07-29-2020, 09:25 AM | #1 |
Russian in a Bimmer
566
Rep 5,619
X5 M50i Catted/catless downpipes options
Has anyone tried these out?
These seems to be the only catted/catless option I was able to find for the M50i https://brondexshop.com/products/bmw-x5m-g05-downpipes https://www.supersprint.com/ww-en/bm...system.aspx#!/
2013 X6 - retired
2015 X6 - retired 2015 435GC - retired 2018 X5 40e - retired 2020 X5 M50i - Current |
07-29-2020, 12:34 PM | #2 |
Rep 1,242
3000 Euros!!!
Never..... in a million years would I spend that much on downpipes. It would be cheaper to have a custom exhaust builder make you a set, and ceramic coat them.... and install them. Wait a year or so, there will be a dozen manufacturers on the market selling a catless set for $500, and a catted set for around $1000 |
07-29-2020, 01:40 PM | #3 | |
Rep 446
Right now, we do know that the ARM pipes do fit the M50i and are very reasonably priced. The downside is that there is only one downpipe mounting bracket versus stock with 2. Does that make a difference? I am not sure I have a valid opinion yet. Last edited by 130FeetDeep; 07-29-2020 at 04:13 PM.. |
07-29-2020, 03:28 PM | #4 | |
Russian in a Bimmer
566
Rep 5,619
I have resonator delete (Straight pipe, not X pipe) and would like something a bit louder. That is why I am looking into DP's, preferably catted pipes either 100 or 200 cell.
2013 X6 - retired
07-29-2020, 04:07 PM | #5 | ||
Russian in a Bimmer
566
Rep 5,619
once the car warms up it, its not as loud and not that many pops from the exhaust
2013 X6 - retired
07-29-2020, 04:15 PM | #6 | |
Rep 446
I don’t get what’s going on at VSRF? Testing the fitment should be easy. |
07-29-2020, 04:17 PM | #7 |
Russian in a Bimmer
566
Rep 5,619
Yeah I spoke to a local shop here and they recommend tuning it as well to take the light off, they did mention customer purchased downpipes for 850i and it fit with some modifications to the heat shield.
2013 X6 - retired
07-29-2020, 04:29 PM | #8 |
Rep 446
You have a flash option? Most require you to send in your DME for bench flashing now. That is not realistic for most of us.
07-29-2020, 04:54 PM | #9 |
Rep 444
I have been researching downpipes almost daily. The more I listen to resonator delete sound clips the more I think it’s not the sound I want, it’s that high rasp that I just don’t think is right for my car. I want a deep V8 rumble like my Panamera had.
I would like to hear the sound produced from just swapping out the down pipes and opening the aquator flaps. If that doesn’t do it then it’s X-Flow. I know a tune will be required so might as well go for the 680bhp version and be done with it |
07-29-2020, 05:02 PM | #10 | |
Russian in a Bimmer
566
Rep 5,619
2013 X6 - retired
07-29-2020, 05:08 PM | #11 |
Rep 444
07-29-2020, 05:24 PM | #12 | |
Rep 446
https://www.vr-speed.com/vrsf-stainl...i-g30-g31.html We do know that the ARM fit because we have members running them. We know nothing about fitment of the VRSF because they were using a local tester, but no one has heard back from them. |
Addbuyer833.50 |
07-30-2020, 04:33 AM | #13 | |
Rep 444
You guys over the pond don't have the noise regulations we have and so your motors already sound half decent. The Nissan LEAF sounds better that my M50i so we are starting improvements from a disadvantage even though we are supposed to have what BMW are calling an M-Sport Exhaust . So do I start with just downpipe replacement and should they be catless or sports cats, along with some type of control over the actuator valves flaps or do I also go with resonator delete with X-flow |
07-30-2020, 05:49 AM | #15 | |
Rep 444
Stock exhaust, no resonator delete or valve touched then? I cant see any mention of the M50i on FI's website? No wonder my searching has been fruitless. Any chance you could pm me the item numbers and their costs of the parts you installed please. This is starting to come together now thanks to all you guys who know where to look and share the info |
07-30-2020, 06:50 AM | #16 | ||
Russian in a Bimmer
566
Rep 5,619
If you are looking for a deep noise, I would first change the downpipes and then play around with the resonator as it is easier and cheaper to put back on if you don't like the noise.
2013 X6 - retired
07-30-2020, 09:02 PM | #17 | ||
Rep 148
Addbuyer833.50 |
08-04-2020, 10:55 AM | #18 | |
Russian in a Bimmer
566
Rep 5,619
was it direct fit or had to make alterations?
2013 X6 - retired
08-05-2020, 04:37 PM | #19 |
Rep 444
So today I took a trip to an exhaust specialist (https://www.torqueflow.co.uk) who are next door to a tuning specialist (https://mslperformance.co.uk) to discuss installing Supersprint down pipes with catalytic’s, removing the OPF filters that plague European cars, and getting the car tuned to prevent the CEL warnings. The resonator would stay and the valves maybe welded in the open position.
I believed the two chambers located mid way along the exhaust system, just in front of the resonator, was the OPF’s but it turns out the OPF’s are located on the down pipes immediately after the catalytic’s and those chambers in the middle are secondary catalytic’s. Immy at Torqueflow suggested I just chop out the secondary cats and resonator and replace with straight pipes. A second option is to gut the secondary cats and resonator so it all looks standard but should I have to revert it back to standard, it’s a very expensive process. As the OPF’s won’t be touched (for now) I no longer need any kind of tune. Not sure I’m going to achieve any great sound improvement with those bloody OPF’s left in the system. Praying supersprint brings their full exhaust system for the M50i to market soon. |
08-10-2020, 10:19 AM | #20 | |
Russian in a Bimmer
566
Rep 5,619
2013 X6 - retired
08-10-2020, 01:52 PM | #21 |
Rep 444
