      07-30-2020, 11:33 AM   #1
Boss330
Boss330's Avatar
G82 M4 test drive review by Sport Auto
Attached is the German magazine Sport Auto's article on the test drive of the new G82 M4.
Sport Auto is home of the Supertests which partly takes place on the Nürburgring and which has set the benchmark in Nürburgring lap time comparisons.
Sport Auto has a lot of good to say about how the car drives and handles on the track. Much better than the F82 M4 Comp that they did back to back laps with on the same circuit the same day… From their review it sounds like the G8x both is a very capable, quick, and not least, a very entertaining car to drive on track
EDIT: Have "translated" the Google translation into what is, hopefully, a more coherent text… Neither English nor German is my first languages (I speak both) but I have tried to clean the text up to the best of my ability
Shortly after the “Große-Kuppe” left hand curve the fourth gear is perfect, the three-liter inline six-cylinder engine pushes plenty of torque through the transmission. Now: buttocks clinch, take off a little bit of throttle, because still the low coefficient of friction on the still damp (wet) track in the fast Ralf Waldmann kink pushes the car onto the kerbs. Doesn't have to be. Yet: The new BMW M4 interacts (interlock) insanely consistent with the damp asphalt. Both with the front as well as the rear wheels.
So much that the BMW M team even has one predecessor M4 Competition (with DKG) deployed so that we can experience both generations in direct comparison to each other. In fact, the old acquaintance F82 fullfills all expectations. It turns in committed and quick, however, it never leaves any doubt to its drive concept: All power to the rear.
With the new G82 (the number 2 stands for the coupe) you haven’t even reached the legendary and tricky Omega of the Sachsenring, as the cars lateral acceleration and feedback filter through your body and tells you:
This M4 can do everything better. Better at driving at least. And much better. The bite of the front wheels alone; this turn-in punch after mere milliseconds until the rear follows. Under the current damp conditions the electronics quickly catches the rear.
Now the entire car turns at the instant of the steering impulse around the vertical axis, twists with highest natural agility through alternating curves (Omega exit uphill over the hilltop. My God!). The car bravely keeps the line, and is even closer connected than before to the driver. Why? The communication is just right, no matter if it’s through the steering or the chassis - you always know what's going on.
Nevertheless you can trust BMW ///M, to also provide you with a relaxed long-distance trip.
The current M puts far less emphasis on suspension comfort than before. And this is good thing.
What have the boys and girls in the development team particularly focused on?
,,We have invested a lot in the direct connection of the chassis", says Carsten Wolf, Project Manager Vehicle Characteristics M3 / M4. The engineer doesn't say much more since he want to save the details for the world premiere in September. He says one other thing though:
,, The progress in the tire is immense".
New: Mixed tires of dimensions 275 / 35-19 at the front and 285 / 30-20 at the rear. In addition six instead of four-piston fixed caliper brakes on the front axle with carbon-ceramic discs, in case of doubt both as options. In general: This would be the preferred choice.
For the first test rounds we have the entry-level, 480PS, six-speed manual transmission. The market launch also introduces the Competition variant with 510 hp and the eight-speed automatic transmission. Later this is followed by an all-wheel drive in the mold of the M5/M6 – this possibly comes a generation too late.
Because the mechanical grip turns out to be so much higher than before, there is now a significantly improved stability control with better programming. Even in a full protection mode the stability system now works perfectly even in the lower curve where the track is particularly rough.
On entry to the Queberg curve. downshift two gears. Not because it’s necessary but just because it's so much fun. One downshift would have been sufficient.
Asphalt evaporates:
On the start-finish straight, going through the precise and short gear changes is a pleasure, not too light and with a beautifully modelled resistance. This is the case also for the steering, which - typical of BMW - even on the racetrack in the comfort mode gives a particularly homogenous feeling of steering. The ideal line dries out, lap after lap the M4 can put more and more of its maximum torque of 600Nm down, the competition model has as much as 650Nm.
You sit perfectly positioned behind the steering wheel in gripping sports seats which works great and that also finally, since the X3 / X4 M, comes with an extendable thigh pad.
