02-05-2021, 05:03 PM | #1 |
Rep 636
Alarm going off
Wondering if this happened to anyone? when I opened the trunk without unlocking the car but with key fob in my pocket, the car alarm went off. When I did the remote view on BMW app , the alarm went off....
?21 X3M Comp
'18 M3 Comp '15 M4 coupe '12 M3 coupe '09 335xi coupe '07 328xi coupe |
02-06-2021, 01:10 PM | #2 |
Rep 192
Nope. I've had no such issues & do that regularly. Perhaps you inadvertently hit the alarm button on your fob?
2021 Cayenne GTS * 2021 AMG GLE 63
2019 911 Targa 4 GTS, Carrara White Metallic 2008 911 Turbo Cab, Speed Yellow 1997 911 Targa, Zenith Blue 2017 GT3-RS Lava Orange (LEGO) |
02-07-2021, 11:20 AM | #3 |
Keep it clean
111
Rep 209
I've had the same issue many times. It even happens when I have the key in my pocket and touch the door handle to unlock it. I've been meaning to look into this because it's very annoying.
02-07-2021, 12:28 PM | #4 |
Rep 636
I thought that too and tried again and had the same thing happen with the key in my hand instead of pocket
?21 X3M Comp
02-07-2021, 12:30 PM | #5 |
Rep 636
I haven't had it with the doors itself ... only the trunk ... I'm wondering if there is some weird interference in my garage ... I haven't got a chance to try it outside of the garage to test the theory
?21 X3M Comp
02-08-2021, 02:05 PM | #6 |
Rep 636
it looks like it only does this in my garage so I'm guessing some weird interference ... will just have to remember to always unlock the doors first before opening the trunk in the garage
?21 X3M Comp
07-27-2021, 08:57 PM | #7 |
Rep 636
Finally figured this out.. FYI in case anyone else had this issue.. it turns out it was my v1 savy in the obd port causing the issue … I had to turn off obd alarm via bimmercode and this fixed it.. no more alarm when opening the trunk without unlocking the car
?21 X3M Comp
07-29-2021, 12:01 PM | #9 | |
Rep 636
This is the setting to turn off: OBD alarm The alarm is triggered when the vehicle is locked and communication via the OBD port is detected. Please note that this function requires the car to be equipped with an alarm system. Values: Active Not active Requirements: "Roof Function Center" FZD__35 control unit
?21 X3M Comp
usu335i110.50 |
07-30-2021, 07:34 AM | #10 |
Rep 96
I sent my 550 to dealer for exorcism… the alarm went off three times while parked in one day. The horn honking alarm would shut down with keyfob… but the screeching siren continues untill I drive it 1/4 mile! Anyone had an unresponsive alarm demon… only thing worse than alarm is the courtesy vehicle is an I3. 😂
