BMW E46 M3 - Legend Eternal
E46 M3 Coupe and Convertible Forum Photos, Videos, Builds
      03-29-2020, 09:10 PM   #1
Andrew
Moderator
Andrew's Avatar
429
Drives: E46 M3 / E92 M3
2003 BMW M3  [0.00]
2008 BMW M3  [0.00]
DISAPR's 2004 E46 M3 Track Car
This is a re-post of disapr's legendary E46 M3 track build originally posted on M3Post.
Body
  • Roll cage was fabricated by Lucas Racing - All tubing is 1.750 x .090 Steel, TIG or MIG welded depending on access.
  • Interior paint & body was done by Richey Collision - Metal was etch primed and painted with single stage DuPont Alpine White.
  • BMW CSL Carbon Fiber Roof - This is one of the last OEM BMW CSL Roofs and includes black CSL rails. The roof was bonded using SEM 39747.
  • BMW OE Windshield - New
  • Five Star Bodies Polycarbonate Rear & Quarter Glass - All windows are attached with screws that are tapped/threaded into the body.
  • Five Star Bodies Rear Window Brace w/Custom Mounts
  • Bimmerworld Carbon Fiber Diffuser
  • Bimmerworld Carbon Fiber Headlight Blanks
Engine/Performance
  • Zionsville E46M Competition Cooling Radiator w/SPAL Fan
  • BMW Motorsport Thermostat
  • VAC Billet Racing Oil Filter Housing
  • C&R Racing Remote Filter Housing w/Custom CNC 6061-T6 Aluminum Mount
  • SETRAB Oil Cooler
  • SETRAB Power Steering Cooler
  • GoodRidge PTFE Oil Lines & AN Fittings
  • Turner Solid Aluminum Engine & Gearbox Mounts
  • Bimmerworld Race Exhaust with straight pipe
  • Remote WIX Racing Filter
  • EPIC Race Tune
  • AFE Stage II Intake w/dry filter/new MAF
Suspension
  • MCS 2way Dampers w/Coil-Over Rear
  • Hyperco Coils 650 Front | 375 Rear
  • Hotchkis Sport Sway Bar Set
  • Ground Control Adjustable End Links
  • Turner Solid Aluminum Bushings & Spherical Bearings
  • Ground Control Spherical Rod Ended Control Arms
  • Turner Subframe Reinforcements Front & Rear - The rear subframe is also tied to the cage.
  • Mason Engineering STB
Interior
  • Custom Carbon Fiber Switch Panel
  • Push Button Start w/GTR Start Button
  • STACK Gauges - Oil Pressure, Oil Temp, Water Temp
  • AiM SOLO DL w/CANBUS Connection
  • Custom Carbon Fiber AiM SOLO DL Mount
  • RaceTech 4009WHR Driver Seat & RaceTech 4009W Passenger Seat
  • SCHROTH Profi II-6 HANS Driver & Profi II-6 Passenger
  • CAE Ultra Shifter
  • VAC Seat Mounts
  • WorksBell Quick Release w/Machined/Pinned Steering Shaft
  • Sparco Steering Wheel
  • Mason Engineering Clutch Pedal
  • Turner Pedals
  • BSCI SFI 45.1 Padding
  • 4 Pole Battery Disconnect Switch
  • SPA 4L Mechanical Fire System
General
  • Apex Arc8 Wheels
  • StopTech ST40 Brakes w/Stainless Lines - PFC11 Front pads & PFC01 Rear pads
  • Hoosier R6 Tires
  • Braille Carbon Fiber Battery
  • Braille Battery Mount
  • PAINLESS Stranded Copper Battery Cable w/Monster Terminals
  • Techflex Braided Sleeving
  • Heater Core Delete
  • CDV Delete
  • A/C Delete
  • Parking Brake Delete
  • Emissions Delete
  • Turner Nylon Tow Hooks
  • Turner 90mm Studs
  • Turner Spacers 5mm F 10mm Rear
  • Machined Rear Hubs to Clear Spacer
  • All new control arms, bolts, axles, seals, hoses etc
  • AMB (MyLaps) Transponder - Hardwired
[Track] 03 AW/CIN 6MT E46 M3
[Street] 08 AW/FR 6MT E92 M3
[Tow/Overland] 23 Toyota Tundra HV TRD Off-Road
      03-29-2020, 11:08 PM   #2
maaicher
maaicher's Avatar
62
Drives: 2008 BMW M3
Beautiful Build!
SOLD Current 2008 Space Grey E92 M3 * JRZ RS Pro * TE37SL * AP Racing * Sparco Evo * Akrapovic Slip On * Studio RSR Cage *
SOLD 2003.5 E46 M3 * Apex ARC8 * MCS 2-Way * Stop-Tech C43 * Recaro Profi XL *
SOLD 2008 Jet Black E92 M3 * HRE C20 19in Wheels * KW Clubsport * Huper Ceramic Tint * Stop-Tech Trophy BBK * Gintani SC & Gintani Custom Exhaust * Vertice Front Bumper * Arkym Diffuser *
      03-31-2020, 04:37 AM   #3
u2usual
u2usual's Avatar
60
Drives: E46 M3 & F80 M3
Amazing build!
Romans 3:23
2002 BMW M3 Racecar
2017 BMW M3 F80
e46m3
