G80 BMW M3 and M4 General Topics M3 (G80) and BMW M4 (G82) General Forum
      10-06-2020, 09:14 AM   #1
_RS4_
Switzerland
508
Drives: M2 Competition
Exhaust details & undercarriage look from G82 M4 / G80 M3
Looking underneath the car I noticed that the exhaust is quite different from the other S58s, you can see a small central resonator (red circle), 2 secondary catalysts/OPFs (blue) and 2 primary catalysts (yellow), but the curve of the tubes and the location of the catalysts it totally different from the X3/4M. I'm surprised to see the primary catalysts so far from the manifolds, any thoughts?
Name:  G80 M3 G82 M4 Exhaust System Undercarriage Underbody.jpg
This is the X3/4M exhaust
      10-06-2020, 09:47 AM   #2
kyleb350
kyleb350's Avatar
Drives: TBM F82
Preproduction maybe? I'm not an exhaust expert, but I imagine having the primary cats far from the manifold isn't good for efficiency.
      10-06-2020, 09:57 AM   #3
CanAutM3
CanAutM3's Avatar
Drives: 2019 M4cs
2019 BMW M4cs  [0.00]
2018 Audi RS3  [0.00]
Hmmmm, interesting. I wonder if it is an attempt at making an equal length exhaust system.
///M4cs 2019 F82 Lime Rock Grey
MPE / CF Mirror caps / MP-HAS / GC Camber plates
JTO242873.50
      10-06-2020, 10:30 AM   #4
M-SP0RT
M-SP0RT's Avatar
Drives: 335i M Sport
does that make it easier to de-cat
Waiting for the G80 M3
Current Ride: '14 335i M-Sport
peterdf27.00
werdn215.50
F85MTuNED1099.50
E92only11.50
      10-06-2020, 10:36 AM   #5
Holset
Sweden
49
Drives: BMW M4
Interesting!
      10-06-2020, 11:54 AM   #6
super51fan
Drives: F10 535i
Routing the downpipe under the transmission is very strange to me. It almost looks like the M5 midpipe setup. I wonder if they are planning for a V engine configuration down the road. I know that sounds farfetched but I do not see why else they would do it this way.
bk950.00
      10-06-2020, 02:34 PM   #7
JTO24
Got an 8:30 res at Dorsia
JTO24's Avatar
Drives: 2018 AW M2 6MT
This was my initial thought as well... maybe they've seen all the work the F8x folks were doing with EL systems and tried to implement it
2018 F87 M2 6MT | Alpine White | Exec. | OEM+
GONE BUT NOT FORGOTTEN:
2016 981 Cayman 6MT | Jet Black | X73 Sport Suspension
2015 F80 M3 DCT | Tanzanite Blue | Gold Brown | OEM+
2013 E92 M3 6MT | Mineral White | Fox Red/Black | OEM+
CanAutM313056.50
F85MTuNED1099.50
      10-06-2020, 02:43 PM   #8
mrrm3
Drives: 2016 M4 cabrio
Looks like after-market exhaust suppliers will just need to tap in aft of item #9, which means much less metal/shorter piping than was required for the F80/82/83. Hopefully, that will translate into a less expensive exhaust mod.
      10-06-2020, 04:44 PM   #9
NISFAN
NISFAN's Avatar
United Kingdom
2774
Drives: The best kind of F30 :)
Looks like the opposite. Notice the significant extra length as they pipe 3 cylinders to the other side of the gearbox. Going for the Subaru warble. :
RalphyBMW156.50
      10-06-2020, 04:47 PM   #10
CanAutM3
CanAutM3's Avatar
Drives: 2019 M4cs
It depends which of the two manifolds goes through the longer route: the front or the rear one.
On the F8X, the exhaust gases of front manifold have to travel a longer distance that the ones of the rear manifold. Making a detour for the rear manifold balances the exhaust length.
