BMW M2 Forum > Regional Forums > USA - Northwest > time-lapse overview of the S55 crank hub upgrade!
      03-01-2021, 12:08 PM   #1
BMW DIY Guy
BMW DIY Guy's Avatar
Drives: 2019 M2 Competition
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
Hey yall! I wanted to share out my latest video made in coordination with the amazing Ivan Hernandez and BimTech PNW!
Knowing I am going to jump up power on my F87, I knew I wanted to upgrade my crank hub as a means of (relatively) cheap insurance, or at least peace of mind. I spoke with Ivan, enthusiast owner of Bimtech here in the PacNW. He agreed to let me film the whole experience, to highlight was a detailed piece of work this is, plus its neat to watch!
I picked up the RK Autowerks 4pin billeted crank hub from Kies Motorsports, and rushed up to Ivan to get the job done.
I am truly impressed with the quality of work he does, and if you have an S55 anywhere in the Pacific Northwest (and more) and want this done, I enthusiastically endorse Ivan!
(plus.. the new tradition of bringing lunch when they work on your car.. he works his tail off, feed the man!)
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy **
'Nimona' G87 M2 Build Thread
'Lillith' F87 M2 Competition Build Thread
omasou2088.00
      03-01-2021, 01:08 PM   #2
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
OMFG. I didn't realize how they gut the car to do this! Plus this solution requires drilling the crank and two of the holes blew threw the edge (8:01).
So besides the labor, it also requires an oil change, coolant change, new valve cover gasket, new oil pan gasket and alignment! Hell no, stock is just fine for "me".
Thanks for the video that was really informative but I didn't see how this is an improvement. Are the 4 screws that go into the holes what holds it in place?
marcw584.00
      03-01-2021, 01:15 PM   #3
robertm
Drives: 2020 M2 Comp
Haven't had a chance to watch your video yet but thanks for putting it together. Crank hub fix install is a long process. I've worked on all generations of BMWs from e30 to e90. This job is too big for me though and best left to the professionals. It's the only safe way to go if you plan to add power!
      03-01-2021, 01:20 PM   #4
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
What's the cost of this anyway? I mean total. Drop off, pick up, done = $________?
      03-01-2021, 01:41 PM   #5
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
Keep in mind in the drilled picture, you are seeing the hole template disk still in place, to guide the drill for perfect alignment. If you look at the pic of a 4 pin hub, the pins press into those holes, so the front hub can never spin. The back hub is keyed into the first, so IT can never spin either.
Huge improvement as it removes the chances of the crank hub spinning ever.. I can easily see me at 50% or more over stock power, so really cheap insurance at that point.
omasou2088.00
      03-01-2021, 01:45 PM   #6
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
Figure start at $3k in your head and hopefully come out better than that.
VisualEcho6636.50
      03-01-2021, 02:14 PM   #7
marcw
marcw's Avatar
Drives: 2021 M2 Competition
That seems cheap. The part alone is $1299. You telling me you got 3 days of labor for only $1700 or roughly $70/hr?
2021 M2 Comp
2019 330i xDrive SportsWagon (For Sale)
2014 Jaguar F-Type S V8
Retired: 2016 328i xDrive SportsWagon, 2010 Z4 sDrive 35i, 2006 530 xiT, 1999 323i
      03-01-2021, 02:25 PM   #8
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
No.. I am ballparking as it really depends on where you are and who does the labor. As a generic number, I would use $4k as closer myself.
      06-11-2021, 09:05 AM   #9
pal
pal's Avatar
433
Drives: Z4 M Coupe
Thanks for the time lapse OP and setting expectations on how intrusive and involved this job is.
Looking at pictures on their site, the holes in the crank can get pretty close to the edge. But, I suppose the load is along the radial edges of the holes so less of a risk of chipping the super thin wall of the crank and ingesting metal.
https://pnwn54.com/s55-crank-hub-upgrade
[IMG]https://img1.wsimg.com/isteam/ip/99b...0E52FEFC8.jpeg[/IMG]
      06-11-2021, 01:31 PM   #10
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
Thanks and I had no CLUE of how insanely complicated the process really was until we got into it.
Keep in mind the whole come from a template provided by the crank hub source.. in my case, the holes are very tight to the inside rather than on the outside like the shot you shared.
m2