We would probably want a bit less “playful” instruments, the one in the car are virtual, but despite that has a somewhat classic layout.
And also more sound, more panic orchestra, fitting of the driving behaviour would be preferred. Yes, sure, the biturbo S58 is already making music, sometimes bassy, sometimes brighter, sometimes slightly metallic, always hoarse, still somewhat washed out, like an overcompressed MP3 track. LP would be again nice, or at least an early one CD, when music still was produced more expensively.
The M4 drives no differently than the M3 and vice versa. The car successfully strives to get you to sweep away with its incredible agility, the engine’s character with power and rev happiness imitates the best the 80s, 90s and 2000s, so to speak.
You use it, enjoy it, fight with the racetrack, register the immense traction in the dry. Because even with moderate acceleration out of the left hand turn after the karting hall, you can sense the delicate oversteer in your hands. There could be even more oversteer but the MDM mode of the traction control reigns it in.
With lots of momentum through Turn 9, 10 and 11, the line gets tighter, full throttle downhill, then drop the anchor. No problem, the brake pedal has a a clearly defined pressure point and great deceleration.
Then, downshift. Perfect with the manual shifter. Once again, one gear more than necessary. Just because it's so much fun to do so...
Appreciate 12
Jason40689.50
VCP1390.00
CanAutM321115.00
seis-speed2430.50
Miko M6650.50
EXE462100.00
02M3ForMe4257.00
      07-30-2020, 12:21 PM   #2
khoa@x-ph.com
khoa@x-ph.com's Avatar
Drives: F83
Good writing. Thanks for sharing.
GRIP-SCHWAGER!!
      07-30-2020, 12:36 PM   #3
bunker
BVARIAN
bunker's Avatar
Drives: 2022 M240xi
GRIP-SCHWAGER
man, I adore the Germans yanno
1999 330ci / 2003 330i / 2008 328i coupe / 2011 328i Touring M-Sport / 2016 M235xi / 2019 440xi GC unicorn / current: 2022 M240xi (the "Purple Porsche Eater")
      07-30-2020, 12:43 PM   #4
jim1013yyf
Drives: YMB M4
would be such a great car IF they drop the fugly grill.
      07-30-2020, 12:44 PM   #5
hellrotm
4143
Drives: F80
Looking forward to the S58 in the next gen M2, without the pig nose.
Appreciate 14
hdubf80143.50
Teutonic2709.00
ssabripo937.50
scm6079118.00
clee1982797.50
CSBM52716.50
dmboone254972.00
TheOne26.50
///M TOWN16066.50
      07-30-2020, 12:49 PM   #6
chris719
Drives: '08 M Roadster
Don't worry, the 2er coupe will be purposely beaten with the ugly stick to compensate. There are already hints in the leaks.
Appreciate 8
stein_325i25064.00
Ibiza3596.00
Teutonic2709.00
CSBM52716.50
Geo_FF140.00
      07-30-2020, 12:56 PM   #7
hellrotm
4143
Drives: F80
Seen the leaks, styling will work with wide body of M2.
      07-30-2020, 12:58 PM   #8
JustChris
General
JustChris's Avatar
Drives: Tesla MYRWD
Sounds very very promising!
My car made front page of Bimmerpost
      07-30-2020, 01:07 PM   #9
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6155
Drives: ‘06 Z4MR, ‘20 X7, ‘22 M4x
Now: buttocks fluff together, yours take some gas away, because still would one of the wet low coefficient of friction in the fast RalfWaldmann Kink well over the curbs wear. Doesn't have to be.
Google translate needs some work
Appreciate 17
mkoesel7508.50
JTO245271.50
DeeKay553.00
chris7197331.50
_robert_108.50
dmboone254972.00
ra2289303.50
KoenG1426.50
CanAutM321115.00
Swappy531.50
mrkmtchll285.00
Habs78.00
Dinh335713.00
      07-30-2020, 01:23 PM   #10
CanAutM3
General
CanAutM3's Avatar
Drives: 2021 911 turbo
for sharing!!