Holset49.00
      10-06-2020, 04:55 PM   #11
NISFAN
NISFAN's Avatar
United Kingdom
2774
Yes I realise that, but not to the extent shown here. This looks deliberately out of balance.
Twin turbo straight sixes are not new, here is a picture of an RB26DETT front pipe to balance the lengths. You are talking 12" max to make up.
      10-06-2020, 05:04 PM   #12
///Motivated
Drives: 335i, i3
The distance does nothing to efficiency. It just adds time, and therefore emissions, to the cold start. Once at operating temp in a few seconds the efficiency will be the same.
      10-06-2020, 05:17 PM   #13
Pinkoboe
Pinkoboe's Avatar
Drives: 2018 C43
Can anyone explain what is going on in the original picture? The car looks like it is participating in some sort of circus trapeze act.
Just curious...
      10-06-2020, 05:19 PM   #14
solstice
Drives: 2015 M3 6MT
Enables a lower profile of the exhaust resulting in less drag of the fast flowing under car air? Might not be enough space when routed one side to achieve the same?
      10-06-2020, 05:21 PM   #15
EBII335
EBII335's Avatar
Drives: F30 335i M Sport EBII
I think BMW ran out of room to put both primary cats on one side ... so they used the unused space on the other side of the transmission for one of the cats and piped under transmission to that space.
Mike
2015 335i 6 MT
AA Flash, VRSF DP
      10-06-2020, 05:21 PM   #16
audioMeth
audioMeth's Avatar
Drives: F80
Just curious...
they lowered it from a helicopter for a PR stunt.
Pinkoboe197.00
      10-06-2020, 05:46 PM   #17
mitch32
Drives: F82 ZCP
Principles of thermal dynamics says largest temp difference from intake to exhaust mani equals largest power. Placing them closest to the manifold will equal more heat but to be honest I don't think that logic was used here looks like packaging but I didn't design the car. Also cats like to be heated up to function properly maybe the idea is to get into them and keep them heated. Or the all most important topic BMW topic NVH, BMW has started to make these M3/4 everyday cars with minimal NVH it's possible moving the cats closer helps eliminate some NVH topic the car tuners (me included) will remove those NVH nannies anyways!
      10-06-2020, 06:06 PM   #18
CanAutM3
CanAutM3's Avatar
Drives: 2019 M4cs
See below aftermarket solutions for the F8X. They do add a fair bit of length.
One28i7.50
      10-06-2020, 06:53 PM   #19
tbraden
Germany
Drives: BMW M2 Competition
https://g80.bimmerpost.com/forums/sh....php?t=1763157
In this Youtube video filmed by a german YouTuber, a BMW M employee states at around 8:20, that the exhaust and sound design team specifically engineered the exhaust to be equally lengthened to create the desired sound profile for the new BMW M3/M4. These undercarriage photos seem to confirm that.
Holset49.00
      10-06-2020, 07:07 PM   #20
CanAutM3
CanAutM3's Avatar
Drives: 2019 M4cs
Originally Posted by tbraden View Post
In this Youtube video filmed by a german YouTuber a BMW M employee states at around 8:20, that the exhaust and sound design team specifically engineered the exhaust to be equally lengthened to create the desired sound profile for the new BMW M3/M4. These undercarriage photos seem to confirm that.
for sharing this video. It's the most informative video I've watched about the G8X, finally something technical :
  • Base: 1.3bar boost
  • Comp: 1.7bar boost
  • 5.5kg of sound-deadening removed over the base 3-series
SYT_Shadow5936.50
      10-06-2020, 07:09 PM   #21
JB M4
Drives: BMW M4
I hope so and to put back the cats when it goes in for service...plug and play
      10-06-2020, 07:45 PM   #22
autoart
Drives: 2009 335i e90 M
Could it be in the yellow circles those are braided exhaust pipes?
Search this Thread:
Advanced Search
Copyright ©2000 - 2020, vBulletin Solutions Inc.
