BMW X5
      07-14-2020, 03:19 PM   #1
Dennuske
Dennuske's Avatar
23
Drives: BMW G31 2019
Exhaust Flap 45e
Does anyone now if the 45e has a exhaust flap that can be opened with for example Carly?
BMW X5 45e (G05) 2020 (in order)
BMW 520d (G31) 2019
BMW 116i F20 (2016)
      07-19-2020, 01:28 PM   #2
ikheetleon
Netherlands
219
Drives: BMW X5 45e 2020
https://www.bimmerpost.com/forums/sh...php?p=26035253
      07-22-2020, 04:08 PM   #3
hiluca
Drives: X5 45e 2020-2024 X5 50e 2024-
Originally Posted by ikheetleon View Post
did you open the flap permanently and did it make a difference in sound/ start up ?
      07-23-2020, 06:08 AM   #4
ikheetleon
Netherlands
219
I haven't done the mod myself, I only checked if the 45e has the flap.
      07-23-2020, 09:35 AM   #5
Flippy_00
Belgium
44
Drives: 2020 G05 45e
I opened/closed the flap using BimmerLink on my 45e.
You can hear it 'click' when changing.
Exhaust sound difference is noticable.
I just tested it, haven't made permanent changes.
Raizon9.50
      07-23-2020, 03:03 PM   #6
hiluca
thank you for the reply.
does the flap open by default in sport mode or only when needed ?
      01-08-2021, 05:29 PM   #7
Wzon
Drives: BMW X5 G05
Only over 4000rpm.
I have done the permanently open hack with taken out the fuse. Works fine and sound a lot better!
QM287.00
      01-08-2021, 07:02 PM   #8
marcpitt
Germany
23
Drives: BMW X5 45e
Start up
      01-19-2021, 10:40 AM   #9
almu2min
Drives: BMW X5 45e 2021 (G05)
Hi, which obd adapter did you use for bimmerlink ?
Carly doesnt let me open the flap on the x5 45e. I saw on the seller page that the obdlink for bimmerlink doesnt work on hybrid cars nor electrical ones.
Which obd adapter do you recommend ?
Thank you
      01-20-2021, 12:54 PM   #10
ikheetleon
Netherlands
219
Thank you
I use the ENET cable with lightning/ethernet adapter on iphone. Works very well/fast.
      01-20-2021, 01:53 PM   #11
almu2min
thank You, I have Android, i'll check if it is possible to work with my phone
      10-31-2021, 04:09 AM   #12
BartG05
Drives: BMW X5 45e
I can confirm that this device is also working on the GO5 45e. It opens the valve with the button on the steering wheel. I borrowed it from a friend who uses it in his M2. Just plug and play.
https://www.mosselmanturbo.com/en/ic...xhaust-valve-1
      10-31-2021, 09:41 AM   #13
saadG05
Drives: BMW X5 40i M KIT
i found a way to open the flap, just ask someone to put the car in launch control while they are pressing both paddles and launch control activates just pull off the fuse (fuse:203) and you got an open exhaust flap, not a good idea but it works
      11-03-2021, 06:54 AM   #14
Atlantis8000
Drives: X5 G05 45E
Does it remember the position of the valve or do you need to open the valve every time you start the car ?
      11-04-2021, 03:53 PM   #15
BartG05
Drives: BMW X5 45e
No, it doesn't remember.
      03-20-2022, 05:40 AM   #16
Who Cares
Drives: btw x5 45e
Smile
I have the x5 45e 2020. After having read several solutions on how to open the flap, I just tried to find out if the flap is in the open or closed position when the engine is turned off. It appears to be open! So I just pulled the fuse when the car was turned off, and the flap remains open Worked for me.
      03-30-2022, 06:02 PM   #17
jjcools
jjcools's Avatar
43
Drives: 2009 - 335i 6MT
Whoa, nice. Which fuse is it for the 45e?
2022 - X5 45e M-Sport, MGM over tartufo
2009 - 335i 6mt, Monaco over saddle (past)
2015 - 335i M-Sport, Estoril over black (past)
2005 - 330i ZHP, Mystic Blue over black (past)
      04-19-2022, 12:19 PM   #18
Joph Weud
Drives: X5 45e M
Yes, which fuse?
What else is on that fuse too?
      04-26-2022, 10:25 AM   #19
ThomasShelby
Drives: 2022 X5 45e M Sport
Also would like to know the fuse, looks like he was a one and done poster. When I tried to pull up the fuse map for my VIN it said my VIN wasn't found. Hoping someone else has one for the 2022 45e.
xbimmers
