05-21-2020, 09:10 AM | #1 |
Rep 3,129
NEW RELEASE: Dinan BMW G20 M340i (RWD) Springs/Bumpstops & Monoballs
Dinan BMW G20 M340i (RWD) Springs/Bumpstops Part Number(s): D100-0934 & D193-0121 Applications:
Description: Suspension systems that not only transform the stance of the vehicle but also maintain ride quality and improve upon handling are what Dinan suspensions are known for. This is accomplished by pairing springs sets with bump stops spring perches or both to maintain suspension travel resulting in a smooth ride while also improving mechanical grip and handling. This is what makes Dinan suspension systems unique. While we are able to sell each component separately, it is highly recommended that both the spring sets and the supplemental ride quality and handling kits are used in tandem in order to maintain the Dinan quality standards our customers are used to. Experience the Dinan difference with this combination and enjoy the ride it provides. Dinan's Performance Spring set for the G20 M340i, G22 M440i xDrive & G20 330i provides greater control over body roll by virtue of carefully calibrated spring rates. Additionally, Dinan lowers the car for improved suspension geometry and an even more aggressive stance. The Dinan springs are CNC wound with high tensile chrome silicon wire and shot-peened for stress relief to last the life of the car. The increase in stiffness will reduce the rear suspension compression under acceleration and front suspension compression (or dive) under braking, giving your car a more controlled feel. The Dinan performance springs will also provide a noticeable improvement in grip for high-speed driving situations that will inspire confidence in your car's capabilities. The reduced body roll makes the steering more responsive to driver input and will be noticed at low speeds up to the top speed of the vehicle. NOTE: Dinan Performance Spring sets should be purchased and installed with the corresponding Ride Quality and Handling Kit to achieve the advertised ride height performance and ride quality. While not explicitly required, if the matching component is not purchased and installed you will get less than favorable results in the form of poor ride quality and improper handling traits. While we will maintain a full warranty on product defects any claims against the cars improper handling ride quality traits due to not purchasing the corresponding handling kit will not be warranted. Features/Benefits:
----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Dinan BMW G20 Tension Strut Ball Joint Kit (Monoballs) Part Number(s): D280-0022 Applications:
Release Date: Available Now! Description: An underrated component of a proper driver's suspension the monoball kit (tension strut ball joint kit in today's terminology), is a remnant of an era when road feel was something desirable and sought after. Drivers wanted the visceral feel of being connected to the road as the road-racing heritage of BMW M demanded. Dinan embraced this and over the years mastered its craft into a kit that not only satisfied the desire for proper road feel but also made it livable for everyday driving. While stock suspension properties may have swayed from its golden era lineage to more mainstream ideals, Dinan is here to correct those mistakes for those that want a more M-passioned BMW experience. The Dinan Tension Strut Ball Joint Kit provides responsiveness you can feel by replacing the rubber bushings in the thrust arms with precision ball joints and machined aluminum housings. Improves responsiveness by eliminating the deflection inherent in the stock rubber bushings while also reducing brake shimmy. The quietest bearings on the market are virtually noise-free so you can live with them every day. These are the only bearings on the market that are sealed using a rubber boot to keep out dirt and road grime stopping them from wearing out prematurely. Features/Benefits:
Last edited by Dinan_Engineering; 01-27-2022 at 08:52 AM.. Reason: M340i xDrive application addition. |
05-21-2020, 09:12 AM | #2 |
Rep 113
Drives: 2023 BMW M3 Competition
YAY! It sounds like these are compatible with the adaptive suspension option, correct?
05-21-2020, 09:30 AM | #3 | |
Rep 3,129
Also a quick profile shot before it goes back in the air... |
05-21-2020, 10:38 AM | #5 |
Rep 3,962
Please someone donate an xDrive!
Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5 |
05-21-2020, 11:05 AM | #6 | |
Rep 3,129
In the case of our development car it is on stock wheels with no spacers. Seconded. |
05-21-2020, 11:18 AM | #7 |
Rep 1,168
Drives: 2020 M340i
Wow super sad to see there's nothing available for the xdrive model
2020 M340xi PB (sold)
2020 Ram 1500 Laramie (Daily) 2019 Shelby GT350R (Weekend) |
05-21-2020, 11:31 AM | #8 |
Rep 3,129
Need to see one before we can develop suspension for it I'm afraid. xDrive models arent exactly common in the deep south and the development requirements dont lend themselves to make shipping a car in really a viable option.
05-21-2020, 11:47 AM | #9 |
Rep 71
Great news! Before I pick up a set of springs and bumpstops for my M340i, can you confirm these will fit the non adaptive suspension?
Current: BMW ///M340i
Previous: BMW 335i, Audi A4, Honda Civic |
05-21-2020, 11:49 AM | #10 |
Rep 3,129
05-21-2020, 12:50 PM | #11 | |
Rep 1,168
Drives: 2020 M340i
What can you say about the strut ball joint system that was also released?
05-21-2020, 01:22 PM | #12 | |
Rep 3,129
Basically it improves on the tactile feel of driving for lack of a better way of saying it. The improved bearings allow the steering to be more predictable and removes the delay in between the input (turning the wheel) and the output (the car actually turning). As a result you feel more connected to the road inspiring more confidence given the car behaves exactly as you are telling it in real time. It's one of those parts that you see on paper and don't think much about but once you experience it you understand its value. Such is the life of a lot of suspension parts actually. Someone actually had a really good description of monoballs that I can't for the life of me think who it was. Might have been Turner actually... Last edited by Dinan_Engineering; 05-22-2020 at 07:34 AM.. |
Gdiddy23907.50 |
05-26-2020, 09:32 PM | #13 |
Rep 1,496
Dammit. I'd be all over these if they were xDrive compatible. I shall wait.
| M-Performance Exhaust | JB4 Map 4 on E35 | BMC Red Panel Filter |
| Previous: 18 M3 ZCP | 17 M3 6MT | 15 M235i | |
05-28-2020, 08:12 AM | #14 |
Rep 101
Getting my springs and bumpstops installed today
Dinan_Engineering3910.00 chenry2357.50 |
05-28-2020, 08:20 AM | #15 |
Rep 1,168
Drives: 2020 M340i
Let me know what your thoughts are after you've had time to drive with them installed
05-28-2020, 09:54 AM | #17 |
Rep 1,222
05-28-2020, 10:21 AM | #18 |
Rep 113
Scheduled my install for next week. I got quoted around 1200 to install everything (including the bump stops and the monoball mounts). They'll need a day and a half for the install.
randomserious51.00 |
05-28-2020, 10:59 AM | #19 |
Rep 1,222
05-28-2020, 11:05 AM | #20 |
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
Does that include alignment too?
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
05-28-2020, 02:12 PM | #21 |
Rep 113
05-28-2020, 04:10 PM | #22 |
Rep 1,771
Also please post pics!
Instagram: @dg_g20
