      06-27-2021, 11:35 AM   #17
rottenit
Drives: Acura MDX
It's pretty straight forward the shell is 2 pieces that wraps around the electronics attached to the windshield. I used an ifixit pick: https://www.ifixit.com/Store/Tools/i.../IF145-123?o=2
Starting at shell's seam furthest from the mirror insert the pick and move it toward the mirror it will pop apart the clips. I had to tilt the mirror to get in on an angle to pop the seam that is right behind the mirror. Once the seam clips are popped off you can separate the shell.
      06-30-2021, 09:30 AM   #18
tsixtial
Drives: M
What’s a few minutes? I left my car on lock what it felt like 3 minutes and it didn’t power down. Does your start when you turn on your car? Mine doesn’t I have to manually power on.
      06-30-2021, 01:01 PM   #19
modat
Drives: 2022 IOMG M3 Xdrive
should shut off around 6 min?
Which detector are you using? If its the valentine 1 Gen 2 then there is a known issue around it automatically powering on.
      06-30-2021, 01:52 PM   #20
tsixtial
Drives: M
6 minutes!?! that an awful long time.. i will have to test that.
I have the Valentine 1 Gen 2, but I have the manually turn it on when i drive the vehicle is that because its not connected to the ignition fuse box?
      06-30-2021, 06:50 PM   #21
modat
No. It's an issue with your detector.
When you turn the car the power is being delivered to the radar, but it's not automatically turning on. If there was a wiring issue it wouldn't turn on at all
      08-02-2021, 04:00 AM   #22
Limegrntaln
Limegrntaln's Avatar
Subbed for more info. I need to hardwire my detector when I get my car. I don't leave home without it. I have an R7 in my commuter, Ill probably get another one.
YT: G Dubyou
