12-30-2020, 02:22 PM | #1 |
Rep 21
Sloshing noise in the background... What is causing it?
I have a humming/sloshing noise in the background... What is causing it? At 30 sec it can be heard best. It comes and go, like a contraction or rotation. Will try to post a video without the engine cover tomorrow for better audio.
01-02-2021, 04:21 AM | #2 |
Rep 21
I guess it's hard to hear the sloshing noise. You really have to focus on it by dismissing the engine noise (including the ticking, which is normal). I wonder if it's the AC compression or ebox vent of sort. Tried taking the engine cover off but the noise it's barely recorded... It resonates more in person. My iphone XS is unable to pick it up as strongly as I hear it (hey perhaps it's me going def - ok no, not the case as the humming/sloshing stops when turning the engine off).
Anyone that is able to hear it and has any idea, welcome to comment. Cheers. |
01-02-2021, 07:17 AM | #4 |
Rep 21
The car has been garaged (not-heated), in same old same London temp these days (btw -3 and 5 degrees Celsius). Haven't driven much if at all past month due to Covid. Just took it to the mechanic for oil change issue. Cheers.
01-02-2021, 08:06 AM | #6 |
Rep 2,342
Drives: 9Y0 Cayenne S
Yes, I hear it. Which engine do you have? The camera was moving around too much to see clearly.
The sound is regular. I would spend 30 minutes just listening and pinpointing the sound. Remove the engine cover and listen. Start the 30 minute observation with a cold engine, and by the end of your 30 minute observation the engine will be warm. Please post a video when you first hear the noise at cold start, and then again another video at the end of the 30 minute observation. Candidates: - air con compressor, valve and refrigerant lines - heater/coolant circuit - intake - EGR (which engine?) - PCV (which engine?) - engine mounts - belt driven accessories or pulleys I don't think it is these: - timing chain - valves - crank or rod bearings - fuel pump - injectors |
BMWBambi5.50 |
01-02-2021, 09:57 AM | #7 |
Rep 21
Thanks for the comments thus far! Glad to know I'm not going mad - though the noise is annoying.
It's an M40i, 6 cylinder engine. What's located next to right of the oil pan (if you were to sit on a left-hand driver seat? Cheers. |
01-02-2021, 10:04 AM | #8 |
Rep 383
Drives: 2023 BMW X3M40 1984 911 TARGA
Why not ask the mechanic who did oil change?
Or better yet DRIVE it over to him? Not sure how many owners listen under the hood of their vehicles these days.
2023 X3 M40I 2018 X3 30i M Sport
2011 550i 2005 325i 1985 535I 2017 F150 2016 GS 2004 545i 1994 525I 1984 911 TARGA 2014 HD ULTRA |
01-02-2021, 10:07 AM | #9 |
Rep 15,858
Besides the injection, there is the vacuum pump sound track.
I sense a sort of pulsing, (the sloshing sound?) which I'm minded won't be from the vacuum components, but could be AC or heat management induced sounds. Does it change much with the engine cold and/or warmed up? |
BMWBambi5.50 |
01-02-2021, 10:37 AM | #10 | |
Rep 21
I drove it for about 25 minutes the other day, and made the same sound. It kicks in about 5-10 seconds after the cold start subdues. I will have to re-check and time it again though to be more precise. I also thought that would be the case, so checked the cooling and heating inside at max and it seemed everything was working fine, inside at least. I cannot hear the noise from the inside cabin. Anyone ever heard a *pulsating* noise in their X3? I hope it's due to something that's iced and it will fall off when I make a longer drive ha! |
01-02-2021, 11:15 AM | #11 |
Rep 15,858
The pulsing is not rhythmic, like the injection or vacuum pump, so doesn't appear to be a rotational component.
That indicates to me it involves valves, non-return valves, or flows of some kind. Vacuum pump does appear rather loud to my ear, (may be more common on the B-series engines). I'm wondering if it is something like the discharge valve, back into the crankcase ventilation system. Could explain the changing sound level and the more erratic timing of the pulsations. |
BMWBambi5.50 |
01-02-2021, 02:10 PM | #12 | |
Rep 21
01-02-2021, 02:35 PM | #13 | |
Rep 15,858
BTW, the discharge valve is essential, not exactly sure what the air balance is, but it will be part of the controlled crankcase ventilation, feeding back into the intake system. It is controlling the 'exhaust' from the vacuum pump, but can't vent to the atmosphere, as it contains oil. There may be a way to see if it is the problem. I'd get someone to gently press the brake pedal (on and off) to use vacuum. See it it changes the frequency of the pulsating, as the vacuum pump works harder. Does it sound the same with a few revs, change or disappear? What about when the engine is warm, or hot? |
BMWBambi5.50 |
01-02-2021, 03:14 PM | #14 |
Rep 2,342
I just ran my wife's 30i for 5 minutes with my ear inches away from all around the engine, and heard nothing resembling the sound in the original post. To me this suggests the sound is coming from something specific to the M40i.
BMWBambi5.50 |
01-03-2021, 04:12 AM | #17 | |
Rep 21
I will check again in a few days and try to get mechanic pinpoint the noise and will keep you posted. Thanks mate! |
HighlandPete6663.00 |
01-03-2021, 08:18 AM | #18 |
Rep 2,342
If the sound doesn't change with engine (coolant) temperature or engine rpm, it's likely not related to induction, combustion or exhaust.
Possibly air con/compressor/thermal expansion valve. Try the test from a cold start, with air con fully turned off 100%. No fan, no "AC", temp turned all the way to the lowest setting. See if the noise appears from cold until warm engine. Then repeat the test from a cold start with the air con at full fan, highest temperature setting and "AC" on. |
01-03-2021, 12:05 PM | #19 | |
Rep 15,858
From the OP's reply on revs and temperature, I'm less inclined to see the vacuum being involved. Although a stationary brake application test would help in putting that avenue of exploration to rest. |
BMWBambi5.50 |
01-04-2021, 07:38 AM | #21 |
Rep 21
Cheers for that.
I will have it checked out. I had no idea about bleeding out hydraulic lifters... not sure what they are either ha! Anyone care to explain if this applicable to our B58 engine? I'm pretty ignorant about many things. Thank you for the wisdom and information in advance! Cheers. |
01-04-2021, 01:52 PM | #22 | |
Rep 15,858
BTW, the odd sound is not hydraulic lifters. Besides, an HVA is a clear 'tapping' sound, it is engine rpm related (half speed), so changes with revs. |
BMWBambi5.50 |