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black
Boss3301711.50
      07-30-2020, 01:33 PM   #11
prompt
Car Designer
prompt's Avatar
United Kingdom
292
Drives: M2C
It seems a very vague review to me
Is going to have more grip ok,what about the rest of the driving experience?
I was expecting some ASD complain or something else
On the other side I bet is going to perform quite well if they want to compete in the GT3 class
      07-30-2020, 01:41 PM   #12
duky
The Tanzanian
duky's Avatar
Drives: BMW M3, Audi RS6, Mini Cooper
As excited as I am/want to be, that English translation is barely understandable
2023 F56 MINI Cooper SE Midnight Black II on Carbon Black
2021 C8 Audi RS6 Avant Mythos Black on Black/Grey
2016 F80 BMW M3 Black Sapphire Metallic on Silverstone
      07-30-2020, 01:52 PM   #13
solstice
Drives: 2015 M3 6MT
“Now: buttocks fluff together”
Really, what more do you need to know?
Appreciate 8
chris7197331.50
JTO245271.50
JustChris17483.00
del82102.00
KoenG1426.50
ra2289303.50
Remonster824.00
      07-30-2020, 02:01 PM   #14
fndrsn
Netherlands
111
Drives: Nothing...yet!
Sounds like it'll be a bunch of fun to drive, but not much fun to be seen in. I wonder if someone will come along like those guys that replaced the nose of the Aston Martin Vantage, can imagine quite a few people will go for that option
Just your average kid with more love for BMW than money to actually buy one
      07-30-2020, 02:02 PM   #15
chris719
It's true, I test drove a 370Z once and I just couldn't buy it because it didn't make my buttocks fluff together.
solstice5456.50
JTO245271.50
      07-30-2020, 02:03 PM   #16
solstice
Drives: 2015 M3 6MT
When the lower powered RWD MT version feel this impressive in in and out of the corners the AWD version should be capable of an average track speed far, far beyond the current version. Much more power for top speed, much more tire for grip around corners and much more traction from AWD to exit, hold on...
JustChris17483.00
      07-30-2020, 02:33 PM   #17
Chihuahua
Chihuahua's Avatar
4058
Drives: E30 329iS, E65 Alpina B7
Thanks for the post. My buttocks also fluff when I take gas away.
      07-30-2020, 02:52 PM   #18
del82
Drives: BMW M340i xdrive
"Now: buttocks fluff together"
Is that a standard feature or part of an options pack? Disappointed if BMW now start charging for this.
Current: 2020 M340i
Past: M140i, Z4 35is
solstice5456.50
syd34213.00
      07-30-2020, 03:04 PM   #19
Sheharyar_rr
Drives: 14' 335xi M-Sport
Couldn't understand the translation too well, hopefully someone can chime in.
Does it come with 6 piston calipers with steel brakes now? I know it will with carbon ceremic
2021 M5 Competition | Imola red
2020 Z4 M40i | Misano blue Pure850/PI/LPFP
Gone: 2018 M550i xDrive | DME Tuning BEF / JB4 / BM3 / DPs | 10.95 @ 125 1/4 Mile
Gone: 2014 335i xDrive | Bootmod3 Stage 2 93 Map | 12.2 @ 113 1/4 Mile
      07-30-2020, 03:07 PM   #20
BwoodBMW
BwoodBMW's Avatar
1861
Drives: EFFEIGHTY
I can't tell with the translation whether its saying the ride will be more or less comfortable...
F80 is needlessly harsh which adds to the traction issues the car has. Better suspension tuning and the AWD will be absolute game changers for this car. I really want to be excited about it .. but... you know...
stein_325i25064.00
      07-30-2020, 03:09 PM   #21
Encanto
Encanto's Avatar
Drives: 2021 X3 M40i
I think that they wanted to say that 6-piston front calipers are now standard, regardless of rotors type instead of 4-pistons (iron)/6-pistons (ceramic).
Good review...
      07-30-2020, 03:12 PM   #22
thekidd
Drives: @a_anders0n
Happy to see the commitment to development and improving upon engineering of each subsequent generation. Although I plan to keep my F80 I'm excited to see the G8X on the road!
Search this Thread:
Advanced Search
