09-23-2020, 11:53 PM | #1 |
Rep 1,658
Vehicle Will Turn Off Soon Message
or something to that effect...received this message twice now after driving for a few minutes, thankfully it does not shut off but it does not seem realize the vehicle is actually running! Any thoughts?
2019 M850i xDrive Coupe (06/19 Production)
Mineral White/Black, HP Cooling/Tire/M-Technology Pkg/Extended Shadow/Etc., Anthracite Headliner, Carbon Roof, DAx2, Display Key, Various Accs'. Topic permitting, I try to be objective as possible Last edited by RJC-1; 09-24-2020 at 02:03 AM.. |
09-24-2020, 01:36 AM | #3 |
Rep 1,658
Good thought, as the key is a year old so maybe it needs a battery, but I'm not getting the key is not in the vehicle message
Mineral White/Black, HP Cooling/Tire/M-Technology Pkg/Extended Shadow/Etc., Anthracite Headliner, Carbon Roof, DAx2, Display Key, Various Accs'. Topic permitting, I try to be objective as possible |
09-24-2020, 12:54 PM | #6 | |
Rep 1,658
09-24-2020, 03:44 PM | #7 |
Rep 92
I had this a few times, I think it may be a battery thing as I do lots of short journeys and this message would come on after I had sat in the car for a short while before starting it. I could drive all the way home ( only a mile or so ) and the message would remain there the whole way.
RJC-11291.50 |
09-24-2020, 04:19 PM | #8 | |
Rep 1,658
09-24-2020, 04:26 PM | #9 |
Rep 810
Drives: M8C Coupe,E63s ED1,AMG GTC
I would just put the battery on a trickle charger to give it a full charge.
Just driving the car for a while may not resolve a low battery condition, especially as you have 90 degree weather with AC and seat vents running... The message obviously makes no sense but their software isn't the smartest when dealing with a low bat condition. |
RJC-11291.50 |
09-24-2020, 04:32 PM | #10 |
Rep 1,658
Thanks, I'll let the dealer charge it up when I get my 1 year done next week and be sure to drive it more. When I do take it out every two weeks the seats are off and AC is on but fans set to lowest setting...the car does have the HP cooling and in addition to the HD oil cooler there's HD cooling fan so that probably draws the battery down more so.
09-24-2020, 04:35 PM | #11 | |
Rep 92
Can't tell you long term though as my car went back to the dealers over 7 weeks ago with a couple of other issues and I haven't seen it since. They have subsequently given me the whole value of the car against a new one as they can't seem to fix it ( not reading digital key ). If you go to the thread about the updates going horribly wrong you will see the history. |
09-24-2020, 04:41 PM | #12 | |
Rep 810
CTEK makes the best ones AFAIK; they are cheap too - just get one compatible with Lithium Ion. |
09-24-2020, 04:47 PM | #13 | |
Rep 1,658
09-24-2020, 04:50 PM | #14 |
Rep 1,658
Will check it out and go that route, hopefully in the interim BMW will get the battery up to snuff or replaced if need be, as the car only has about 975 miles and it's only been 9 mos since I bought it new on 12/26/19.
09-24-2020, 05:05 PM | #15 | |
Rep 810
BMW will be happy to tell you that a battery damaged due to drainage will not be covered by warranty Lithium Ion batteries also have eye watering prices. Btw, BMW and Mercedes have branded trickle chargers which are also made by CTEK https://www.amazon.com/CTEK-56-926-L...a-493114685985 |
RJC-11291.50 |
09-24-2020, 05:26 PM | #16 | |
Rep 207
M |
09-24-2020, 05:42 PM | #17 |
Rep 1,658
He mentioned BMW replaced it
09-24-2020, 05:54 PM | #18 | |
Rep 1,658
09-24-2020, 06:09 PM | #19 | |
Rep 810
I just clip the connectors onto the battery ports in the engine compartment. Our car just auto locks when walking away and there is no impact leaving the car like this for extended periods of time. Just don't forget to unplug before taking off |
09-24-2020, 07:16 PM | #20 | |
Rep 1,658
09-24-2020, 09:49 PM | #21 |
Rep 4,372
Drives: 2020 M850i Coupe
The absolute irony if it is a battery issue is that here in AZ with the 110 plus degrees during the summer so far so good in my M850i without the same notice. In fact 2020 has set a new record for summer temperatures at 107.9 as the average. The key being as the heat absolutely kills car batteries to the point a 5-year battery (under traditional battery warranty) may make it about 2 years tops.
09-24-2020, 10:07 PM | #22 | |
Rep 1,658
